Types do not match between component and entity at Simulation on Modelsim
Guest #6710422
Hi, I am requesting some help because I am completly stuck in my VHDL
project. All of my VHD files do compile without any errors, but when I
want to simulate the whole block on Modelsim, here is what I get:
# ** Fatal: (vsim-3807) Types do not match between component and entity
for port "nibble1".
#    Time: 0 ps  Iteration: 0  Instance: /myadder_vhd_vec_tst/i1 File:
Adder.vho Line: 37
# FATAL ERROR while loading design
# Error loading design
# End time: 09:47:42 on May 31,2021, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
Error.
This should be an easy error to spot, but I've checked my types a
thousand times, they all seem to match. Here's my code. Once again they
all compile, but I get these errors only at simulation on Modelsim.
library IEEE;
USE IEEE.STD_LOGIC_1164.all;
USE IEEE.NUMERIC_STD.all;
ENTITY myAdder IS
  PORT
    nibble1, nibble2 : IN unsigned(3 downto 0);
    sum              : OUT unsigned(3 downto 0);
    carry_out        : OUT STD_LOGIC
END myAdder;
ARCHITECTURE myArch OF myAdder IS
  signal temp : unsigned(4 downto 0);
BEGIN
  temp <= ("0" & nibble1) + nibble2;
  sum <= temp(3 downto 0);
  carry_out <= temp(4);
END myArch;
The error specifically mentions the port "nibble1" which is strange.
Thanks.
Guest #6710454
And where is myAdder used? I suspect the error to be in the component
instantiation.
In the top level file you probably have something like
component myAdder IS
  PORT
end component;
adder : myAdder
port map(
  nibble1 => ...,
  nibble2 => ...,
Check if everything is correct there.
PS: For me the text indentation in the code view is very high. Is that
the same for everyone?
Guest #6710464
This is also wrong:
<code>
</code>
Please, resume the lesson reagarding the difference between '0' and "0".
Also, re-read the specification regarding array-types and the relation
to range - definition.
You're lying. Hint: there can be more than just a single type definition
for 'unsigned' in a code, this depends on the different libraries
(ieee.numeric_standard",ieee.numeric_bit ) included.
Yes, the vhdl syntax highlight ist quit broken here.
Moderator (Company: Titel) #6710486
Yes, its a problem within the English forum. I reported it to Andreas,
but he seems busy.
The other tags [pre], [c], [code] don't work much better...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
