VHDL Seven Segment Decoder
OP (Company: Home) #6302402
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity SevenSegmentDecoder  is
port
 ClockIn ,                        -- General Clock
 nResetIn                         -- Generar Reset
                    : in std_logic;
 NumberIn                         -- Number for display
                    : in std_logic_vector(3 downto 0);
 nSegmentAOut,                        -- Segment A of 7 Segment Display       A
 nSegmentBOut,                        -- Segment B of 7 Segment Display     F   B
 nSegmentCOut,                        -- Segment C of 7 Segment Display       G
 nSegmentDOut,                        -- Segment D of 7 Segment Display     E   C
 nSegmentEOut,                        -- Segment E of 7 Segment Display       D
 nSegmentFOut,                        -- Segment F of 7 Segment Display
 nSegmentGOut                         -- Segment G of 7 Segment Display
                    : out std_logic
end SevenSegmentDecoder;
architecture  ArchSevenSegmentDecoder of SevenSegmentDecoder is
begin
30
  DisplayDecoder_Process:
31
process (ClockIn)
32
 begin
33
 if (ClockIn'event and ClockIn = '1') then
34
  case nResetIn is
35
   when '0' =>
36
     nSegmentAOut <= '1';          -- Segment A of 7 Segment Display       A
37
     nSegmentBOut <= '1';          -- Segment B of 7 Segment Display     F   B
38
     nSegmentCOut <= '1';          -- Segment C of 7 Segment Display       G
39
     nSegmentDOut <= '1';          -- Segment D of 7 Segment Display     E   C
40
     nSegmentEOut <= '1';          -- Segment E of 7 Segment Display       D
41
     nSegmentFOut <= '1';          -- Segment F of 7 Segment Display
42
     nSegmentGOut <= '1';          -- Segment G of 7 Segment Display
43
   when others =>
44
    case NumberIn is
45
     when X"0" =>
46
      nSegmentAOut <= '0';          -- Segment A of 7 Segment Display       A
47
      nSegmentBOut <= '0';          -- Segment B of 7 Segment Display     F   B
48
      nSegmentCOut <= '0';          -- Segment C of 7 Segment Display       G
49
      nSegmentDOut <= '0';          -- Segment D of 7 Segment Display     E   C
50
      nSegmentEOut <= '0';          -- Segment E of 7 Segment Display       D
51
      nSegmentFOut <= '0';          -- Segment F of 7 Segment Display
52
53
     when X"1" =>
54
55
56
57
58
59
60
61
     when X"2" =>
62
63
64
65
66
67
68
      nSegmentGOut <= '0';          -- Segment G of 7 Segment Display
69
     when X"3" =>
70
71
72
73
74
75
76
77
     when X"4" =>
78
79
80
81
82
83
84
85
     when X"5" =>
86
87
88
89
90
91
92
93
     when X"6" =>
94
95
96
97
98
99
100
101
     when X"7" =>
102
103
104
105
106
107
108
109
     when X"8" =>
110
111
112
113
114
115
116
117
     when X"9" =>
118
119
120
121
122
123
124
125
     when X"A" =>
126
127
128
129
130
131
132
133
     when X"B" =>
134
135
136
137
138
139
140
141
     when X"C" =>
142
143
144
145
146
147
148
149
     when X"D" =>
150
151
152
153
154
155
156
157
     when X"E" =>
158
159
160
161
162
163
164
165
     when X"F" =>
166
167
168
169
170
171
172
173
     when others =>
174
175
176
177
178
179
180
181
    end case;
182
  end case;
183
 end if;
184
end process  DisplayDecoder_Process;
185
186
end ArchSevenSegmentDecoder;
OP (Company: Home) #6302843
berndl wrote:
> that's the worst 7-segment decoder I've ever seen...
 You can put better and more simply for understand design.
It's not problem for me and other readers.
 It's place for discuss and looking for better way for design.
 Regards Alex.
 P.S.
 All readers are waiting to see your nice and simply for understand
design.
Guest #6302894
since you want to drive 4 7-segment displays, according to your I/O-list
 (NumberIn                         -- Number for display
(but you didn't do this) and you allocate libraries which you are never
using
 and, of course, these are outdated libs...
and you are doing it the most inefficient, most complicate way, your
example is by far the worst 7-seg decoder I've ever seen...
You are flooding the forum here. What you show is not really something I
want to teach/tell people when they do logic-design...
Guest #6302912
Andreas S. wrote:
> Why is your decoder clocked? It doesn't need any saved state or
> registers.
it simply doesn't matter. I just want to give out some information with
4 7-seg-displays. And clocking this will resolve any issue with
timing... I don't care about a delay of 10ns...
Moderator (Company: Titel) #6303031
Don't throw bricks when you live in a glass house: why is yours?
> It doesn't need any saved state or registers.
Indeed.
What do you want to make better in your design?
There is a stop watch with a 4 digit 7-segment display:
http://www.lothar-miller.de/s9y/archives/88-VHDL-vs.-Verilog-am-Beispiel-einer-Stoppuhr.html
That whole design consumes less space and is better readable than your
copyandpaste orgy.
Guest #6303056
Andreas S. wrote:
> What are you talking about? I don't remember that I ever published a
> seven segment decoder.
Andreas, I just wanted to ask your question... Seems that this thread is
a really dead one. We simply should talk about more interesting stuff in
other threads, like to read you again...
OP (Company: Home) #6303148
> registers.
You are right :if your design only decoder you do not need
clock/register.
 But if your decoder small part of big high speed design, speed of your
decoder it's part speed of all design.
 Regards Alex.
Moderator (Company: Titel) #6303170
And besides general statements: what's the use of (or the need for) a
clock at this very point? Why should it be necessary to update 7-segment
displays some 50000000 times a second? How fast is the led driver
circuit? And how fast are your eyes?
OP (Company: Home) #6303285
> copyandpaste orgy.
 In the picture you can see schematic of implementation by Xilinx my
decoder design.
(Sorry for duplicate pictures. I can't not delete pictures. Can anybody
help me delete duplicate pictures ?)
 Your decoder design :
  -- the decoder
  segments <= "1000000" when digit=0 else
              "1111001" when digit=1 else
              "0100100" when digit=2 else
              "0110000" when digit=3 else
              "0011001" when digit=4 else
              "0010010" when digit=5 else
              "0000010" when digit=6 else
              "1111000" when digit=7 else
              "0000000" when digit=8 else
              "0010000" when digit=9 else
              "0111111"; -- is a dash, but will hopefully never be used!
 Your design is same with my design.
You use :
 I use :
    case NumberIn is
     when X"0" =>
 Yes !
Your code is more shortly .
 But my code more easy for understand debug and repair.
My design is faster
(  Your design contains more than 10 consecutive checks, and mine always
does only one check.
 You do not know how the development system will make optimization and
what will be the result.),
 sometimes it's matters.
OP (Company: Home) #6303348
Lothar M. wrote:
> How fast is the led driver circuit?
 It's not problem of external device such as led driver or eyes or
other!
It's problem of big high speed (such as GMII 125 MHz of MII 25 ethernet
interfaces and other) design with display static information of main
design state.
  If you ask development system calculate max. design frequency of youe
design it calculated include your decoder as part of design.
 Development system don't know that decoder for static information.
 So, if your decoder can work with max. frequency such 10 MHz,
development system will say max. frequency of all design such 10 MHz.
 For calculate real time and  max. frequency of high speed part of your
design you have two option :
 All part of your design must work with max. frequency .
Or
 You need insert to development system constrains : not include slow
part of design to system timing calculation.
 If you have many slow parts in your design,
it's problem to insert this constrains.
 If you want to use your components in the future and don't know
application, preferable for my opinion to design all components for high
speed design : clockable.
 Don't use statement :
if( = ) then
elsif ( = ) then
elsif ( = ) then
else
end if;
use only :
case `SignalName` is
 when `ConstantValue` =>
    --  Conditional Signal Assignment
 when others =>
end case;
Use only synchronous reset .
 It's small part of many rules for high speed VHDL design.
Moderator (Company: Titel) #6303684
> My design is faster (  Your design contains more than 10 consecutive
> checks, and mine always does only one check.
"My design is better than your design!"
Childisch game, isn't it?
Did you synthesize my design? Did you find 10 consecutive checks?
I check that out when my constraints are not met.
Why not? Can you proof your statements? What toolchain for what target
did you use for that proof?
My preffered design rule is: use no reset at all.
And if you have to use a reset, then ceck out whats the best way for the
target hardware. FPGAs behave different from manufacturer to
manufacturer and from series to another series.
Guest #6303787
Hi!
@Alexander S.
I just can't believe it...not a single knowledge how to develop VHDL
code, but such a big mouth!
First, I wanted to defend you against the arrogant tone in the forum,
but keep on reading your post I must see that you're unfortunately the
same ...
@Lothar don't waste your time with such kind of people and continue to
support people who are worth it.
Cheers :)
OP (Company: Home) #6303852
 It's great rule : your designs have undefined state after power up.
See (attached picture) simulation of your reference Debounce design : it
may have 2 mS undefined output.
 If anybody include this design in the his design that all design will
have 2 mS undefined state after power up.
 Regards Alex.
Moderator (Company: Titel) #6303923
Alexander S. wrote:
> Yes. Sorry ,it's only 9 consecutive checks in your design for decimal
> display.
What is the resource use of those both designs? What is the timing
closure of both designs?
I did some tests with Xilinx ISE 14.7 (it's the only toolchain available
on this computer). I added input flipflops to get a timing calculation
to your design and implemented my design with the missing 7 segment
decoding for A to F. Now both of the designs do the very same.
Then I started the synthesizer and the result with your code is:
Selected Device : 3s50pq208-5
 Number of Slices:                        6  out of    768     0%
 Number of Slice Flip Flops:             11  out of   1536     0%
 Number of 4 input LUTs:                  8  out of   1536     0%
 Number of IOs:                          13
 Number of bonded IOBs:                  13  out of    124    10%
 Number of GCLKs:                         1  out of      8    12%
  Clock period: 2.482ns (frequency: 402.885MHz)
The synthesis result with my code is:
 Number of IOs:                          13
Do you find a difference?
Also the technology schematic of both look exactly the same.
And the RTL-schematic of both descriptions is much more simple:
input --> FF --> ROM(16x7) --> FF --> output
So even the old fashioned ISE toolchain can recognize such a simple
"everyday" description and transfer it correctly to a minimal
implementation.
Conclusion: neither of both ways is "faster" or "slower" in real life.
SRAM based FPGAs have a well defined state at power up, because all of
the FPGA is loaded with defined values out of the config ROM in the
configuration cycle.
See the design guide of the configuration process for a specific FPGA
type. And for a Xilinx FPGA additionaly read the WP272.
OP (Company: Home) #6312495
 But you do not know : how start your design with this defined state and
can't see that on the functional simulation !!!
 Regards Alex.
OP (Company: Home) #6312510
 You see no difference for small design and after optimisation by
development tools.
 This optimisation not guaranteed by development tools.
My design will have this paramrters in all big design, Part of which is.
Your design will have parameters according to big design,Part of which
is and can change it if this big design will change.
 Regards Alex.
P.S.
 All asynchronous design can change it timing (without changes code)
after next implementation and will be or more good or more bad.
OP (Company: Home) #6312572
> [pre]
>  Number of IOs:                          13
   See in the piture in the bottom : my design is smaller and not same
as your.
 It's only 7 (not 11) Slice Registers and we see that in the picture.
 Regards Alex.
Moderator (Company: Titel) #6313203
Fairly easy to see: because you kicked off the 4 input registers you can
easy calculate 11-4 = 7. Whats the news?
> my design is smaller and not same as your.
But in a usual design this decoder would use no (zero, nada, null, 0)
register at all. Because there is no need for no clock at all. And "no
clock" leads to "no registers".
This ist childisch.
Alexander, see it that way: when you are the big boss and your design
rules and your design style are the best in the world, why do you have
to prove it?
OP (Company: Home) #6313854
Lothar M. wrote:
> your design
> to prove it?
 My design rules and my design style isn't the best in the world.
Your design rules and your design style is your problems
 Good luck in your designs.
 Regards Alex.
Guest #6313886
No. Lothars design rules are the result of experience and proven in real
hardware. Lothar can give reasons for every piece of code. And Lothar is
sharing a lot of his knowledge.
I have make often the same experience in FPGA design, so I can rate this
a little bit.
Duke
Guest #6314084
>  Regards Alex.
Donald, is it you?
OP (Company: Home) #6314483
> a little bit.
> Duke
   So, your experience say : asynchronous design more good (for high
speed design) then synchronous and that FPGA system does not need system
reset after Power Up ?
 I'm sorry that students have teachers like you.
 Regards Alex.
Guest #6314543
> speed design)
Who sad that? A rule of thumb: keep away from async stuff. It needs
different design rules (for the engineer) and the toolchains may not
protect you from mistakes.
That's right. The FPGA does not needed an explicit reset, since due to
configuration, the FPGA is well defined. But: your design may need a
reset. See WP272 from Xilinx.
For me, I almost never have a POR. I use local resets when needed ans
where needed (stream interruptions, etc.). For example, I rarely reset
data register, most of the time, I only (re-)set (flow-) control
registers.
greetings
Moderator (Company: Titel) #6314602
Alexander S. wrote:
> So, your experience say : asynchronous design more good (for high speed
Where did you dig out this statement?
> and that FPGA system does not need system reset after Power Up ?
Yes. Indeed all SRAM based FPGA do not need a reset path in the VHDL
code. They will power up with predictable values.
Alexander, no personal attack here, pls!
(Company: Schweigstill IT) #6314983
Alexander S. wrote:
>  Do you know from what state start your state machine if you have not
> system reset ?
During initialization of the FPGA "everything" is loaded from the
bitstream. This also includes the initialization values for all
registers. So the FPGA "knows" the states of all FSM.
Lothar wrote "predictable values" which means reproducible and well
defined. Of course it doesn't mean that the developer knows these
values. If one doesn't want to rely on the default values which are
determined by the VHDL used he can use explicit initialization values
for register definitions.
Moderator (Company: Titel) #6315018
> system reset ?
Yes. It behaves as for VHDL defined: the initial value is the leftmost
state in the state definitions. And for most synthesizers you can define
another initial value also. The synthesizers users guide is the place to
look for such information.
Alexander S. wrote:
> Because you ask : why I use only synchronous logic !
Where did I?
I'd asked why you implement unnecessary flipflops and add latency.
Moderator (Company: Titel) #6315542
Alexander S. wrote:
> So , you don't know from what state start your state machine ?
As I said several times: RTFM of your toolchain. There it is written on
page 202!
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug901-vivado-synthesis.pdf
And if you don't want to READ THE FULL MANUAL then learn searching the
internet:
https://www.xilinx.com/support/documentation/sw_manuals/help/iseguide/mergedProjects/destech/html/cd_webpackcontrolling_register_initial_states.html
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
