I am working with an online learning tool for VHDL, trying to make a
frequency reducer using generics.
The basic idea is: Set 'DIVIDE_BY' to a value, then get 'clk_en_out' = 1
on every 'DIVIDE_BY'th rising edge of 'clk_in' for one pulse, before
setting it back to 0.
E.g.: DIVIDE_BY = 8: wait for 7 rising edges, on the 8th, set clk_en_out
= 1, on the 9th, set it back to 0, repeat.
If 'reset' = 1, reset the cycle and start at 0.
Unfortunately, I do not know what values the tool tests, so I cannot
check why it doesn't work/on what pulse it wants me which test instance
to be 1.
I do know though that 'DIVIDE_BY' is less than 16, so an overflow of my
'counter' signal should not be the problem.
In the attached screenshot, the 'valid' line stops being 1 on rising
edge 4, yet when I twisted the code so as to have 'clk_en_a' (test
instance one; the second one is 'clk_en_b') be 1 there, it didn't
change. I assumed that trying to get 'b' to be 1 there would be
pointless, as that would make 'a' be 1 much earlier, which in theory
should set the valid line to 0 much earlier.
Can someone help me figure out why it does not work?
libraryieee;
useieee.std_logic_1164.all;
useieee.numeric_std.all;
entityClockEnableGeneratoris
generic(
DIVIDE_BY:integer
port(
clk_in:instd_logic;
clk_en_out:outstd_logic;
reset:instd_logic
endClockEnableGenerator;
architecturertlofClockEnableGeneratoris
signalcounter:unsigned(3downto0):=(others=>'0');
signalclk_out2:std_logic:='0';
begin
process(clk_in)
begin
if(rising_edge(clk_in))then
counter<=counter+1;
if(to_integer(counter)=DIVIDE_BY)then--reset the counter at 'DIVIDE_BY'
It looks fairly fine, all in all.
One problem is the well known one-by-one error: you are counting one
step to far. With DIVIDE_BY-1 set to 8 you will see:
0,1,2,3,4,5,6,7,8
Try it this way:
if (to_integer(counter) = DIVIDE_BY-1) then...
An additional hint: why don't you simply use an integer as counter?
Eric J. wrote:> In the attached screenshot
What's the testbench code for that waveform?
Hi, thanks for the reply.
I tried the -1 in the if... didn't work either, unfortunately.
Uh, good question with the integer. Most of the code was copied from my
solution for a previous task, that's why it is a binary vector.
For the screenshot, I do not know what the testbench code is... that's
the problem with the online tool.
Eric J. wrote:> I do not know what the testbench code is...
The testbench code is useless for counters more than 7..8 clocks,
because then the external reset pops up.
I had a chance to put your code on a testbench. What I found: you have a
weird async reset structure:
process(clk_in)
begin
ifrising_edge(clk_in)then
endif;
ifreset='1'then
endif;
endprocess;
That means: your sensitivity list is incomplete, reset is missing. Due
to that you see a strange behaviour of your design: although reset pop
up at a absolutely random time, the counter value is reset with the next
change of the clk_in and therefore at the falling(!!) edge of this
clk_in.
Two solutions:
1. Add the reset to the sensitivity list
process(clk_in,reset)
begin
endif;
ifreset='1'then
endif;
endprocess;
2. Change the structure to a synchronous reset:
process(clk_in)
begin
ifreset='1'then
endif;
endif;
endprocess;
I prefer the unmentioned third one, so I get a synchronous design with
no hazzle about a sensitivity list at all:
processbegin
waituntilrising_edge(clk_in);
ifreset='1'then
endif;
endprocess;
See my solutions attached. I wrote a simple testbench generatin an
100MHz clock and a reset signal every 331ns. Both of them behave the
same and like I expect them to.
Thank you for the detailed explanation. Made my code prettier with the
reset.
It didn't fix the problem, though; after some trial and error, I landed
at:
libraryieee;
generic(
DIVIDE_BY:integer:=1
port(
clk_in:instd_logic;
reset:instd_logic
signalcounter:integerrange-1to15:=0;
begin
begin
counter<=counter+1;
if(counter=DIVIDE_BY-2)then--reset the counter at 'DIVIDE_BY'
counter<=-1;
clk_en_out<='1';--set the out2 signal
30
else
31
clk_en_out<='0';
32
endif;
33
endif;
34
ifreset='1'then--reset on HIGH reset input
35
counter<=0;
36
clk_en_out<='0';
37
endif;
38
endprocess;
39
endarchitecturertl;
Note that counter is set to -1 once the DIVIDE_BYth rising edge is
reached - because the interval clk_out_en is 1 apparently should not be
counted. By giving the counter one more rising edge to count, the
problem is fixed.
Thank you for the help!
Eric J. wrote:> the problem is fixed.
What "problem"? As far as I see the problem is your understanding of
what should happen.
> because the interval clk_out_en is 1 apparently should not be counted.
Look on any µC or any other computing device with a counter inside all
over the world: each of them continues counting when reporting an
overflow or a match or something else.
Based on what "appearance" do you come to this conclusion? What should
happen, when DIVIDE_BY is 1? If you have a clock of 10 MHz and DIVIDE it
BY 1, then the clockenable must be '1' all the time. Because dividing
by 1 means "run with the clocks frequency". And exactly thats what my
code does (see the screenshot)...
Running your code against my testbench leads to
# RUNTIME: Fatal Error: RUNTIME_0067 design.vhd (24): Value 16 out of range (-1 to 15).
And its obviously why: you initialize counter with 0. Then you set
DIVIDE_BY to 1. Then you assign a clock and do this comparison "if
(counter = DIVIDE_BY-2) then..." which is the same as "if (counter = -1)
then...". And as counter value is "0 and increasing" that compare
against -1 is always wrong and the counter counts on and on until it
reaches the end of its range generating an error message.
Check it out yourself: https://www.edaplayground.com/x/DZuL
A question of your own?
This thread is over 4 years old.
Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
