Where is the fatal error? I couldnt find it
Guest #7143005
Hello everyone,
I compiled the 2 codes I gave in the attachment on Questasim without any
errors. But when i want to start simulation i get this error but i
couldn't find any problem. I'm new at this job, I'd be very happy if you
could help.
Guest #7143072
Maybe you have to give every value the correct 4bit.
If the int is 9 (1001) so the Segments are all on (111 1111).
How is it decided what time is the alarm time?
Does the current time just count up from 0 to 9?
Guest #7143074
I forgot. You also have to give the correct segments the high.
So if it ist
A6 A5 A4 A3 A2 A1 A0
set the correct segments high to give the correct number if the both
times matching.
Guest #7143213
There are some issues with your design. First, as already noted, you're
trying to assign vectors of different lengths. Second, you're driving
DISPLAY from multiple processes. I'd suggest to just use two processes.
One that generates the sound, the other that generates the display
output. It should actually be something like
process (ALARM_TIME, CURRENT_TIME, SHOW_A)
begin
  if SHOW_A = '0' then
    case CURRENT_TIME is
      -- 7 segment encodings...
    end case;
  else
    case ALARM_TIME is
    end case;
  end if;
end process;
process (ALARM_TIME, CURRENT_TIME)
begin
  if ALARM_TIME = CURRENT_TIME then
    SOUND_ALARM <= '1';
  else
    SOUND_ALARM <= '0';
  end if;
end process;
Note that in general one would not just assign the outputs inside a
process. One would rather use a signal that is assigned to the output
outside a process. Although in your case it does not matter.
Guest #7143308
Engin wrote:
> Thanks for helping. I will test your code. I tried again, changing
> the
> code a bit. The error is as follows. My code is like this.
> What do you say about this?
> Thanks Again.
The entity DDRV has 3 inputs and 2 outputs. Your testbench instantiates
the entity using 7 ports in total - the 5 former ports as in your task
as well as two additional ports DISP_CURRENT and DISP_ALARM. These
"ports", however, are internal signals used in the architecture. They
don't appear as output ports, which is why the simulator is complaining
as you're trying to connect to ports that are not assigned as ports..
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
