Raspberry Pi XDC-File vivado
OP #7522664
Hi everyone, I would like your help regarding the xdc file of a project for handling a double input ADC. For testing purposes, I'm testing only one input first, then I'll test both. When running Generate Bitstream I get the following error message.
Error: [DRC UCIO-1] Unconstrained Logical Port: 12 out of 22 logical ports have no user assigned specific location constraint (LOC). This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all pin locations. This design will fail to generate a bitstream unless all logical ports have a user specified site LOC constraint defined. To allow bitstream creation with unspecified pin locations (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks UCIO-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: Dout[9:0], CLK, and CLK_out.
I hope to be able to connect the PYNQ Z2 with my Eval-Borad LTC2287 via the Pynq Z2's RPi inputs.
Moderator (Company: Titel) #7522976
  1. Start the thread in the englisch spoken embdev.net
  2. Read the error report and act according to it: assign the ADC_Interface ports to the corresponding FPGA pins
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
