N:1 MUX with 2:1 MUXs, VHDL
OP #7383632
Hi ! So I'm trying to write VHDL code to implement an N:1 MUX with 2:1 MUXs. At the beginning I used a process but the compiler quickly pointed out to me that we can't use port map inside a process So I omitted the process and turn the variables into signals and I got this:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity MUX8_1 is
  generic (
      N : integer := 8;  -- N vers 1
      C : integer := 3   -- Signaux de contrôle
  port (
    E : IN std_logic_vector(N-1 downto 0);
    CTRL : IN std_logic_vector(C-1 downto 0);
    S : OUT std_logic
end MUX8_1;
architecture MUX8_1_arc of MUX8_1 is
--generic map (
--       N => 8,
--       C => 3
component MUX2_1 is
30
  port (
31
    E :  IN std_logic_vector (1 downto 0);
32
    SLCT : IN std_logic; --avec 1 downto 0, la conversion
33
    S : OUT std_logic               -- ne peut se faire
34
35
end component;
36
37
38
  signal L : integer := N;
39
  signal a : integer := 0;
40
  signal E1 : std_logic_vector(N-1 downto 0);
41
  signal T1 : std_logic_vector(N-1 downto 0) := E;
42
  signal T : std_logic;
43
begin
44
  Controle : for j in 0 to C-1 generate
45
    L <= L/2;
46
    a <= 0;
47
48
    E1 <= T1;
49
    T1 <= (others => '0');
50
51
    Entree : for i in 0 to 2*L-1 generate
52
      if (a mod 2 = 0) then
53
        MUX : entity work.MUX2_1 port map(E1(2*L-1-i downto 2*L-2-i), CTRL(j), T);
54
        T1 <= T1&T;
55
      end if;
56
      a <= a + 1;
57
    end generate;
58
59
  end generate;
60
61
62
end MUX8_1_arc;
And here are the errors and warnings that I got:
** Error: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(53): illegal concurrent statement. ** Error: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(54): (vcom-1450) Actual (slice name) for formal "E" is not a static signal name.
** Warning: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(51): (vcom-1147) Range in parameter specification of FOR GENERATE must be static.
** Warning: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(41): (vcom-1013) Initial value of "T1" depends on value of signal "E".
** Warning: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(38): Nonresolved signal 'L' may have multiple sources. Drivers:
C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(45):Conditional signal assignment line__45
** Warning: C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(39): Nonresolved signal 'a' may have multiple sources. Drivers:
C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(57):Conditional signal assignment line__57
C:\Users\loune\OneDrive\Bureau \EE\S2\MSCL\Devoir Maison 1\Ex1_N.vhd(46):Conditional signal assignment line__46
Any help is welcome.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
