*HELP VHDL CODE *
Moderator (Company: Titel) #6694969
MariosBon wrote:
>  *HELP VHDL CODE *
I can't see  no VHDL to help.
> Can someone help me with the code?
Let's try to do it this way: you show some code and ask a particular
question about a specific problem. Just to say: "do my homework pls"
isn't enough.
Guest #6695012
Just for a start, here a simple subcomponent:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
use ieee.std_logic_arith.all;
entity cmpx is
  port(
    data_a_i  : in  std_logic_vector(7 downto 0);
    data_b_i  : in  std_logic_vector(7 downto 0);
    greates_o : out std_logic_vector(7 downto 0));
end port;
architecture behave of cmpx is
begin
  greatest_o <= data_a_i when data_a_i > data_b_i else
                data_b_i;
end architecture behave;
Guest #6696222
ty for the reply,,, for 2 numbers its easy but what about 8? i thought
that i can put the first number to a "max" variable and the compare that
variable to the numbers but i am not sure how i can write these thoughts
on vhdl code.
Guest #6696290
library ieee;
USE ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
USE ieee.std_logic_unsigned.all;
ENTITY compare8 IS
       port(a,b,c,d,e,f,g,h : in std_logic_vector ( 7 downto 0);
           ( exod:out std_logic_vector (7 downto 0));
end compare8
ARCHITECTURE  behaviour OF compare8 IS
        m : std_logic_vector(7 downto 0);
BEGIN
     m<=a;
( and here is where my brain freeze and i cant continue the programm..i
try to use the comand IF but i stuck after the first comparison)
Guest #6696361
The problem is not VHDL. The problem is that you have no clue how to
find the largest of 8 numbers.
So ... just describe in natural language, here, how to get the largest
of 8 numbers. This is step 1. When you know how to find the largest
number, then we can think of how to do this in vhdl.
Moderator (Company: Titel) #6696614
And then pls wrap your VHDL code into the VHDL tags as described here
above each edit box in "Formatting options".
Never ever both together!
In real life these two lines beneath each other are a reasonable reason
to get fired.
Guest #6696930
Just use the 2-> 1 subcomponents and  GENERATE directive to construct
-first  layer: with  4 subcomponents to get 4 results of 8 inputs
top-level
-second layer: with  2 subcomponents to get 2 results of 4 inputs (all 4
outputs of 1-layer)
-third  layer: with ... ( this shall be easy to guess)
https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.55.6397&rep=rep1&type=pdf
Moderator (Company: Titel) #6696963
Or do a simple loop with a compare and an assignment to a variable.
But I think, FPGA NOTFALLSEELSORGE is correct: first there must be a
solution on a sheet of paper. In the best case as a schematic. Then its
fairly easy to describe this schematic with the hardware description
language VHDL.
Guest #6696979
And the concept used here is called a (binary) tree - structure , or in
German Language 'Baumstruktur' ...
In this particular case see "comparing tree"
https://www.pickeringtest.com/de-de/kb/hardware-topics/switching-architectures/comparing-tree-and-conventional-mux-architectures
Guest #6698690
in natural language : lets say that we have 8 numbers .. lets put the
first number in a viarable ( max ) and then we compare the max first
with b , if the number b > max then the max will take be the number b
else the max variable will remain the same , and then we must compare
the max viarable to the other numbers , at the end we have to assign the
max value to the output...... thats how i think it will work.
Guest #6698707
or i can compare it in multiple (if) comands but i dont know if it is
syntictically correct like :
IF ( A < B) THEN
     O1<= B; ELSE
     O1<=A;
IF ( C < D ) THEN
     O2<=D; ELSE
     O2<=C;
IF ( E < F ) THEN
    O3<=F; ELSE
    O3<=E;
IF ( G < H ) THEN
    O4<= H ; ELSE
    04<= G ;
IF (01 < 02 ) THEN
    S<= 02 ; ELSE
    S<= 01;
IF (O3 < O4) THEN
   Y<= 04;   ELSE
   Y<=03;
IF (S < Y ) THEN
    M<=Y;   ELSE
    M<=S;
( This is my second thought but i think is really wrong)
Guest #6698748
Well you described one method in natural language and in "code" you
wrote an different method. But yes, both will work.
But don't use signals names 04 or so, tzhey have to start with a letter.
Now it is time to write correct vhdl. You may choose between a clocked
pipeline or a combinatorical solution.
Moderator (Company: Titel) #6699032
And they may be mixed up with o4 or so...
The thought is ok, but you will encounter some weird results in
simulation due to how signals behave.
I would try it simply without any process. Somehow like that:
signal ab, cd, ef, gh, abcd, efgh : std_logic_vector( 7 downto 0);
    ab   <= a when a>b else b;
    cd   <= c when c>d else d;
    ef   <= e when e>f else f;
    gh   <= g when g>h else h;
    abcd <= ab when ab>cd else cd;
    efgh <= ef when ef>gh else gh;
    max  <= abcd when abcd>efgh else efgh;
Guest #6700929
Hello guys, after some reading and help from you i wrote the programm
just like that , any correction accepted. ( This is my first program in
vhdl )
 LIBRARY ieee;
 USE ieee.numeric_std.all;
ENTITY compare8 IS
      PORT ( a,b,c,d,e,f,g,h : IN std_logic_vector (7 downto 0);
             max : OUT std_logic_vector (7 downto 0);
END compare8;
     SIGNAL (a_uns,b_uns,c_uns,d_uns,e_uns,f_uns,g_uns,h_uns,ab_uns,cd_uns,ef_uns,gh_uns,abcd_uns,efgh_uns,high_uns : UNSIGNED(7 downto 0);
     BEGIN
   a_uns<=UNSIGNED(a);
   b_uns<=UNSIGNED(b);
   c_uns<=UNSIGNED(c);
   d_uns<=UNSIGNED(d);
   e_uns<=UNSIGNED(e);
   f_uns<=UNSIGNED(f);
   g_uns<=UNSIGNED(g);
   h_uns<=UNSIGNED(h);
 ab_uns<= a_uns WHEN a_uns>b_uns ELSE b_uns;
 cd_uns<= c_uns WHEN c_uns>d_uns ELSE d_uns;
 ef_uns<= e_uns WHEN e_uns>f_uns ELSE f_uns;
30
31
 hg_uns<= h_uns WHEN h_uns>g_uns ELSE g_uns;
32
33
 abcd_uns<= ab_uns WHEN ab_uns>cd_uns ELSE cd_uns;
34
35
 efgh_uns<= ef_uns WHEN ef_uns>gh_uns ELSE gh_uns;
36
37
 high_uns<= abcd_uns WHEN abcd_uns>efgh_uns ELSE efgh_uns;
38
39
 max<=high_uns;
40
41
END behaviour;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
