FIFO MEMORY VHDL
OP #5685104
Hello. I have to do a project which will be a simulator of 16 bit FIFO
memory in VHDL. I need to add values to my memory and later put it on
7-segment display, but I don't even know how to deal with it. Can you
give me some advice how can I do this project? I know these things:
* I need read flag on slider
* I need write flag on slider
* I need input logic_vector 15 downto 0 and pin it to sliders
* I need output logic_vector 15 downto 0 and then via component push it
to display (not sure here)
* clk on button for example to send my value to memory
I don't know how I can store my data in "memory" and I'm bad in
understand components. I'm not sure how to write it "not structural" I
mean I want write it in multiple files not only in one file, but I have
problems with send component from file to my top entity
Moderator (Company: Titel) #5685252
This obviously is some kind of homework. Your teacher wants you to do
something and learn by doing that. We should not override this
intention. So let's try it this way: you start with something and we
help you on particular questions.
First you will need a VHDL module with the mentioned ports. In that
module you will need a array to store the incoming data. And you will
need two pointers, one for the write position and one for the read
position. This module will also need a clock to handle the pointers.
Additionally you will need a VHDL module to handle the button and one
VHDL module to handle the display.
BTW: it would be very neat to have a flag showing that there's data
stored in the fifo at all. Otherwise you could read the fifo without
having written data in it...
OP #5685270
It's project for end the semester. I'm trying to do it alone, but I have
some problems and no time to go to the teacher for resolve that
problems, because I'm working in the middle of week. I did in other
files connected 2 7-segments displays. That was the easiest part of
project. In another file I did entity which tries store data, but I
can't find how to write my vector to variable and then change it again
for bytes. Unfortunately, I don't have FPGA to test my project. Now I'm
trying do these pointers, but if I have pointers must I save my last
positions? I will think how to do it, but it help me a bit. Still I
can't connect these files. I mean everything works not connected like
another projects, because I have problem with add it to top entity in my
main project.
Guest #5685289
In your Top-Level File you put a Component Part in the Architecture
Section.
ARCHITECTURE bdf_type OF Block_toplevel IS
  component quad is
     port(
      clk     : in  std_logic;
      reset_n   : in  std_logic;
      quadA   : in  std_logic;
      quadB   : in  std_logic;
      count   : out std_logic_vector(23 downto 0)
  end component;
BEGIN
  -- Panasonic Rotary-Encoder
  quad1 : quad
  PORT MAP
    clk    => hw_clk,
    reset_n    => hw_reset,
    -- quadA  => Q1_debouced,
    -- quadB  => Q2_debouced,
    quadA    => Q1,
    quadB    => Q2,
    -- count   => s_quad1_out
    count     => s_addr_i
30
31
32
33
34
END bdf_type;
left-side is the Entity Part, right side are signals or connections to
yout Hardware
Moderator (Company: Titel) #5685471
first the whole thing must run properly in simulation. And be happy:
because the buffer is so small (only 16 words) you will be able to use
distributed RAM instead of invoking a RAM block.
> Now I'm trying do these pointers, but if I have pointers must I save my
> last positions?
Have a lok at this:
http://www.lothar-miller.de/s9y/archives/21-FIFO.html
Its German, but when you (try to) understand the (faily simple and
straight forward) code, then you will get the trick.
Patryk S. wrote:
> * clk on button
Usually a very, very bad idea. This will only work when you have a
properly debounced button...
Marek wrote:
> The File with the "Quad" Part schould be also in your Project.
Wrong thread? I cannot see any need for a rotary encoder here.
Guest #5685926
Ich dachte er hat Probleme die Komponenten zu verbinden.
Oder habe ich was falsch verstanden?
mfg
Moderator (Company: Titel) #5686017
Pls. write in English.
Keep in mind EmbDev.net is the English spoken part of
https://www.mikrocontroller.net/
Patryk S. wrote:
> Still I can't connect these files.
You have problems with the instantiation of one or multiple components
in a VHDL module?
If so, then read on, otherwise skip to the next post... ;-)
Its the very same like instantiating a module into a test bench (eg.
like the decoder in the test bench ther in the
https://embdev.net/topic/465973#5685466)
Afterwards you will have to connect those modules with internal signals.
There I'm taking a DDFS module and a PWM module and connect them
together to generate a sine modulated PWM output:
http://www.lothar-miller.de/s9y/archives/57-Sinusausgabe-mit-PWM.html
Its German, but I'm sure you will get the trick...
OP #5686541
You help me so much. I understand a bit deutch so I hadn't problem with
that code. I resolve most of my problems. Now I have one problem with
simulator. I use altera modelsim and I don't know how to set manualy
without code specified value. For example I have input A and B and now I
want set on A 0 and on B 1. How can I do it without write it in code?
EDIT: Ohh okay. I realize how to do it. I can force it. This video help
me do it. (https://www.youtube.com/watch?v=W9rANBbhbSo) Most difficult
part of coding it for me is change my 1 big file to many small others. I
changed 2 of my 10 components, but I lost for it a couple hours. I don't
understand signals in my code. That testbench. I saw that testbench. Can
I join it outside my project? I tried, but I didn't knew how to pin it
properly
Moderator (Company: Titel) #5686739
Don't know that tool. But I never ever did something with that "forcing"
in a simulator, because simulation is not a real-time story. So there is
no need for a "button" to force signals to a certain value.
A test bench simply should invoke the possible usual input stimuli to a
module, and then it should add some "errouneous" input states to check
how the module handles problems and recovers from them. And because its
best to have alwas the very same timing throughout test, its best to
write it in a file to have the very same conditions throughout
development.
> That testbench. I saw that testbench. Can I join it outside my project?
A test bench is a stimlui file that is not inside the final hardware
files. It is solely for simulation and invokes the "module under test"
as a component.
So in HDL development you have 2 "projects":
1. the one that will be synthesized and implemented on on real hardware
and
2. that one for simulation. It is a test bench which includes one or
more of the modules from the 1. project. You also can have multiple test
benches e.g. each one for the each sub module (debouncer, encoder,
decoder, somewhatelse...) and also maybe one "big" test bench for the
top level module of the design.
OP #5689868
Still I have problem with components. How Can I pin it? I will send
example for my top entity and component which I want to use
Library IEEE;
USE IEEE.Std_logic_1164.all;
use IEEE.NUMERIC_STD.ALL;
entity fifo_memory is
  port (
    data_in: in std_logic_vector(memory_architecture-1 downto 0); -- data input. Value which will be put into our memory
    read_flag: in std_logic; -- read flag
    write_flag: in std_logic; -- write flag
    clk: in std_logic; -- not sure to use
    action_button: in std_logic; -- master button
    data_out: out std_logic_vector(memory_architecture-1 downto 0) -- data output. Value which will be throw by our memory. This one will be converted to our 7-seg display
end fifo_memory;
architecture Behavioral of fifo_memory is
  --code
  signal f_led_out : std_logic_vector(6 downto 0);
  component bcd_flag is
    port (
      f_led_out: out std_logic_vector(6 downto 0)
  end component;
  begin
  bcd_flag_component: bcd_flag PORT MAP(
    f_led_out => f_led_out
30
31
32
--code
33
34
  flagBCD: process(read_flag, write_flag)
35
    begin
36
    if (read_flag='1' and write_flag='0') then
37
      f_led_out <= "1001111"; -- I
38
    end if;
39
    if (read_flag='0' and write_flag='1') then
40
      f_led_out <= "0000001"; -- O
41
    end if;
42
    if (read_flag='1' and write_flag='1') then
43
      f_led_out <= "0110000"; -- E
44
    end if;
45
  end process flagBCD;
46
47
end Behavioral;
Error (12006): Node instance "bcd_flag_component" instantiates undefined entity "bcd_flag". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
I have problem with this error. I surrender with push it to multpile
files and I try do it in one, but I can't pin new components
OP #5689879
I understood error and even I tried to do it in some ways, but I don't
know how to use component in component. I don't know how to include this
module. I want to have some variables as component and from other
component push it to this component. I tried to do it in a new file, but
I don't know how to do it. Once I ran my program properly, but I
couldn't simulate my program and I had warning design connected with
this f_led_out in the console
EDIT: I appreciate some help. I fight with this last 2 days :(
EDIT2: I might say nosense, but I want send data from my
component/entity called fifo_memory to my component bcd_flag. Something
like it's written in code. I cut everything what I thought isn't needed
here. I'm trying cut everything from fifo_memory to another components,
coz I wanted to do it on multiple files or even in one file, but with
component. It's required in project
OP #5702470
I have last question. How Can I add std_vector to std_vector? I want do
something like this
    d_units <= std_logic_vector((d_value mod 10));
    d_tens <= std_logic_vector(((d_value / 10) mod 10));
I create it as std_logic_vector, but I can't assign math operations
Moderator (Company: Titel) #5703724
A std_logic_vector is just a bunch of bits, so it is not a good idea to
perform on it. Does it represent a signed or is it unsigned or even a
float number? How should the synthesizer know?
You could use the old-fashioned std_logic_arith package to do so, but
much better is to use the numeric_std package and to cast the
std_logic_vector to a defined unsigned or signed data type:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
> (d_value mod 10)
A division in hardware is a fairly demanding task. Much more when its
done in pure logic as you want the synthesizer to do here. What are
those two results  needed for?
(Company: www.dossmatik.de) #5704024
It looks like a Hex to dec converter.
This need a division unit. It is not possible to calculate this in on
clock cycle or only with an assign.
Moderator (Company: Titel) #5704045
René D. wrote:
> It is not possible to calculate this in on clock cycle or only with an
> assign.
Depends on the toolchain...  ;-)
See Beitrag "Re: Rechnen mit unsigned vs. signed und einer division"
(its German, but maybe Google translates it).
But indeed such a combinatorial divider needs a big bunch of logic gates
and it is slow.
A binary to BCD converter can be done like this:
http://www.lothar-miller.de/s9y/archives/67-Vektor-nach-BCD-kombinatorisch.html
Or this:
http://www.lothar-miller.de/s9y/archives/34-Vektor-nach-BCD.html
Or much better like this:
http://www.lothar-miller.de/s9y/archives/84-Binaer-nach-BCD-mit-1-Takt-pro-Stelle.html
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
