Hi! I have a problem to creat ALU function with 4bit full adder/sub like A-B , A xor B ,itc, . ALU is defined with A,B(inputs 4bit) then K selected input (2bit) and R output 4bit 4bit full adder/sub is defined with M,N inputs 4bit,S,COUT output 4bit, SO in selected but hi is 1bit!!! And I have problem to connect K with SO because K is 2bit and SO is 1bit!!! I dont know how to connect this signals? I attached files AND I KNOW HOW TO DO LATER FUCTIONS A XOR B A-B A . WITH CASE but i don t know to connect signals K and SO
The main possibility starts with a third entity which instantiates alu and accu but contains also "signals". (Please read your script about it).
I don't unterstand the full-adders? Why can't you use the simple + operation, which adds numbers in VHDL?
I'm so sorry! I uploaded wrong four_alu.vhd file :). Now is four_bit_alu file. Can I use the port map for connceting signals(or if you want, inputs and outputs and select in) between alu and four bit adder/sub? And,again, how to connect SO with K which is 2bit (K(0),K(1))? Thanks
> four_bit_alu.txt > I uploaded wrong four_alu.vhd file :) You did so. MY vhdl files extension is *.vhd or *.vhdl, but never *.txt > I have problem to connect K with SO because K is 2bit and SO is 1bit!!! > I dont know how to connect this signals? Indeed you don't! What function has S0? What function has K? Why at all sholuld you ever need to connect them? Draw a schematic of your structure first. And then write vhdl code that does the wiring as you have scetched in your schematic. PittyJ wrote: > Why can't you use the simple + operation, which adds numbers in VHDL? I see a lot of such low level structural vhdl code form schools around the world. And everybody has to build a kind of adder out of single gates. But indeed its a stupid task, because the synthesis tool CAN handle such easy arithmetic operations itself. And i don't see, why ANYBODY must do such a "scetching-down-an-adder-on-paper-and-transfer-it-to-a-netlist" job.
>I see a lot of such low level structural vhdl code form schools around >the world. And everybody has to build a kind of adder out of single >gates. But indeed its a stupid task, because the synthesis tool CAN >handle such easy arithmetic operations itself. And i don't see, why >ANYBODY must do such a >"scetching-down-an-adder-on-paper-and-transfer-it-to-a-netlist" job. So true! You start in VHDL, read a book and see that adders are build from scratch, instead of a simple "+". You think to yourself: There has to be a reason! Later in the job you still find professionals instanciating Adder cores.
I have to creat ALU function like +,- ,itc with 4-bit adder sub . So, I have to connect ALU with 4-bit adder sub ,then i have problem with signal K which is 2bit and hi is selected input of alu and i have S signal of 4bit adder sub which is also selected input but 1bit. I must connect them because i don t have another way to connect this 2 components. DO YOU UNDERSTAND NOW?
Your shift key seems to be stuck. You should get a new keyboard.
u muzt contact the i/os form the ALU to the signels in ur modul, so u creat S, K itc too corisponding signels in ur modul with fittings bits widths. than inrupts mite works to.
