Forum: FPGA, VHDL & Verilog RAM not working as needed in spartan 3
Author: vhdl newbie (Company: none) (pranoy)
hi guys,
       i've used this code as a ram block in Spartan 3. But it was not
working.
i checked the RTL view of the file, but in that the RAM block have 2
pins unassigned(ENA and RSTA).
is that the problem why this is not working?
also the RAM created is a dual port RAM. I need only a single port RAM.
please help.
thanks in advance.
1 useful
vhdl newbie wrote:
>         data_o <= "ZZZZZZZZ";
This is not possible inside a FPGA. There are no tristate lines in
FPGAs anymore.
Where did you take it from? Did you check out the templates Xilinx
delivers with the ISE? And did you check the XST User Guide? In there
you can find how to describe a RAM so that the synthesizer can recognize
it correctly...
Author: alex (Guest)
do you test it?
no --> testbench.
i would generate a bram with the core genarator from xilinx and check
the function.
  • [vhdl]VHDL code[/vhdl]
