vcom-1576 error with expecting BEGIN
Guest #6708321
Hello!
I'm newbie in this topic, so sorry if I say something dumb. I have the
following code, which always comeback with a 'vcom-1576 error expecting
BEGIN at line 12 in ModelSim. What I'm missing from the code?
Thanks for the help in advance!
library IEEE;
use IEEE.std_logic_1164.all;
entity MODULE is
port ( X,Y,BIN : in std_logic_vector(3 downto 0);
  D  : out std_logic_vector(3 downto 0);
  BOUT : out std_logic_vector
end MODULE;
architecture behavioral of MODULE is
p1: process(X, Y,BIN);
variable var_D, var_BIN : std_logic_vector(3 downto 0);
begin
var_BIN := BIN;
for j in 0 to 3 loop
var_D(j) := X(j) xor Y(j) xor var_BIN;
var_BOUT(j) := (not X(j) and Y(j)) or (not X(j) and var_BIN(j)) or (Y(j) and var_BIN(j));
end loop;
D<=var_D;
BOUT<=var_BOUT;
end process p1;
end behavioral;
Guest #6708653
von -gb-, thank you for understanding the error message, but my problem
is, where is the begin missing? Because in my code there is the begin at
line 14, and I don't understand why the program says it's missing...
#6708673
Formatting helps to finde errors. I attatched a formatted version. The
";" in
is a bug.
There is also no need for variables. So you process boils down to
process (X, Y,BIN) begin
    D(j)    := X(j) xor Y(j) xor BIN;
    BOUT(j) := (not X(j) and Y(j)) or (not X(j) and BIN(j)) or (Y(j) and
BIN(j));
  end loop;
end process;
EDIT: REMOVED VHDL TAGS BECAUSE THEY BREAK FORMATTING !!!!!!1111elf!
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
