Forum: FPGA, VHDL & Verilog 8 bit full adder issue (i'm newbie in vhdl)
von Marco (pastaman71)
i was following my teacher lecture  and i copied his code. His compiler
didn't gave any warning or error, but when i try to compile it with my
PC, it turns out some warning about non-bounded components. I tryied to
use also std_logic instead of bit, but nothing (idk i tryied it all).
I'm starting hating vhdl and i don't know what i have to do. Do you guys
have any idea?
Thank you all in advance
: Edited by User
Not all of it. The entity for component cfa is missing. Maybe its your
job to write it.
> Do you guys have any idea?
Start on your own with a simple counter.
Wrong order.
But however, its simple to cure: learn it. And be sure: Verilog won't be
any better.
: Edited by Moderator
> job to write it.
Thank you for the answer. May i ask some more? What i thought was that
my entity "addern" was like a black box where inside the are 8 full
adder that i declared with "component".
Are you telling me that i have to create an entity for the single full
adder and from that use the component to make the 8-bit F-A?
Briefly, i have to make a F-A?
Thank you
You need code for 1 component cfa because this missing component cfa is
used n times in the adder_n entity.
Simply search for cfa in the posted code and do a little bit
brainstorming on the search results.
OMG i made the entity cfa ( literally the logical function of a full
adder) and now it works !!! Thank you a lot my saviour!!
I also upload the code if someone need it some day.
SOLVED
Marco wrote:
> now it works !!!
You see: VHDL isn't that horrible. For me its simply straight forward...
> Thank you a lot
You're welcome.
