Forum: FPGA, VHDL & Verilog PSEUDORANDOM NUMBER GENERATOR AND HAMMING CODE DISPLAY ON LED Test Bench
von Ed H. (howerj)
The  purpose  of  this  project  is  to generate pseudorandom  numbers
and  display  corresponding hamming code on LED’s present on Spartan3E
FPGA board. Use X^4 + X + 1 linear feedback shift register  (LFSR)  as
pseudorandom  generator  circuit.  The  four  D-Flip  Flops  used  in
LFSR  circuit output 4 -bit output values at 1 Hz in the free running
mode. The issue I am running into is creating the test bench for the top
file. Any help would be much appreciated!
Ed H. wrote:
Please attach your source code as a *.vhd or *.vhdl file. Its extremely
difficult to edit a heap of pixels...
> The issue I am running into is creating the test bench for the top file.
Show what test bench you have created so far and ask a specific problem
about that.
A hint: a VHDL test bench is a entity without ports.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity tb_top is
                                   -- empty entity --> testbench
end tb_top;
architecture behavior of tb_top is
   component top
   port( clk : IN  std_logic;
   end component;
   signal clk : std_logic := '0';  -- local signals
begin
   uut: top                        -- wire the unit under test
   port map ( clk => clk,
   clk <= not clk after 10 ns;     -- generate clock
end;
BTW: why the heck don't your vectors have an element 0? All of them
range from somthing "downto 1". That's kind of unusual...
von Ed H. (howerj)
So something like this?
Yeah something alike...
And what do you get out of design when you run it on this test bench?
One thing:
   uut: top port map (
     clk => clk,
     sw1=> '1',
     sw2=> '1',
     sw3=> '1'
Why don't you use your local signals you defined a few lines above that?
Let your port map look this way:
   uut: top port map (
     clk => clk,
     sw1 => sw1,
     sw2 => sw2,
     sw3 => sw3
And ahead of that you can work with initial values:
   signal sw1 : std_logic := '1';
   signal sw2 : std_logic := '1';
   signal sw3 : std_logic := '1';
von Duke Scarring (Guest)
I prefer the prefix 'tb_' for testbench signals.
So I know everytime if the signal is inside or outside the dut.
   signal tb_sw1 : std_logic := '1';
   signal tb_sw2 : std_logic := '1';
   signal tb_sw3 : std_logic := '1';
   uut: top port map (
     clk => tb_clk,
     sw1 => tb_sw1,
     sw2 => tb_sw2,
     sw3 => tb_sw3
Duke
And of course the output port of the component should be connected to
a local signal, too...
