Forum: FPGA, VHDL & Verilog State Machine for SPI Master/Slave Interface
Author: Nayan Patel (nay)
Dear all,
I am trying to write a state machine that checks to see if correct data
is being received on the SPI link by lighting an LED.
I have written a code but I am not sure if I am writing the state
machine correctly, it definitely does not compile.
Here is the code that I have written in relation to the test bench,
please find the file attached.
library IEEE; -- Reference for VHDL source code
use IEEE.STD_LOGIC_1164.all; -- Package defined in the IEEE (Found in library IEEE)
-- Entity declaration
entity spi_statemachine is
   generic (n: positive := 16; -- Number of bits
  port (-- Master --
      di_m: in std_logic_vector(15 downto 0);
      wren_m: in std_logic;
      -- Slave --
      do_s: out std_logic_vector(15 downto 0);
      do_valid_s: out std_logic;
      -- Clock operation --
      rst_i: in std_logic;
      clk_i: in std_logic;
      -- Output detection --
      correct: out std_logic);
end spi_statemachine;
-- Architecture behaviour
architecture detect of spi_statemachine is
type state_type is (createData, writeData, delay, writeEnable,
              checkValid, receivedData, checkFinished);  -- Enumeration type
signal state: state_type;
begin
  P1: process (clk_i, rst_i) -- Clock and reset
  variable dataLength: integer := n; -- Length of data
  variable count: integer := 1;
  begin
    if rst_i = '0' then -- Reset operation used initialize all signals to predetermined state
      state <= createData;
    elsif clk_i'event and clk_i = '1' then  -- Signal attribute used to test for a change on a signal
      case state is
        when createData =>
            state <= writeData;
          else
          end if;
        when writeData =>
            di_m <= std_logic_vector(to_unsigned(dataLength,n)); -- Write data
            state <= delay;
        when delay =>
            count := count + 1;
          if (count > 1) then
            state <= writeEnable;
          count := 0;
          else
            state <= delay;
          end if;
        when writeEnable =>
          wren_m <= '1';
          state <= checkValid;
        when checkValid =>
          wren_m <= '0';
          state <= receivedData;
        when receivedData =>
          if do_s = di_m then
            state <= checkFinished;
          end if;
        when checkFinished =>
          correct <= '1';
        when others => null;
      end case;
    end if;
  end process;
end detect;
Any kind of help will be appreciated.
Kind regards,
Nay
Author: ruusel (Guest)
Hi nayan,
you have a lot of mistakes in your syntax. Check your brackets and be
sure that every if has its else end endif aso...
ruusel wrote:
> Hi nayan,
Thank you for the reply.
How do I declare an output from the slave component to the code that I
am writing above?
Kind regards,
Nayan
> am writing above?
What slave?
But you get no warnings or error messages?
So the waveform picture is what your code should do after being
completed? Where's the testbench for that waveform?
Lothar Miller wrote:
>> am writing above?
> What slave?
I am using a master block to send data to the slave block and the state
machine block will check to see if the correct data is received.
I get the following error message:
Error (10482): VHDL error at spi_statemachine.vhd(70): object "do_o" is used but not declared
I am trying to assign the output 'do_o' of the slave block to the input
'di_m' of my state machine block.
Please find the file of the test bench attached.
Kind regards,
Nayan
This here could be cut down several lines:
-- Clock generator (50% duty cycle)
  -- Master clock --
  -- Serial clock --
  clk_process_serial: process        -- Identifying the process
  begin                        -- Begin process
       sclk_i <= '0';              -- Serial clock signal is '0'.
       wait for clk_period/2;          -- Serial clock signal is '0' for 5ns
       sclk_i <= '1';              -- Serial click signal is '1'
       wait for clk_period/2;          -- Serial clock signal is '1' after 10ns
  end process clk_process_serial;      -- End process
  -- Parallel clock --
  clk_process_parallel: process        -- Identifying the process
       pclk_i <= '0';              -- Slave clock signal is '0'.
       wait for clk_period/2;          -- Slave clock signal is '0' for 5ns
       pclk_i <= '1';              -- Slave clock signal is '1'
       wait for clk_period/2;          -- Slave clock signal is '1' after 10ns
  end process clk_process_parallel;    -- End process
  -- Slave clock --
    clk_process_slave: process        -- Identifying the process
  end process clk_process_slave;      -- End process
Just by this here:
  clk_i  <= not clk_i after clk_period/2;
  sclk_i <= clk_i;
  pclk_i <= clk_i;
I cannot find do_o in any of the VHDL code you provided. Is it hidden
somewhere else?
And of course, this here won't work at all:
          if do_s = di_m then    -- it is not allowed to read an output port!
In VHDL a output cannot be read.
> somewhere else?
The output 'do_o' is read from the slave block, please find the file of
the master block and slave block attached.
Kind regards,
Nayan
And where is the file with the line of code causing the errror:
Heck, it is so exhausting to worm every small bit of information out of
someone...  :-/
> someone...  :-/
Apologies for the confusion, please find state machine file attached.
I have also attached the wrapper (Top-level entity) for the 'spi_master'
and 'spi_slave' cores, to synthesize the 2 cores and test them in the
simulator.
Kind regards,
Nayan
  • [vhdl]VHDL code[/vhdl]
