Duty and phase control clock divider
OP (Company: Flashgate Technology) #5701518
Hi, I'm new to this forum and I looking for some guidance on a problem
that I've got with a duty and phase control clock divider. I need to
generate 2 clock outputs (same frequency) that have varying duty cycles
and a phase differential between the first and second clock. To
accomplish this, I am using a high-speed clock from a PLL that it
operating at 36x the target frequency and dividing it. By using a clock
that is 36x faster than the target my thinking is that I can divide it
down to provide phase and duty control in 10 degree steps for each tick
of the input clock. The PLL will be changing frequency periodically and
by using this method I am hoping to maintain a constant phase and duty
relationship between my 2 outputs independent of the PLL frequency.
The code, as written, works correctly if I single-step through the
process (by attaching a toggle switch to the high-speed clock input). As
the frequency of the input clock increases,however, I am noticing that
the 2 outputs are unreliable. For example, at higher frequencies (>150
MHZ) and certain duty cycles, the process will stop generating the clock
completely (constant 1) or it might generate spurious signals in the
middle of the clock (random 1s and 0s - instead of 1 for the first half
of the duty cycle and 0 for the second half.
If anybody has any suggestions or ideas I would be interested in
learning how to solve this problem.
Thanks,
Moderator (Company: Titel) #5701619
Greg W. wrote:
> For example, at higher frequencies (>150 MHZ)
By using the falling and the rising edge of the 150MHz clock you
effectively double the FPGA clock to 300MHz. And that's fairly
demanding...
Did you set (at least) a clock constraint?
What does the synthesizer/toolchain say about the fmax of the design?
BTW:
When trying to do high speed designs it is much better to think
"binary": do not use 36 steps, rather use 32 or 64 steps, then you can
use a simple wrap around for the counter instead of comparing and
resetting it.
OP (Company: Flashgate Technology) #5702322
Lothar,
Thanks for your response.
I previously tried combining the two loops to generate the EX and DM
outputs on the rising_edge of a single process. The result is similar.
I've added a BUF on the two outputs and this seems to have improved the
performance but I still have occasional glitches at higher frequencies.
Interestingly, the results differ depending on the load (even with a
BUF.) For example, the EX output is routed directly to an output on the
chip and feeds into a circuit to drive an oscillator. If I monitor the
EX signal at the input to the oscillator, the output clock has a glitch
(at certain frequencies and duty cycles.) I then routed the same signal
to a test pin (with the oscillator routing still connected) and the
output is different (even though I am using the same frequency as the
previous test.) I've sent a note to Microsemi (it's their FPGA that
we're using) to see if they have any ideas (perhaps different
buffering.)
With regards to your comment about using a 32 or 64 wrap-around, I agree
that it would be a more efficient implementation. Unfortunately, I can't
use 32 as a multiple as 32x my target frequency is outside of the upper
limit for the PLL for our FPGA (and I'd prefer not to go to 16 because
I'm trying to get as much resolution as I can for phase and duty
control.)
Thanks,
Greg
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
