Getting Rank of Elements in an Array
OP #7104207
Dear VHDL Coders,
I am trying to get the rank of elements from an array of data. For
example, I have an array, Voltage = [20 40 10 30] ;
The position of the elements in the voltage array is ranged from 0 to 3.
Using a bubble sorting algorithm, I obtained index of the elements in
array as follows: Index (0)= 2 ; Index (1)= 0  ;  Index (2)= 3 ; Index
(3)= 1 ;
However, basically I just the rank of the elements in the voltage array.
I expect to get: Rank (0) = 1 ; Rank (1) = 3 ; Rank (2) = 0 ; Rank (3) =
2 ;
I would appreciate any of your help and suggestion to get the desired
outcome using the VHDL code. Thanks, a bunch in advance  :)
Moderator (Company: Titel)
Which one?
Must that be finally implemented on hardware or ist it just some fun for
the simulator?
Because if "VHDL" is 100% then "VHDL for synthesisis" ist somewhat less
than 5%
Show your code, so we have something to start and the type definitions
at least...
Guest
No matter if you are interested in the sorted array values or just the
ranks: It is a sorting problem. So forget VHDL for the moment and think
about an algorithm for sorting in hardware (assuming you need real
synthesizable hardware)
What is the size of the array? Shall the sorting be done sequentially or
in parallel? May be this paper gives you a first idea:
https://web.ece.ucsb.edu/Faculty/Parhami/pubs_folder/parh99-ieeetpds-dd-lin-arrays.pdf
However, if the array is small as in your example, there may be a
simpler solution like here
https://ijariie.com/AdminUploadPdf/hardware_implementatioon_of__sorting__algorithm_using_FPGA_ijariie7623.pdf
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
