For my VHDL designs I use Multi Edit ver.9.1 editor with very friendly user interface and much capability editing tools. This editor have many build in VHDL template with option to edit it or add custom templates. For using template user need type keyword and space. Attached Vhdl.tpt file with my custom templates. User can also build project for easy looking for files of project for editing.
New VHDL file template : Keyword : new_file<SPACE>
1 | --------------------------------------------------------------------------------
2 | --
3 | -- Title :
4 | -- Design :
5 | -- Author :
6 | -- Company :
7 | --------------------------------------------------------------------------------
8 | -- File : xxxxxx.vhd
9 | -- Generated : Jun 20 2020
10 | --------------------------------------------------------------------------------
11 | -- Description :
12 | --------------------------------------------------------------------------------
13 | -- Revision History :
14 | -- -----------------------------------------------------------------------------
15 | -- Ver :| Author :| Mod. Date :| Changes Made:
16 | -- v1.0 | :| 20/06/20 :| Automatically Generated
17 | -- -----------------------------------------------------------------------------
18 | library ieee ; |
19 | |
20 | use ieee.std_logic_1164.all ; |
21 | use ieee.std_logic_arith.all; |
22 | use ieee.std_logic_unsigned.all; |
23 | |
24 | entity NameEntity is |
25 | port
26 | (
27 | ClockIn , -- General Clock |
28 | nClockIn , -- General not Clock |
29 | ResetIn , -- General Reset active High |
30 | `PortName`, -- Port description |
31 | `PortName`, -- Port description |
32 | `PortName` -- Port description |
33 | : in std_logic; |
34 | |
35 | `PortName` -- Port description |
36 | : in std_logic_vector(`MaxValue` downto `MinValue`); |
37 | `PortName`, -- Port description |
38 | `PortName`, -- Port description |
39 | `PortName` -- Port description |
40 | : out std_logic; |
41 | `PortName`, -- Port description |
42 | `PortName`, -- Port description |
43 | `PortName` -- Port description |
44 | : out std_logic_vector(`MaxValue` downto `MinValue`) |
45 | );
46 | end NameEntity; |
47 | |
48 | architecture ArchNameEntity of NameEntity is |
49 | |
50 | signal `SignalName` : std_logic; |
51 | signal `SignalName` : std_logic_vector(`MaxValue` downto `MinValue`); |
52 | signal `SignalName` : integer range `MinValue` to `MaxValue`; |
53 | |
54 | begin
55 | |
56 | end ArchNameEntity; |
Edited by User
New process template : Keyword : pps<SPACE>
1 | Name_Process: |
2 | process (ClockIn ) |
3 | begin
4 | if(ClockIn'event and ClockIn = '1') then |
5 | case nResetIn is |
6 | when '0' => |
7 | -- Conditional Signal Assignment
8 | when others => |
9 | -- Conditional Signal Assignment
10 | end case; |
11 | end if; |
12 | end process Name_Process; |
Keyword : nps<SPACE>
1 | Name_Process: |
2 | process (nClockIn) |
3 | begin
4 | if(nClockIn'event and nClockIn = '1') then |
6 | when '0' => |
10 | end case; |
11 | end if; |
New State Machine template : Keyword : stm<SPACE>
1 | type StateMachine is (Idle,StateMachine.....State,... ) ; |
2 | signal StateMachineCurrentState,StateMachineNextState : StateMachine; |
3 | |
4 | StateMachineCurrentState_Process: |
5 | process (ClockIn) |
6 | begin
7 | if (ClockIn'event and ClockIn = '1') then |
8 | case nResetIn is |
9 | when '0' => |
10 | StateMachineCurrentState <= Idle; |
11 | when others => |
12 | StateMachineCurrentState <= StateMachineNextState; |
13 | end case; |
14 | end if; |
15 | end process StateMachineCurrentState_Process; |
16 | |
17 | StateMachineNextState_Process: |
18 | process (nClockIn) |
19 | begin
20 | if (nClockIn'event and nClockIn = '1') then |
21 | case StateMachineCurrentState is |
22 | when Idle => |
23 | if( = ) then |
24 | StateMachineNextState <= StateMachine.....State; |
25 | else
26 | StateMachineNextState <= Idle; |
27 | end if; |
28 | when StateMachine.....State => |
29 | -- Conditional Signal Assignment
30 | when StateMachine.....State => |
31 | -- Conditional Signal Assignment
32 | when others => |
33 | StateMachineNextState <= Idle; |
34 | end case; |
35 | end if; |
36 | end process StateMachineNextState_Process; |
New signals template : Keyword : si<SPACE>
1 | signal `SignalName` : std_logic := '0'; |
2 | signal `SignalName` : std_logic_vector(`MaxValue` downto `MinValue`):= (others => '0'); |
3 | signal `SignalName` : integer range `MinValue` to `MaxValue` := 0; |
New Variable template : Keyword : va<SPACE>
1 | variable `VariableName` : std_logic; |
2 | variable `VariableName` : std_logic_vector(`MaxValue` downto `MinValue`); |
3 | variable `VariableName` : integer range `MinValue` to `MaxValue`; |
CASE template : Keyword : ca<SPACE>
1 | case `SignalName` is |
2 | when `ConstantValue` => |
3 | -- Conditional Signal Assignment
4 | when `ConstantValue` => |
5 | -- Conditional Signal Assignment
6 | when `ConstantValue` => |
10 | end case; |
IF template : Keyword : if<SPACE>
1 | if( = ) then |
2 | |
3 | elsif ( = ) then |
4 | |
5 | else
6 | |
7 | end if; |
I'll be very glad to know other VHDL editor (preferred FREE) which have VHDL templates with option edit it or add custom templates. Regards Alex. P.S. I'm ready to repair my templates according to your remarks.
Alexander S. wrote: > if( = ) then > elsif ( = ) then Why the parentheses? Alexander S. wrote: > New State Machine template That is VERY, VERY BAD design style! By using both edges of the clock you lose half of the allowed propagation delay. This leads to very slow designs, because the time between the falling clock edge and the rising clock edge is simply wasted. Additionally to this the design gets sensitive to a clock having not exactly a 50:50 cycle. For a beginners design theres one major rule: use onle one and the same edge of only one and the same clock in the whole design. Alexander S. wrote: > I'm ready to repair my templates according to your remarks. Pls. check out your "templates" for such obvious problems and rookie mistakes before releasing it to the world.
Edited by Moderator
Alexander S. wrote: > I'll be very glad to know other VHDL editor (preferred FREE) which have > VHDL templates with option edit it or add custom templates. Emacs with VHDL mode and yasnippet to add more templates: https://github.com/joaotavora/yasnippet Our templates are ready to be used with doxygen to generate documentation out of the source code.
Lothar M. wrote: > Additionally to this the design gets sensitive to a clock having not > exactly a 50:50 cycle. PLL of Xilinx and Altera guaranteed 50:50 cycle with 180 degree from Clock to not Clock signals. Regards Alex.
Lothar M. wrote: > Alexander S. wrote: > For a beginners design theres one major rule: use onle one and the same > edge of only one and the same clock in the whole design. I do not use different edges of clock in the my design. I use two clock generated by PLL : Clock and not Clock. Regards Alex.
Lothar M. wrote: > By using both edges of the clock you lose half of the allowed > propagation delay. This leads to very slow designs, because the time > between the falling clock edge and the rising clock edge is simply > wasted. By using not Clock for logic of next state ... state machine work more quickly because : synchronous logic work more quickly than asynchronous logic and SetUp and Hold time guaranteed by synchronous design Regards Alex. P.S. If you use asynchronous logic for logic next state timing of your state machin not guaranteed . If you change (small changes) asynchronous logic for logic next state your state machin can stop work. Without gate level simulation you do not know that your design is work. In the functional simulation you do not see real SetUp and Hold time and do not know that your design work with real clock. Regards Alex.
Edited by User
Lothar M. wrote: > Alexander S. wrote: >> if( = ) then >> elsif ( = ) then > Why the parentheses? Why No ? It's place for logic. Regards Alex.
Alexander S. wrote: >>> if( = ) then >>> elsif ( = ) then >> Why the parentheses? > > Why No ? Because VHDL does not need them. Alexander S. wrote: > Without gate level simulation you do not know that your design is work. > > In the functional simulation you do not see real SetUp and Hold time > and do not know that your design work with real clock. Do you design for FPGAs or ASICs? What tools do you use for your designs? In the functional simulation I don't care about setup and hold times. This is the Job of the FPGA toolchain to synthesize, place and route a design that meets my clock frequency requirements including worst case setup and hold times (This includes longest paths at highest chip temperature and shortest paths at lowest chip temperature).
Alexander S. wrote: > If you use asynchronous logic for logic next state timing of your state > machin not guaranteed . "My" way (which is the way almost 99,9% of the other FPGA desingers use) is the only way the toolchain can reliably check and prove the timing. > If you change (small changes) asynchronous logic for logic next state > your state machin can stop work. Such simple problems are reported by the toolchain. I simply set a constraint "I want 200 MHz" and the toolchain tries to achieve that. If thats not possible I get an error. It is really that simple. > Without gate level simulation you do not know that your design is work. I set suitable constraints and the toolchain guarantees the timing. > In the functional simulation you do not see real SetUp and Hold time > and do not know that your design work with real clock. I don't care about timing in functional simulation (and I do not do timing simulation since 15 years anymore). Instead I set proper constraints and my designs are running from the scratch. > By using not Clock for logic of next state ... state machine work more > quickly Argh, thats bullshit (thats the most gentle way to say it). THINK about timing and you see, that your design style will reduce your maximum clock frequency to the half. And addtionally you need the double count of registers for that strange FSM style: one register set for the falling clock edge and the same again for the rising edge.
Lothar M. wrote: > I simply set a constraint "I want 200 MHz" and the toolchain tries to achieve that. Great : try it's not always can ! If before finishing big design system can't release ... you will debug and redesign your design ? If big design with your part will not release your constrain ? Regards Alex.
Lothar M. wrote: > Alexander S. wrote: >> I don't care about timing in functional simulation (and I do not do timing simulation since 15 years anymore). So if you design is part of big design only after release that design you will know that your design work properly ? That's your good practice design and style to design ? Regards Alex.
Alexander S. wrote: > So if you design is part of big design only after release that design > you will know that your design work properly ? No, the toolchain will tell me after an implementation process. Long before I have real hardware to put it on. One word to that FSM template is there: https://embdev.net/topic/498784#6314618 > That's your good practice design and style to design ? Alexander, pls stop such shabby personal attacks against me and other users. We do not need that here!
Edited by Moderator
Lothar M. wrote: > No, the toolchain will tell me after an implementation process. Long > before I have real hardware to put it on. I not say about real hardware. I say : if team of designers design the big project and global implementation possible after that all parts is ready : how you check that you part of design work properly with real timing of FPGA ? Regards Alex.
Edited by User
Christoph Z. wrote: > Do you design for FPGAs or ASICs? > > What tools do you use for your designs? FPGA Vivado and Quartus > In the functional simulation I don't care about setup and hold times. > This is the Job of the FPGA toolchain to synthesize, place and route a > design that meets my clock frequency requirements including worst case > setup and hold times (This includes longest paths at highest chip > temperature and shortest paths at lowest chip temperature). So, next compilation you can have other results according to optimization tools. But by some VHDL rules such as using synchronous Reset or using "case" statement instead "if" statement you can insert some constrain for syntezis tools and receive same results of compilations ! Regards Alex.
Alexander S. wrote: > using "case" > statement instead "if" statement Please stop that case vs. if nonsense. a) Not all if-then-elsif-else statements can be rewritten as a case statement. b) But in case it can, you will get the same hardware. Especially your case-template with the nReset will be absolutely the same. There will be no benefit in terms of timing (it is the same netlist). As drawback, this template (yes, it works) is very unusual and hard to read (at least for me). Please stick to the templates given in vendors user guides. greetings
Alexander S. wrote: > I not say about real hardware. Thats the problem. But at last the only relevant thing is real hardware. > how you check that you part of design work properly with real timing of > FPGA ? As already said several times: I do not check it. I urge the toolchain to achieve the timing. And when the tools are not able to fulfill my constraints, they tell me with an error message. So the only thing needed to perform is a STA (Static Timing Analysis). Search for that term in the manual of the toolchain.
Lothar M. wrote: > I urge the toolchain to achieve the timing. So, you do not know that your not full synchronous design (without reset) in the final syntesis of team's design will be released !!! Regards Alex.
Edited by User
daniel__m wrote: > a) Not all if-then-elsif-else statements can be rewritten as a case > statement. But if case state possible it's preffered for high speed FPGA design. Regards Alex.
daniel__m wrote: > hard to read (at least for me). That not say : not work more quickly. Regards Alex.
A fully synchronous design (with or without synchronous reset) with initial values will work in final synthesis, if the clock is properly constrained. This will work with Xilinx, Intel/Altera and Lattice-FPGA. BTDT. Duke
Alexander S. wrote: > But if case state possible it's preffered for high speed FPGA design. Bullshit!
Alexander S. wrote: > can insert some constrain for syntezis tools and receive same results of compilations ! Yes . You can insert some constrain for syntezis tools and receive same results of compilations ! That not say will be released by synthesis tools always after all implementation in the hardware. Regards Alex.
daniel__m wrote: > this template (yes, it works) It's not only work, it's work more quickly than If ... elsif ... else statement and this purpose of using. Regards Alex.
daniel__m wrote: > There will be no benefit in terms of timing (it is the same netlist). In the pictures we see implementation same function of decoder : one released by case statement other by if statement (Before optimisation by development tools). Case statement implemented by set parallel LUTs with propagation delay of one LUT. If statement implemented by set of sequence (consecutive) of 7 CELs with propagation delay of 7 (or more) CELs (x 7). This is the different before optimisation by development tools. You don't know what will be after optimisation. Regards Alex. P.S. It's same implemented function but with different speed.
Alexander S. wrote: > It's not only work, it's work more quickly than If ... elsif ... else > statement and this purpose of using. I proved that this statement is wrong in https://embdev.net/topic/498163#6303923 Alexander S. wrote: > In the pictures we see implementation same function of decoder : one > released by case statement other by if statement Of course there is a difference in sourcecode, then there must be a difference in the direct RTL translation. > It's same implemented function but with different speed. At this point of the design (RTL schemtic) there is no "speed" involved at all. Show an implementation schematic, then we discuss about timing. > Before optimisation by development tools Show a difference after optimization. Then we discuss further on. No one can put a "unoptimized" design on a FPGA, because this kind of "optimization" is only a reduction of logic like student do it with a Karnaugh map. And before the K map a design is always "unoptimized". So thats indeed no "optimization", but just the usual way of implementation. > You don't know what will be after optimisation. How the toolchain implements my desgin doesn't matter at all. But I know for sure that the timing will meet my constraints. Otherwise I will get an error message. And when this error message shows up, then I start seraching the critical path with the STA tool. And then I will fix that path. It IS really that simple. And for such simple if-elsif-endif translations you will get always an optimal implementation. Show one that doesn't result in an optimal hardware in the bitstream, then we discuss further on. Alexander, it seems like you have established your personal design rules based on personal experience with an old fashioned toolchain not capable of proper implementation and not able to use initial values. But that was at the end of the 1900 or the early 2000s. Now we have 2020 and design style and the according rules have changed. The toolchain programmers have done their job and you don't have to think one second about such simple and obviuos translations.
Edited by Moderator
Lothar M. wrote: > But that was at the end of the 1900 or the early 2000s. Now we have 2020 > and design style and the according rules have changed. But synthesis tools implement case and if statement such as 1000 years before we see that on the pictures and optimisation tools not guaranteed always realisation of optimisation. Regards Alex.
Edited by User
Lothar M. wrote: >But I know for sure that the timing will meet my constraints. Otherwise I >will get an error message. If you will get error message only after assembly full design (of designers team) project , you will redesign your part and teams of designers will wait that ? Regards Alex .
Lothar M. wrote: >And when this error message shows up, then I start seraching the >critical path with the STA tool. And then I will fix that path. >It IS really that simple. For small design of single designer. Regards Alex.
Lothar M. wrote: > In the pictures we see implementation same function of decoder : one > released by case statement other by if statement > Of course there is a difference in sourcecode, then there must be a > difference in the direct RTL translation and propagation delay (speed). In one pictures propagation delay is propagation delay of one LUT In other pictures propagation delay is propagation delay of 7 CELLs (x 7). You think optimisation tools can repair that and propagation delay always will be same ? Regards Alex. P.S. Preferred that design work without it optimisation by development tools. So , after it optimisation it will be work with greater guarantee .
Edited by User
Alexander S. wrote: > But synthesis tools implement case and if statement such as 1000 years > before we see that on the pictures Yes, we do. > we see that on the pictures When I feed the Xilinx ISE 14.7 with 4 different designs (if/select/when/case) I always get the very same picture as RTL schematic. All of them simply show a ROM. So obviously all of the descriptions will lead directly to exactly the very same result in hardware. > and optimisation tools not guaranteed always realisation of optimisation. This conclusion is fundamentally wrong. At least until you prove it. Because even the translation from VHDL code to RTL schematic is a kind of "optimization". Or do you see a "case" in the RTL schematic? No, you don't. The "case" is "optimized" to a lookup table. Do you trust the toolchain here, but not further on? If so: why? > and optimisation tools not guaranteed always realisation of optimisation. And of course nobody won't guarantee you anything. Even the synthesizer may translate the "case" statements to the wrong LUT content. Alexander S. wrote: > Preferred that design work without it optimisation by development tools. So, the only way will be to generate the bit stream manually. And even for that you will need a K map. But you are not allowed to use that way of "optimization". Alexander, I'm finished here. Sit on that little heap of sand and wait till the end comes...
Edited by Moderator
Lothar M. wrote: > The "case" is "optimized" to a lookup table. The "case" is "optimized" to the set of parallel lookup tables. The "if elsif else " is "optimized" to the set of consecutive CELLs (LUTs). The optimisation tools can't change that architecture. You can't use ROM for all "if elsif else " statment in your design : it will be set of consecutive CELLs (or LUTs). Sit on that little heap of sand and wait till the end comes... Regards Alex. Good luck in your high speed design in the teams designers.
Edited by User
Other VHDL editor with editable templates SBA System Creator: http://sba.accesus.com/software-tools/sba-creator Also is easy write plugins to run external tools. regards MARC
Alexander S. wrote: > The "case" is "optimized" to the set of parallel lookup tables. > The "if elsif else " is "optimized" to the set of consecutive CELLs > (LUTs). No. What your pictures are showing is the elaborated Design. This is simply what is written in HDL without optimization. It just shows what the Toolchain thinks you described in HDL. But this is not FPGA specific or optimized. In this View you can have and see individual Gates like AND. But in the FPGA there are LUTs. The Toolchain has to take your Logic like Gates and Registers and then map this to the Hardware available. This is combined with optimization. So it will combine many Gates for Example an put them together in a LUT. Or a statemachine in BRAM. To see what the toolchain created and is loaded to the FPGA you have to look at the Schematic of the implemented or at least synthesized design.
Or to be more precise: Your first two Images show the Logic after sythesis, but the last Image "Lothar_M_Decoder_Implementation.PNG" shows the elaborated design. Why are you doing this and compare synthesized vs. unsynthesized? This in unfair to Mr. Miller.
