Forum: FPGA, VHDL & Verilog Serial_Converter
Author: anjali komalapati (Company: iqi labs) (anjali)
Hi can any 1 plz help me,
 My task is to convert the parallel data into serial of 32 bit i have
written the code it gt implemented but in test bench iam founding some
errors please verify it and suggest me please.
       When the load is high the data should get stored or loaded into
the register and when it is low it should get shifted. This is the topic
which i have done.
  please help me out of this, thanks in advance.
> i am founding some errors
Some secret errors?
If the errrors are not secret, then pls. tell WHICH ones!
I just modified little bit and again a error like,
# ** Error:
D:/Anjali/Data_Simulator/27th_June/Serial_Convertertb/Serial_Convertertb
.vhd(31):  near "USE": expecting '[' or '(' or '.' or '''
so where and how to modify this and iam attachin the file which is
modified too.
Author: kfalser (Guest)
The error message gives you
- line number (31)
- error description
What do you expect more?
ya but even when modifying its not clearing that is what i need how to
rectify it
Author: Hermann-Josef (Guest)
I think there is a ';' missing at the end of this line:
USE ieee.std_logic_1164.std_logic_vector
Cheers
And the most simple solution will be to delete that line, because in the
previous line .ALL is included...
USE ieee.std_logic_1164.ALL;
if i delete that line getting 3 errors like
# ** Error:
.vhd(91):  No feasible entries for infix operator "+".
# ** Error:
.vhd(91):  Type error resolving infix expression "+" as type
ieee.std_logic_1164.std_logic_vector.
# ** Error:
.vhd(96):  near "=": syntax error
then what to do
Take any vhdl book and read the first few pages....
However: this simple message means that the simulator does not know, how
to add a integer to a std_logic_vector. Tell it to him by adding the
old fashioned and obsolete IEEE.std_logic_unsigned.all. In that package
the desired unsigend addition is defined...
What about looking, how others are doing such things?
Google is a very recommended place for such error messages:
http://www.google.com/search?q=No+feasible+entries...
BTW:
USE IEEE.std_logic_arith.all;
USE ieee.numeric_std.ALL;
Use these old obsolete Libs:
 IEEE.std_logic_unsigned.all;
Or this new and fresh one:
But NEVER EVER all of them TOGETHER!
that is cleared but 1 error is coming but which is a syntax error even i
did many changes its not resolving
 # ** Error:
i resolved it , thank u soo much for your posts i resolved the errors
now it got simulated thanks alot
  • [vhdl]VHDL code[/vhdl]
