Forum: FPGA, VHDL & Verilog Synchronizing reset signal used as a combinational logic
Author: Robert (Guest)
I want to synchronize this combinational logic used as a reset signal. I
tried adding registers (flipflops) to remove the glitches. But it does
not seem to work. Is there any other solution? (See attached image)
Robert wrote:
> But it does not seem to work.
How do you see that?
What do you expect and what do you get instead?
For what problem?
BTW: how many clocks are in your design? If its a number greater than 1,
then we know what the problem is...
I get a Critical Warning : Combinational Logic Used as a Reset Signal
Should be Synchronized
PLL generates a 50MHz Clock which is the system clock. But there are few
generated clocks. This module uses a 150MHz Clock
> Combinational Logic Used as a Reset Signal Should be Synchronized
The synthesizer is right.
Never ever use asynchronous combinatorial resets.
If you do that in a counter with e.g. 16 flipflops, then the next glitch
in that combinatorial path will reset 3..12 (or any random number
between 0 and 16) of those flipflops. That will be dependent on supply
volatage and temperature and it will give you some surprising effects.
And even a FSM is only a little bit more complex counter...
> But there are few generated clocks.
A beginners design must have only 1 clock. All the rest is done by
clock enable signals.
Read the last sentence of this school exercise:
https://embdev.net/topic/394849#4539869
Having only 1 clock will help you getting a reproduceable synchronous
design.
: Edited by Moderator
  • [vhdl]VHDL code[/vhdl]
