hello !, I have a small problem with this code, I have 4 parallel inputs coming from the FPGA switches. what I try to do is something similar to a shift register, an FPGA button will simulate a clock signal, when I press it for the first time, the data that enters parallel must make a shift, example (if you enter "0101", when pressing the button the first time a bit must be sent to the left, that is to say "1010", when it is pressed for the second time "0101" and so on). For this I used ROL, but I do not know how to do the increments of the ROL, I tried to use a beat counter of the clock button but it gives me the following error: Line 31. Variable 'cnt' cnt is at left hand side of signal assignment statement. Use 4 LEDs to see the Original input (RD_out) and other 4 LEDs (RD_out2) to see the ROLE in the data. Thank you in advance for your help, Best regards!
Wilson T. wrote: > an FPGA button will simulate a clock signal Hopefully it's debounced! > For this I used ROL, but I do not know how to do the increments What's the hardware you are describing with this VH-Description-L code? Do you have a sketch of that hardware on paper? Or at least a picture of that hardware in mind? Or do you try to "program" and use some kind of VH-Programming-Language? A PISO usually has only 1 serial output. And this could be selected with your counter and a multiplexer: Ser_out<=Serie(cnt); But be aware that cnt runs out of the borders of that array very fast. You must reset cnt to 0 when it reaches the top border of the array. EDIT: Assignments to variables are done with := I suppose to use signals. All together I would do it much like this way by adding an output which is high at the first bit of the serial protcol:
1 | library IEEE; |
2 | use IEEE.STD_LOGIC_1164.ALL; |
3 | use IEEE.NUMERIC_STD.ALL; |
4 | |
5 | entity convertparal_serie is |
6 | |
7 | port (inDCBA: in std_logic_vector (3 downto 0); -- 4 inputs |
8 | reloj: in std_logic; -- some kind of clock |
9 | outSER: out std_logic; -- serial output |
10 | bit0: out std_logic); -- marker for first bit |
11 | |
12 | end convertparalelo_serie; |
13 | |
14 | architecture Behavioral of convertparal_serie is |
15 | |
16 | signal cnt: integer := 0; |
17 | |
18 | begin
19 | |
20 | -- cycling counter from 0 to 3
21 | process (reloj) begin |
22 | if reloj'event and reloj='1' then |
23 | if cnt=3 then cnt <= 0 |
24 | else cnt <= cnt + 1; |
25 | end if; |
26 | end if; |
27 | end process; |
28 | |
29 | -- multiplex the parallel inputs to the serial output
30 | outSER <= inDCBA(cnt); |
31 | |
32 | -- signal the outer component that bit 0 is transmitted
33 | bit0 <= '1' when cnt=0 else '0'; |
34 | |
35 | end Behavioral; |
