Asynchronous 4 Bit Up Counter using D-Flipflops
Guest #5216714
• ▲ useful
▼ not useful
Hey,
i am kinda stuck since 2 hours, i can't find anything related in the
web. so i decided to ask you guys. may be i can get some hints for my
problem.
first of all. i want to implement a 4 Bit Up Counter using only D
Flipflop with an asynchronous reset. my problem is i dont know hot to
"initilize" the flip flops since i get "not initialized" when i use iSim
in VHDL.
i am only allowed to use AND/NAND gates and the D Flipflop should work
with a falling edge.
D Flipflop: https://imgur.com/maADKt2
Asynchronous 4-Bit UP Counter: https://imgur.com/g83g5SF
i am very grateful for any help, i am stuck with my ideas right now.
PS: The D Flipflop has to work with only the CLK, D, Q and nQ. The reset
is for the 4 BIT Counter!
Moderator (Company: Titel) #5216733
• ▲ useful
▼ not useful
Simply attach your VHDL file(s) here without invoking screenshots on
more or less dubious file-sharing portals. Then it's easy to show you
the solution...
I thought you must implement that counter using those flipflops...
However:  when it's an asynchronous reset, then it must go to flipflops.
If it's a synchronous reset then it can go to the combinatorial network
between the flipflops.
> my problem is i dont know hot to "initilize" the flip flops since i get
> "not initialized" when i use iSim in VHDL.
Try that in the entity's port declaration
q : out := '0';
qn : out := '1';
Guest #5216780
• ▲ useful
▼ not useful
Thank your for your reply.
> the solution...
Okay, done.
Yeah that counter has to be build with those flipflops.
So basically i use my reset input and wire it to all clk's of the
flipflops?
> q : out := '0';
> qn : out := '1';
Thank you i did that, but i did that with the 'd' too. So i got some
results right now. I am looking if the results are right.
  • [vhdl]VHDL-Code[/vhdl]
