Interfacing Nexys2 FPGA with DAC8811 - coding issue
Moderator (Company: Titel) #6910599
Divya P. wrote:
> I am trying to send 16bit value to the DAC8811 but there seems to be
> something wrong
What do you expect and what happens instead? Whats the problem and how
do you recognize it? Whats the according error message and which part of
the toolchain reports it?
> with my code.
Do not post your Ccode as a picture. Ist quite difficult to copy/paste
or to edit such a thing. Attrach it as a *.vhdl file instead. And:
attach the code for the dac_spi component also.
> Can anyone help me out in this?
Did you do a simulation? Is it fine? Add the testbench also.
BTW1: Do you know that indention helps reading and understanding code?
Its not helpful to start each line at the leftmost position.
BTW2: you do not need any variable here.
BTW3: a bit is defned to have two elements: '0' and '1' (e.g. see
https://peterfab.com/ref/vhdl/vhdl_renerta/mobile/source/vhd00010.htm).
So its range is '0' to '1'.
What you need to count is an integer in the range from 0 to 15;
OP (Company: IIA) #6910603
These are the error messages :
ERROR:HDLParsers:164 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 44. parse error,
unexpected IDENTIFIER
ERROR:HDLParsers:3312 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 45. Undefined
symbol 'memory_type'.
ERROR:HDLParsers:1209 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 45. memory_type:
Undefined symbol (last report in this block)
ERROR:HDLParsers:847 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 63. The type of
the range constraint is not compatible with bit.
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 71. Undefined
symbol 'i'.
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 71. i: Undefined
ERROR:HDLParsers:854 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 71. The
expression can not be converted to type std_logic_vector.
ERROR:HDLParsers:808 -
"D:/Divya_Data/FPGA_related/DAC_8811/DAC_8811.vhd" Line 73. = can not
have such operands in this context.
Moderator (Company: Titel) #6910625
Thats fairly easy, just fix 'em.
The first are lines 44 and 45:
type memory_type is std_logic_vector (0 to 15) of bit;
Where did you find such a thing? Looks for me like you want to have a 16
bit wide bit vector. And you try to build it out of a std_logic_vector
somehow...
Why do you not simply use a bit_vector?
https://hdlworks.com/hdl_corner/vhdl_ref/VHDLContents/BitVector.htm
The second error in line 63 (and the following ones) we already had...
BTW: your process "process(clk, rst, daccs, dacsck, dacmosi)" is a kind
of mess. It is synchronous to clk first (with the "usual 1990-Style
async reset), but after the synchronous if...endif there comes a
combinatorial part simply assigning those dac____ signals to other
signals.
That is very bad design and coding practise. You should do it this way:
process(clk, rst) -- never ever more than clk and rst in a sync process!!
variable temp : bit;
variable i : integer range 0 to 15 := 0;
begin
  if (rst = '1') then   -- hmmmpf... really old-school-style from the 80s
    mosi <= '0';
    sck <= '0';
    cs <= '1';
  elsif falling_edge (clk) then
    if (rdy = '1') then
      pattern <= std_logic_vector(i, 16);
      i := i + 1;
      if (i = 15) then
        i := 0;
      end if;
      dacdata(15 downto 0) <= pattern;
    end if;
  end if;
end process;  -- synchronous proces is done here
cs <= daccs;  -- concurrent assignments for routing or combinatorial logic
sck <= dacsck;
mosi <= dacmosi;
A hint: start with a flashing LED, then do some kind of chasing lights.
Then start your first a real world design. You will crash hopelessly
when you start with such a SPI interface as first exercise.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
