Forum: FPGA, VHDL & Verilog VHDL Double and Single clocks designs compare
von Alexander S. (Company: Home) (alex_isr)
Attached ModelSim and Vivado VHDL design of two way implementation of 7
consecutive transactions : one by single clock and second by 2 clocks :
Clock and not Clock.
 In the pictures we can see that with same size of hardware second way
(2 clocks) more quickly : see signals sClockData(single clock disign)
and dClockData(Double Clocks design) calculated from same DataIn.
 So, by using two clocks : Clock and not Clock you can make part or all
your design more quickly or use more slow clock.
 Regards Alex.
 P.S.
Clock and not Clock you can generate by FPGA PLL.
Regards Alex.
: Edited by User
von -gb- (Guest)
The Logic between the clock edges determines the maximum speed. So if
you have leisure time between the edges simply incease your clock speed.
Much simpler than to introduce a second clock.
von daniel__m (Guest)
That's right, your design will be faster in terms of latency. And right,
you have 2 (slow) clocks. Buts clocks are (almost) never the problem.
The problem is the propagation delay between 2 synchronous elements (eg.
ff). You have halfed the time, which is effectively the same as using
one clock with doubled frequency. That's your speed benefit.
greetings
Despite the https://embdev.net/topic/498573#6311869 you don't get the
trick at all, do you?
One very last try...
Lets look at this usual FPGA structure (every FPGA or logic design in
general is similar to this):
      tsu=1ns
        tco=1ns
     ...-|D  Q|-- logic --|D  Q|-- logic --|D  Q|-- logic --|D  Q|-...
         |    |  tpd=8ns  |    |    5ns    |    |    10ns   |    |
clk  --o----------------o----------------o----------------o-------...
How fast can the clk frequency be here?
Its very simple to calculate: 1/(tpdmax+tsu+tco) = 1/12ns = 83MHz
And now its your turn:
      tsu=1ns
        tco=1ns
clk  --o----------------+----------------o----------------+-------...
nclk -------------------o---------------------------------o-------...
> greetings
 You are right for max. system frequency and this max system frequency
for big designs you can implement only by synchronous design.
 My test say : for same system (not. max. FPGA frequency ) frequency
using two clocks : Clock and not clock make you design more quickly such
as design x 2 frequency.
 Regards Alex.
  If my system work by Clock and not Clock such as 10 MHz for release
same function by single clock system you need work with system clock 20
MHz.
 That you can see on the picture.
 Regards Alex.
Question to Moderator : why impossible to edit posts after some minutes
after posting ?
 Regards Alex.
von Christoph Z. (christophz)
> MHz.
This is correct. But in both cases you need an FPGA technology that is
fast enough to get the work done in 1/20 MHz = 50 ns.
If you would argue with power consumption that with two clocks only half
the registers toggle at the same time then it would be a different
discussion. Intel is still using a lot two phase clocking scheme in
their processors. But it's one of few companies still using it, building
the clock tree is much more work than with a single one.
Alexander S. wrote:
> If my system work by Clock and not Clock such as 10 MHz for release same
> function by single clock system you need work with system clock 20 MHz.
And having a view at this FSM template
https://embdev.net/topic/498573#6310299 it results in something like
this:
      tsu=1ns
        tco=1ns
  ...----|D  Q|- logic -|D  Q|-----|D  Q|-- logic --|D  Q|-----|D  Q|-
         |    |   8ns   |    | 1ns |    |    10ns   |    | 1ns |    |
clk  --o--------------+----------o----------------+----------o--------...
nclk -----------------o---------------------------o-------------------...
There's only routing delay between the falling edge FF and the rising
edge FF.
How fast is this design? Whats the advantage to do it this way?
Is ist faster than the one without the falling edge clock?
> discussion.
There is no change in the power demands mean value. Its just a half of
simultaneous switching FF and therefore a reduction of ground
bouncing/noise inside the silicon.
: Edited by Moderator
But it's one of biggest company in the world !
 Regards Alex.
 P.S.
 In my FPGA I try to use system clock slowest as possible and this way
is help me.
I try to design only synchronous VHDL components with only synchronous
reset ready to high speed as possible ... with clock slow as possible .
 For me it's good practice design rules.
 Regards Alex.
with slow (half) clock. So , it may be quarter power ?
 Other question if you need only small part of design quickly : you
other slow part of design work with slow clock.
So, if only small part of your design must work with max. speed such as
400 MH ... biggest part of your design may work 200 MHz it's other kind
of high speed design.
 Regards Alex
 With same clock (not max.high speed of FPGA less than ~100 MHz) double
clock design is faster functionaly and we see that in the picture !
 Regards Alex.
P.S.
 Design function released with one clock 100 MHz
can be implemented by double clock design technology with system clock
50 MHz. Sometimes it's important and preferred.
Alexander S. wrote:
> Design function released with one clock 100 MHz can be implemented by
> double clock design technology with system clock 50 MHz.
Only when logic is balanced also.
But not with your FSM template.
Because with that "double-edge-clock" design like in
https://embdev.net/topic/498784#6314618 the high time of the clock
must be 12ns. And if it is a 50:50 clock, then the low time of the
clock is also 12ns. And 1/(12ns+12ns) is 41,6 MHz.
And now it comes: during the low time of the clock cycle nothing is
calculated or done, because there is only a wire between die falling
edge FF and the rising edge FF. And when nothing is done, then time is
lost.
It is simply that way. Think about it until you understand it.
Lothar M. wrote:
 My tempate of State Machin with double clock have same functional speed
as state machin with one clock.
 I use not Clock sygnal for implement synchronous next state logic.
By definition synchronous logic more quikly then asynchronous.
 So, state machin will can work with higher clock.
 I also use synchronous next state output logic for State Machine output
logic generation signal.
 Regards Alex.
: Edited by User
