Problem synthesizing in Vivado
OP (Company: Relevant Technologies Ltd) #4921281
Hi there
I am a bit of a VHDL newbie, so please excuse this. I am using the
following code to attempt to read an array of up to 12288 bits
transmitted via AXI4 stream in 32 but chunks, I am using the TUSER
channel to receive the number of useful bits transmitted in the
accompanying DWORD, which can vary according to the convolution code in
use (each dword is a convolution coded byte, containing usually between
9 and 32 bits, but can also contain between 1 and 32 padding bits).
I am building a COFDM transmitter, and the block I am working on handles
frequency interleaving, the nature of which means I need access to a
complete symbol's worth of bits before transmission. The transmit side
synthesizes fine, but the code which is causing problems is on the
receive side - it takes an age to synthesize, several hours, to be more
precise. The system is flexible, and configuration information is loaded
by the controlling ARM core into AXI lite slave registers.
Here's the code that appears to be causing the trouble: If I comment it
the code synthesizes in good time.
            rx_bits := to_integer(unsigned(axis_in_tuser));
            for i in 1 to 32 loop
              bit_buffer(rx_bit_buf_ptr) <= axis_in_tdata(i-1);
              rx_bit_buf_ptr := rx_bit_buf_ptr + 1;
              if i = rx_bits then
                exit;
              end if;
            end loop;
Am I doing something silly? bit_buffer has length 2 * 12288 - 1 to
facilitate the reception of a symbol during the transmission of another.
I am running Vivado 2015.4 on a Quad-core Skylake Xeon laptop with 48G
of DDR4 and a 1TB SSD, so processing speed should be respectable.
I have attached the complete code for the block. Please note it has yet
to be physically debugged. I have dispensed with the files generated for
the master and slave AXI4 stream data ports, handling these in the top
level with clock and reset ports shared between all interfaces. Some
signals and definitions may be redundant, or provided solely for
eventual debugging purposes.
Best regards
Geoff
Moderator (Company: Titel) #4921311
Thank God that he gave us CTRL-C and CTRL-V!
> bit_buffer has length 2 * 12288 - 1 to facilitate the reception of a
When I look at the whole design I can give only one hint: pack your big
register set in a DPRAM. At the moment you are generating logic to
access each of the bit by some huge, vast multiplexers.
Guest #4921510
Thanks, Lothar, I know what you mean. I have been truly dumb! I come
from a SW background, the mindset is different! Last time I designed
logic it was cute little symbols on bits of graph paper. I guess a sheet
of graph paper capable of covering the greater part of the Pacific ocean
would be needed to implement what I was attempting! Can you give me any
hint how to use DPRAM? Just a hint would do...
Writing this down, I'm pretty sure I understand how to do it! I can use
address translation to achieve any arbitrary scrambling function for the
interleaving, since there is an obvious onto- mapping between input and
output bits, this could be precomputed and also stored in block memory.
The basic requirement is a throughput equal to the clock frequency, so
it would need to be possible to access a word every clock, changing only
the address.
The maximum number of bits encoded in a single carrier is 6 (64-QAM).
Six memory blocks, write interface (port A) 384 x 32 bits, read
interface (port B) 12288 x 1 bit. I write the same (packed) input data
into all six, and read one bit from each into each of six data bits.
This allows for an arbitrary interleaving function, since they are
addressed individually by the output of a further block RAM configured
as lookup table, addressed sequentially by the logic, and programmed
with the interleaving function. These bits are not used directly, but
instead address another block RAM, configured also as a lookup table, 64
x 32 loaded with the real and imaginary parts of the modulation
constellation map. I am warming to this concept! The design boils down
to little more than a memory controller.
The preceding convolution encoder might benefit from the same approach.
The outer interleaver certainly!
Many thanks indeed
Kind regards,
Geoff
Guest #4921972
Lothar, I must restate my thanks, your trigger has completely changed my
way of approaching this kind of problem!
Best wishes
Geoff
OP (Company: Relevant Technologies Ltd) #5053364
The finished OFDM frequency interleaver/modulator, under test.
The purpose is to construct OFDM symbols, modulated and
frequency-interleaved, suitable for iFFT transformation into baseband I
and Q signals. Input data is copied into six memory blocks
simultaneously. In run mode, the carrier index is used to address six
address-mapping BRAMs, which, for the purpose of interleaving in the
frequancy domain, select arbitrary input bits from which an output word
of up to six bits is constructed. This is then used to address a
modulation BRAM which is loaded with the constellation map which outputs
the I and Q values of the desired modulation function in a format
compatible with the proprietry Xilinx FFT block. The buffer memory is
loaded in x32, and output x1. It is split to enable simultaneous
reception and transmission of input, and interleaved, modulated, output
data.
The controller implements an administrative mode in which all BRAMS are
writeable (of course) and readable, hence the multiple buses passing
through the controller. In normal operation these are routed directly
from input to output.
In principle, this can handle pretty much any configuration imaginable,
although I claim no kudos for economy. It has a throughput equal to
system clock frequency, and is arbitrarily stallable at both ends. The
output logic is configurable to accept arbitrary series-connected lookup
BRAMS, in this case, with primitive output registers enabled, the
latency (programmable) in this case being six cycles.
It works very nicely, many thanks! It is part of a much larger project,
most of which is simple. However, I now have to make a viterbi decoder
capable of sustaining system throughput.
Best regards
Geoff
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
