DAC interface on spartan 3E
Guest #5140520
Look for a working SPI-Core and use it.
Check the spi protocol with the datasheet of your SPI-DAC. Use
simulation and compare the waveform of the simulator with that in your
datasheet
Does your spi-clk toggle? I guess not. And also check the direction of
the port.
Guest #5140614
Thank you for your response.
my spi_sck is working proper. And I also check for SPI but I don't find
any problem with it.I am beginner. if possible,can you explain in detail
Guest #5141343
OK, I missed the toggling by "XOR 1'. See it seems to toggle. But i
assume its not using a IOB-Flipflop. Have you set any constraint?
Otherwise is likely that the sck takes some ns longer to propagate to
the pin. Try post place&route simulation or use a scop and check spi set
and hold times in respect to sck.
https://forums.xilinx.com/t5/Embedded-Development-Tools/Post-Place-and-Route-simulation-with-MicroBlaze/td-p/356313
Guest #5141798
You are right it is about constrain, I try to solve it but not working.
it is gives below warnings. can you tell me how to remove that warnings?
WARNING:Xst:1293 - FF/Latch <dacsend_8> has a constant value of 0 in
block <DAC>. This FF/Latch will be trimmed during the optimization
process.
WARNING:Xst:1293 - FF/Latch <dacsend_7> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacsend_6> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacsend_2> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacsend_1> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacsend_0> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_32> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_31> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_30> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_29> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_28> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_27> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_26> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_25> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_24> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_23> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_13> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_12> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_11> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_7> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_6> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_5> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_4> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_3> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_2> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_1> has a constant value of 0 in
process.
WARNING:Xst:1293 - FF/Latch <dacdata_0> has a constant value of 0 in
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
process.
Guest #5155974
The warnings are just telling you that your signal "dacsend" is always
set to all zeros. You never put any other value in there so you have a
signal stuck at one value.
This is usually not what you want and that is why you are getting a
warning.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
