Help creating a SPI state machine in VHDL
OP #6700136
Hi all, I'm new to FPGA but am really motivated to become well-adept in
VHDL and FPGA. I am trying to program figure 31 (page 18) shown here:
https://www.analog.com/media/en/technical-documentation/data-sheets/AD7352.pdf
with the help of the timing specifications on page 5. I think there
should be two states: SCLK = High and low and I was thinking about using
a shift register to take the input of a vector of bits. But I am having
difficulty 1) making the state machine 2) programming it into VHDL. I
would appreciate any help!
#6700162
Not that hard. Make a simple counter counting for the full cycle. For
some time in the cycle toggle SCLK for enough clocks. Maybe 30 clocks
will be enough?
Also use SCLK to shift in the value from SDATA.
At the end of the cycle, when counter is at it's maximum, store the two
sample values in the shift register to some other register and set the
counter to zero.
#6700406
So here is the solution:
AD7352_sim.vhd simulates the very basic functionality of the ADC.
AD7352_read.vhd contains what you intend to do, read data from the ADC.
AD7352_bench.vhd connects them both together.
Have fun (-:
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
