Filtrer IIR VHDL VIVADO
#7698600
Hi, I have a problem with my IIR filter. I coded this filter that works well in simulation. Now that I want to test it on the hardware it no longer works. He’s not stable at all. I use the concept of fixed comma with 10 bit for integers and more or less extra bit for decimals. The problem is in the output samples probably. For an IIR filter it works well: Yn = Xn * 0.125 or Yn = Xn - 2 X(n-10) + X(n-20). Sample frequency is 250 Mhz (like clock) if you have any ideas
thanks the code is attached
  • VF (2.96 KB)
(Company: Starfleet) #7698952
Jürgen S. wrote:
You forgot to post the COEFFs, They might be most relvant for these issues.
There is a section with a comment coefficients in the code:
  constant coeff_0 : signed(NB_Bit downto 0) := X"003FBE";  -- Coefficients
  constant coeff_1 : signed(NB_Bit downto 0) := X"FF8087";
  constant coeff_2 : signed(NB_Bit downto 0) := X"003FBE";
  constant coeff_3 : signed(NB_Bit downto 0) := X"007F78";
  constant coeff_4 : signed(NB_Bit downto 0) := X"FFC082";
number format is not clear
You also should post the simulation
A clear documentation of the utilized algorithm would help (number of pads, expected cut-off, precision of incoming data) and a glimpse of the intended fpga-type (one witw a DSP-slice/hardware-multiplier-macro or not ).
But so far,
#7699273
Your arithmetic is obviously not pipelined, so in the best case, the hardware computes one multiplication and three additions (all depending) in a single clock cycle of 4ns period. Unfortunately you did not mention anything about your hardware (why not?) but this sounds challenging for a non-highend FPGA. Did you specify correct timing constraints? Did you look into the timing report? Did you try to reduce the clock frequency? What did you try at all to find the root of the problem?
#7699503
Good morning,
Yesterday, I managed to operate this filter with the coefficients for a notch. I split the clock, and it worked. Now, I have some questions and I'm conducting tests with different sampling frequencies and coefficients (high frequency).
Thank you for your response.
#7699519
"Your arithmetic is obviously not pipelined, so in the best case, the hardware computes one multiplication and three additions (all dependent) in a single clock cycle of 4ns period."
This seems very interesting; I will look into it further.
I am also wondering how it is possible that with a non-recursive filter, such as:
Y_n = X_n C1 + X_{n-10} C2 + X_{n-20} C3
It works very well with a sampling frequency equal to the clock frequency, which is 250 MHz (ADC). (3 Mux)
Or even with an equation like (using integer coefficients, 1, 2, -1, -2) :
Y_n = X_n C1 + X_{n-10} C2 + X_{n-20} C3 + Y_{n-1} C4 + Y_{n-2} C5
I think it is necessary for me to have a pipelined architecture.
thanks
ps : I use Xilinx Artix-7 FPGA (XC7A35T)
#7699686
When using small integer coeffs as in your example, only a few bits are used for representation. Since the coeffs are constant in your design, the logic synthesis may optimize away parts of the design. Carry chains become shorter, and the design gets faster. For longer coeffs, this is not the case and the timing may fail. Since your IIR works correctly in simulation, I'm quite sure there is a timing problem. Again: Did you specify clock constraints and check the timing report? Running a filter design @250MHz on a XC7A is quite challenging (its one of the smallest in the 7 series), you will need pipelining here for sure. I suggest to use pipelined multipliers and also put a pipe stage in each level of the final adder tree.
#7700014
Not sure. The opening was "it works well in simulation". If this is the case, then there are other reasons. Unused bits as a result of false usage will suddenly cause misbehaviour. However I also thought that coefficients might be not wide enough.
Anyway we need the full code and the full simulation. It then should be evident, what is goging wrong.
#7700364
about the coefficients,
the format is the hexa : There are 10 bits for the integers (input data). Then, there is a number of bits x for the decimals; this number x depends on the precision I want for my coefficients (I ensure that the total is a multiple of four).
#7700369
The filter with long coefficients works in real-time. I divided the clock by 4 and recalculated the coefficients with a different sampling frequency from the clock (250Mhz/4).
I understand the issue a little better now, even though I still have some questions.
" constant coeff_0 : signed(NB_Bit downto 0):= X"000006707EC7"; constant coeff_1 : signed(NB_Bit downto 0):= X"00000CE0FD8E"; constant coeff_2 : signed(NB_Bit downto 0):= X"000006707EC7"; constant coeff_3 : signed(NB_Bit downto 0):= X"007C5C8026EB"; constant coeff_4 : signed(NB_Bit downto 0):= X"FFC389BDDDF7"; " (NB_Bit = 47)
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
