http_get from ulrich radig
OP #1807149
• ▲ useful
▼ not useful
I want to use uli's project to send temperature values to a mysql
database.
I've created a php file that insert var's into the db. i.e.
insert.php?Mainboard_Sensors_Id=c81e728d9d4c2f636f067f89cc14862c&Mainboard_Sensors_Log_Temperature=131
i tried to integrate this into uli's code. when i start the webserver it
does a request to my webserver. I verified this by using wireshark. but
the problem; it isnt working, yet. i do see packet retransmissions. i
searched for a while and found other topics with the same problems.
does someone have this code working or maybe have an other solution to
put data into a remote sql db? i'm looking for a 'real time put'
solution so a bash script getting the data from the atmega is not what
i'm looking for.
Guest #1807582
• ▲ useful
▼ not useful
Hello,
the problem is at Uli's data recive routine.
void test (unsigned char index)
  for (int a = TCP_DATA_START_VAR;a < TCP_DATA_END_VAR;a++)
    HTTPC_DEBUG("%c",eth_buffer[a]);
  tcp_entry[index].time = TCP_TIME_OFF;
  tcp_entry[index].status = ACK_FLAG;
  create_new_tcp_packet(0,index);
if your webserver close the connection (FIN) at same time with sending
last data packet - uli's code send only an ACK and not an FIN/ACK
thereby the connection is not close.
To test use the follow code, but i used in my webserver an ASM code
        if(tcp_entry[index].status & FIN_FLAG) {
                http_get_state=20;
                return;
Sascha
OP #1808315
• ▲ useful
▼ not useful
Hi Sascha,
i tried the code but without any luck.
i captured again with wireshark and i see:
1 - atmega send syn to webserver
2 - webserver send syn/ack back to atmega
3 - and again: webserver send syn/ack back to atmega ??
4 - then i get 6 retrainsmissions from the atmega to the webserver with
http GET requests.
5 - webserver send syn/ack back to atmega
6 - 3 times, atmega send psh and ack with http data (GET)
7 - atmega sends rst, ack to webserver
end.
what to do?
Guest #1809530
• ▲ useful
▼ not useful
Hello,
I testet some code, see attachement ...
changes outside of http_get, code based on version 1.2.5 from ulli:
>main.c
at startup called   httpg_init()
>cmd.c / cmd.h
add command "get" to start http-download
So the statemachine works but implement is not perfect (catch out
errors).
A problem remains - after connection closed most stacks wait sometimes
at new packets with same portnumber. If you within 1-2 mins, running a
new download the connection hang. To avoid this you must change port at
each connection.
Into my server implement this. In example:
> Start download
* get an random portnumber
* add_tcp_app with this portnumber
* running download
* after connection closed kill_tcp_app with selected portnumber
here a link with something information about my server:
Beitrag "Re: Zeigt her Eure Kunstwerke !"
Sascha
OP #1810175
• ▲ useful
▼ not useful
Hi Sascha,
Thanks for your code. I'm trying but i get a little confused.
in your main.c you still got:
        #if GET_WEATHER
        http_request ();
        #endif
but in your cmd.c you are doing a request to command_httpG which
requests run_http_request(); which requests
void run_http_request (void)
  if (http_get_state==-1)
    http_get_state=0;
  } else {
    HTTPC_DEBUG("ERROR - HTTP Request BUSY\n\r");
without any call to other functions?
when only calling http_request(); in the main.c doesnt work,
http_get_state is at start -1 ?
do i need to add http_request in the run_http_request function ?
and replace http_request(); in main.c to run_http_request(); ?
OP #1810189
• ▲ useful
▼ not useful
I changed the code to this:
    http_get_state=0;
    http_request();
  } else {
result:
get
HTTP Request
TCP Eintrag gefunden (HTTP_CLIENT)!
Ready
Daten Anfordern
wireshark:
atmega > webserver : SYN
webserver > atmega RST, ACK
i think handshake is going wrong?
btw, i've got 2 subnets in my lan, local lan and wlan
local lan = atmega 192.168.x.x, webserver = wlan 192.168.y.x
#1810462
• ▲ useful
▼ not useful
Sj Sj wrote:
> Hi Sascha,
>         #if GET_WEATHER
>         http_request ();
>         #endif
this code i dont changed, its runs http_get statemachine simultaneously
into main loop
>     http_get_state=0;
>   } else {
yes it's ok, the http_request() check var http_get_state at every
calling from main loop. At reset or if request complete the state is -1,
that says the http_request() its nothing to do.
have you set GET_WEATHER to 1 in config.h?
yes, so its wait to run with GET command
no
no
Sascha
#1810625
• ▲ useful
▼ not useful
hello,
i download your archive, changed ipaddresses and clockspeed, then
programed to my server.
At serial console type "get" - and it works fine
I see that you changed the IP-Address for download but not changed
GET-String?!
you written that used different subnet's, can test at configuration at
same subnet?
Sascha
OP #1811260
• ▲ useful
▼ not useful
Ok found some new information.
i did install a new webserver on an other pc. lets call this one pc2.
the setup is still in the same subnet.
i've attached 2 wireshark captures. on of pc 2 (new
http_get_test-working-pc2-1145090810.cap) and one of pc1 (old
http_get_test-failure-pc1-1155090810.cap)
PC2 situation:
i booted atmega and typed get. as you can see in wireshark its working!
line 1 to 10.
then i tried again and it failure, as you said line 11..14
PC1:
i booted atmega and typed get. as you can see in wireshark line 3 is
strange, any idea? think this is the problem? but why, its the same code
working with pc1 :/
OP #1811442
• ▲ useful
▼ not useful
ok, shameful, the http services on pc1 was crashed :|
it's working
i read about tcp/ip handshaking and close connections.
i'm not sure but if i understand your story it is normal that tcp/ip
ends with a time_wait state at the server side?
This means that the webserver did get a FIN from the mega to determinate
the tcp/ip connection. it sends back to the mega a ACK packet and a FIN.
then it get a ACK back from the mega.
after this procedure the webserver port goes into TIME-WAIT and timed
out after 2 mins << this is what you mean by waiting 2 mins before retry
to setup a connection..? why its waiting 2 minutes, if the mega sends
back the LAST ack then the connection can be closed, right? why wait 2
minutes or is this part of code missing? i cant find it back in the
wireshark captures
beside the atmega project, does every application use this procedure?
what if an application wants to send traffic again? it count the
LOCAL_HTTP_PORT++ ? and setup a connection again?
is there a simple way to detect failures ? duplicate acks, no remote
port is open, any other failures.. ? if so, what would be a simple way
to handle this?
#1811639
• ▲ useful
▼ not useful
good
it is normal? i dont know but i see at ViewTCP also at other connections
sometimes
in file "http_get_test-working-pc2-1145090810.cap"
webserver send FIN in packet 7, ATmega answer with a ACK (8) and a
FIN,ACK (9), webserver sends ACK (10)
i can not see an error at this sequence, if i compare with other traffic
the same sequence are used
> wireshark captures
at TIME-WAIT state or later no more packets exchanged
you can see the state with TCPView http://tcpview.softonic.de/
the http_get is the reversed function of a http server - in the server
project is not needed, but at ulis stack (or my project) is used to show
some infomation (from web) on display
for example http connections can request more than one files with same
connection
>it count the LOCAL_HTTP_PORT++ ? and setup a connection again?
yes this works, but you must kill the last http_get_app from application
stack before changed port. an "kill_tcp_app" function you must implement
in stack because yet not available.
increment PORT is a good way but limit the portrange e.g. 2200 to 2400
if you look at browser traffic then see - each connection used a new
portnumber
> to handle this?
oh - detect failures at tcp are very difficult but wireshark helps
Sascha
OP #1811732
• ▲ useful
▼ not useful
Thanks again,
i found some code in sendmail.c starting at 241
if mail can't be send it count++ a higher port.
i tried the code below ant it seems to be working, can you verify the
code?
 Copyright:      Radig Ulrich  mailto: mail@ulrichradig.de
 Author:         Radig Ulrich
 Remarks:
 known Problems: none
 Version:        12.11.2007
 Description:    HTTP-Client (empfang einer Webseite)
 Dieses Programm ist freie Software. Sie können es unter den Bedingungen der
 GNU General Public License, wie von der Free Software Foundation veröffentlicht,
 weitergeben und/oder modifizieren, entweder gemäß Version 2 der Lizenz oder
 (nach Ihrer Option) jeder späteren Version.
 Die Veröffentlichung dieses Programms erfolgt in der Hoffnung,
 daß es Ihnen von Nutzen sein wird, aber OHNE IRGENDEINE GARANTIE,
 sogar ohne die implizite Garantie der MARKTREIFE oder der VERWENDBARKEIT
 FÜR EINEN BESTIMMTEN ZWECK. Details finden Sie in der GNU General Public License.
 Sie sollten eine Kopie der GNU General Public License zusammen mit diesem
 Programm erhalten haben.
 Falls nicht, schreiben Sie an die Free Software Foundation,
 Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307, USA.
#include "config.h"
#include "http_get.h"
#include <avr/io.h>
#include <avr/pgmspace.h>
#include "stack.h"
#include "usart.h"
30
#include "timer.h"
31
32
//PROGMEM char WEATHER_GET_STRING[] = {"GET /koch.htm HTTP/1.1\r\n"
33
PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Mainboard_Sensors_Id=c81e728d9d4c2f636f067f89cc14862c&Mainboard_Sensors_Log_Temperature=13 HTTP/1.1\r\n"
34
                                     //"GET / HTTP/1.1\r\n"
35
                                     "Host: www.webservicex.net\r\n"
36
                                     //"Host: www.ulrichradig.de\r\n"
37
                                     "Connection: close\r\n\r\n"};
38
39
volatile unsigned int http_get_state = -1;
40
unsigned int my_http_cp = LOCAL_HTTP_PORT;
41
42
43
//HTTP_GET INIT
44
void httpg_init (void)
45
46
        ////unsigned int my_http_cp = LOCAL_HTTP_PORT;
47
        add_tcp_app (my_http_cp, (void(*)(unsigned char))test);
48
49
50
//Abfrage starten
51
52
53
54
55
    http_get_state=0;
56
  } else {
57
58
59
60
61
//Daten kommen von einem Webserver an!!
62
63
64
65
66
67
68
69
70
71
        http_get_state=-1;
72
    HTTPC_DEBUG("HTTP Request - EOF\n\r");
73
    //tcp_Port_close(index);
74
75
    else ////changed to else
76
77
78
79
80
81
82
83
//HTTP Request an einen Webserver stelle
84
void http_request (void)
85
86
    unsigned long index = MAX_TCP_ENTRY;
87
88
    if (http_get_state > 1 && http_get_state < 20) http_get_state++;
89
90
    if (http_get_state == 0)
91
92
93
        //offnet eine Verbindung zu meinem Webserver
94
        HTTPC_DEBUG("HTTP Request\n\r");
95
96
97
  /*new code*/
98
    unsigned int my_httpget_cp_new = my_http_cp + time;
99
    if (my_httpget_cp_new < 1000) my_httpget_cp_new +=1000;
100
101
    change_port_tcp_app (my_http_cp, my_httpget_cp_new);
102
    my_http_cp = my_httpget_cp_new;
103
104
  /*eo new code*/
105
106
107
108
109
        //ARP Request senden
110
        if(arp_request (WEATHER_SERVER_IP))
111
112
            for(unsigned long a=0;a<2000000;a++){asm("nop");};
113
114
            tcp_port_open (WEATHER_SERVER_IP,HTONS(80),HTONS(my_http_cp));
115
116
            unsigned char tmp_counter = 0;
117
            while((index >= MAX_ARP_ENTRY) && (tcp_entry[index].app_status != 1))
118
119
                index = tcp_entry_search (WEATHER_SERVER_IP,HTONS(80));
120
                if (tmp_counter++ > 30)
121
122
                    HTTPC_DEBUG("TCP Eintrag nicht gefunden (HTTP_CLIENT)!\r\n");
123
124
                    return;
125
126
127
128
            HTTPC_DEBUG("TCP Eintrag gefunden (HTTP_CLIENT)!\r\n");
129
            tcp_entry[index].first_ack = 1;
130
            http_get_state = 2;
131
132
        else
133
134
135
136
137
138
    //if (http_get_state == 10)
139
    if (http_get_state > 10 && http_get_state < 20)
140
141
        HTTPC_DEBUG("\r\n\r\n\r\nDaten Anfordern\r\n");
142
143
        memcpy_P(&eth_buffer[TCP_DATA_START],WEATHER_GET_STRING,(sizeof(WEATHER_GET_STRING)-1));
144
        tcp_entry[index].status =  ACK_FLAG | PSH_FLAG;
145
        create_new_tcp_packet((sizeof(WEATHER_GET_STRING)-1),index);
146
    http_get_state=21;
147
148
i changed:
define global:
added the else statement, else when FIN the connection you get an extra ACK, the extra ACK is not needed i think?
        http_get_state=-1;
removed //unsigned int my_http_cp = LOCAL_HTTP_PORT;    using global one, think else it points to other registers when using it?? my atmega crashes when i use it.. ;P
and added /*new code*/ part
  /*new code*/
  /*eo new code*/
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
                    return;
48
49
50
51
52
53
            http_get_state = 2;
54
55
        else
56
57
58
59
60
61
62
63
64
65
66
67
68
69
    http_get_state=21;
70
71
#1811853
• ▲ useful
▼ not useful
        http_get_state=-1;
/\ send's a ACK packet for each incomming packet, the FIN/ACK packet
following send by the stack.c if FIN is stated in recived packet.
the portchange function is an good idea too, but calculation with time
is not necessary.
  /*new code*/
    unsigned int my_httpget_cp_new = my_http_cp + 1;
    if (my_httpget_cp_new > (LOCAL_HTTP_PORT+300)) my_httpget_cp_new = LOCAL_HTTP_PORT;
  /*eo new code*/
Sascha
OP #1811869
• ▲ useful
▼ not useful
hm, i dont understand what you mean. can you try it again?
now i can send data via GET method, i dont know if this is a good way to
send over data. i was thinking something about soap but i think this
would be overkill ?
the main goal is getting data into mysql, any other suggestion to send
over data? think creating a client would be to difficult
#1811905
• ▲ useful
▼ not useful
with your change (else branch) ACK only send in packets without FIN-flag
> send over data.
> would be overkill ?
yes i thinking too, if the exchange with GET enough for your application
the soap-protokoll dont bring a advantage
if you can use a cronjob at webserver, it can request data from atmega -
your data put into the file which sends from atmega
Sascha
OP #1812151
• ▲ useful
▼ not useful
I'm not sure about the else.
if i remove the else i get one ack to much in wireshark, i.e. i THINK i
see one to much.
but,
if i look to the code, after every received packet in function:
there's an ack send
maybe this ack is send to much and not the one in the test function.
perhaps it is by chance?
if i look at sendmail.c there is no ack send:
//Daten kommen vom EMAIL- Server an!! (Mail wird versendet)
void mail_data (unsigned char index)
    //Verbindung wurde abgebaut!
    if (tcp_entry[index].status & FIN_FLAG)
        return;
#1812989
• ▲ useful
▼ not useful
> see one to much.
i see, after server send's datapacket with FIN atmega send an ACK packet
and an FIN/ACK packet - of principle is enough to send second packet
with FIN/ACK.
see also ...
http://en.wikipedia.org/wiki/Transmission_Control_Protocol#Connection_termination
"It is also possible to terminate the connection by a 3-way handshake,
when host A sends a FIN and host B replies with a FIN & ACK (merely
combines 2 steps into one) and host A replies with an ACK.[13] This is
perhaps the most common method."
<- B can send one packet with FIN&ACK or 2 packets - one with ACK and
one with FIN
i test it to send in second packet only FIN and not FIN/ACK, then
TCPView says FIN_wait2 status.
> but,
this only send with GET request - once per connection
>         return;
see above
Sascha
OP #1813443
• ▲ useful
▼ not useful
Hi again,
I'm trying to mutate http_get.c into a style of sendmail.c, of course
without luck.
if i look to sendmail.c there is no
////tcp_entry[index].first_ack = 1;
in the mail_send() function, so i comment it in the http_get.c (any idea
why this line is used?)
i moved:
    http_get_state=21;
in to the test() function
as result i do get 3 way handshake but then, for a while nothing happen.
after a period of time (32 secs) it sends a 'TCP ACK' protocol packet
thats it.
i guess it would be possible to mutate the code more formally like
sendmail.c but there's something going wrong. can you help me a little?
#1814196
• ▲ useful
▼ not useful
Sj Sj wrote:
> Hi again,
> without luck.
why?
i think that is useless, then in stack.c i found this at
//Server öffnet Port
 ... for outgoing connections, and at
//Empfangene Packet wurde bestätigt keine Daten für Anwendung
//z.B. nach Verbindungsaufbau (SYN-PACKET)
 ... for incomming connections
> i moved:
>     http_get_state=21;
> thats it.
the test() function is only execute if incomming packets recived from
server. If you see at stack.c  "//Server öffnet Port" - there atmega
send's ACK packet for 3 way handshake (step 3), but user application
[test()] is not running
at sendmail there is a little difference:
after opening connenction initiated by atmega, the server sends a packet
first. Thereby the user_appliction [mail_send(void)] is running after
connection opend.
At http_get, you must send the first packet (/GET ...) after connenction
established.
Sascha
OP #1819039
• ▲ useful
▼ not useful
thanks,
i saw it later, but thanks for the confirmation.
i'm trying to create a dynamic GET url but it's PROGMEM.
i tried a few codes but every time the microcontroller reboots
the url:
and i want to create some like:
PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Mainboard_Sensors_Id=%d&Mainboard_Sensors_Log_Temperature=%d HTTP/1.1\r\n"
and where %d = the dynamic value
any suggestions? i tried to use sprintf_P but then the mic crashes and i
need to declare a big char for the url string, but then the advantage
isn't any more i guess.
ok found a solution:
    sprintf(WEATHER_GET_STRING,"GET /temp/insert.php?Mainboard_Sensors_Id=%d&Mainboard_Sensors_Log_Temperature=%d HTTP/1.1\r\n \r\n Connection: close\r\n\r\n", 1,2);
    HTTPC_DEBUG("test: %s\r\n", WEATHER_GET_STRING);
Guest #1836459
• ▲ useful
▼ not useful
Hello Sj Sj,
I got from Sascha a tip that you both spoke about the problem to fetch
web sites with ETH_M32. I have the same problem. Did you fix the
problem?
Can you send me your source of the http_get.c.
Thanks for your support
Markus
Guest #1836707
• ▲ useful
▼ not useful
Hey Sj Sj,
thanks for the answer. I use at the moment the standard Stack 1.2.5 from
Uli. My AVR is a 644P.
I tried your code but I have no look. It doesn't work.
Following situation:
AVR send SYN
WEB SERVER SYN;ACK
AVR sends no ACK, it sends the GET Request
I have to check the code.
Do you have any answer?
br Markus
OP #1836715
• ▲ useful
▼ not useful
hm maybe this part of code stuck, im trying to create a dynamic url but
didnt work yet,
try this:
comment the last PROGMEM line and uncomment the first, think the %d
stucks
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Mainboard_Sensors_Id=c81e728d9d4c2f636f067f89cc14862c&Mainboard_Sensors_Log_Temperature=13 HTTP/1.1\r\n"
PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Mainboard_Sensors_Id=%d&Mainboard_Sensors_Log_Temperature=13 HTTP/1.1\r\n"
comment this sprintf line too.
    HTTPC_DEBUG("%s\r\n", WEATHER_GET_STRING);
    http_get_state=0;
  } else {
try again,
Guest #1836742
• ▲ useful
▼ not useful
I did before. I use this code.
PROGMEM char WEATHER_GET_STRING[] = {"GET /xampp/mypost.php
HTTP/1.1\r\n"
                                     "Host: 10.1.61.188\r\n"
                                     //"Keep-Alive: 300\r\n"
                                     "Connection: Close\r\n\r\n"};
It's a INTRANET with a Apache Server. All ip's you see are in the
private lan.
OP #1837387
• ▲ useful
▼ not useful
aint be sure but i think you dont need to add PROGMEM char
WEATHER_GET_STRING[] = {"GET /xampp/mypost.php HTTP/1.1\r\n"
xampp dir to the url
are you using wireshark to verify the handshake? please upload, you can
filter out the rest of your network traffic
OP #1882333
• ▲ useful
▼ not useful
i've got a working code but it does not working when i'm logging to a
remote lan via vpn.
<lan atmega> <vpn device> internet <vpn device> <webserver>
for local lan test i used a windows webserver, remote its linux.
i dont know why but it seems that the GET sends earlier then an ack is
send:
No.     Time        Source                Destination           Protocol Info
      1 0.000000    192.168.10.99         192.168.20.2          TCP      23794 > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
      2 0.000078    192.168.20.2          192.168.10.99         TCP      http > 23794 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
      3 0.043718    192.168.10.99         192.168.20.2          HTTP     [TCP ACKed lost segment] [TCP Retransmission] GET /temp/insert.php?S1=1&T1=0&S2=2&T2=218&S3=3&T3=0&S4=4&T4=223&Time=14:23:21&Date=2010-10-04 HTTP/1.1 Continuation or non-HTTP traffic
      4 0.043776    192.168.20.2          192.168.10.99         TCP      http > 23794 [RST] Seq=459887518 Win=0 Len=0
      5 0.054712    192.168.10.99         192.168.20.2          TCP      23794 > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
      6 3.399613    192.168.20.2          192.168.10.99         TCP      http > 23794 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
      7 3.399979    192.168.10.99         192.168.20.2          TCP      23794 > http [RST] Seq=1 Win=0 Len=0
any idea why its working on local lan but not via vpn?
when my pc is quite busy and rs232 is 'hanging' sometimes the connection
works, looks like timing / delay issue
#1882546
• ▲ useful
▼ not useful
Hello,
after
you must wait that
tcp_entry[index].app_status == 1
, only then ACK-Packet has been send.
At fast connections at LAN, the looptime in main for calling
http_request brings enough delay to send ACK before http_get_state
achieved a value greater than 10.
Sascha
OP #1882551
• ▲ useful
▼ not useful
hm
at what point do i need to wait?
its already waiting at: ???
#include "config.h"
#include <avr/io.h>
#include <string.h>
#include <stdio.h>
#include "stack.h"
#include "usart.h"
#include "timer.h"
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Mainboard_Sensors_Id_1=%d&Mainboard_Sensors_Log_Temperature_1=%d&Mainboard_Sensors_Id_2=%d&Mainboard_Sensors_Log_Temperature_2=%d&Mainboard_Sensors_Id_3=%d&Mainboard_Sensors_Log_Temperature_3=%d&Mainboard_Sensors_Id_4=%d&Mainboard_Sensors_Log_Temperature_4=%d HTTP/1.1\r\n"
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Id=%d&Temperature=%d&DateTimeGenerated=%s&blaat=1 HTTP/1.1\r\n"
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Temperature1=%d&Temperature2=%d&Temperature3=%d&Temperature4=%d&Time=%s&Date=%s HTTP/1.1\r\n"
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?Sensor1=%s&Temperature1=%d&Sensor2=%s&Temperature2=%d&Sensor3=%s&Temperature3=%d&Sensor4=%s&Temperature4=%d&Time=%s&Date=%s HTTP/1.1\r\n"
//PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?S1=1&T1=0&S2=2&T2=195&S3=3&T3=0&S4=4&T4=223&Time=10:30:53&Date=2010-10-04 HTTP/1.1\r\n"
PROGMEM char WEATHER_GET_STRING[] = {"GET /temp/insert.php?S1=%s&T1=%d&S2=%s&T2=%d&S3=%s&T3=%d&S4=%s&T4=%d&Time=%s&Date=%s HTTP/1.1\r\n"
30
31
32
33
char buffer_string[230]={0};
34
35
36
//HTTP_GET INIT
37
38
39
40
41
42
43
44
45
46
//Abfrage starten
47
//void run_http_request (void)
48
void run_http_request (char *sensor1, int16_t *LM92_CurrentTemp1, char *sensor2, int16_t *LM92_CurrentTemp2, char *sensor3, int16_t *LM92_CurrentTemp3, char *sensor4, int16_t *LM92_CurrentTemp4, char *sql_date, char *sql_time)
49
50
  sprintf_P(buffer_string,WEATHER_GET_STRING,sensor1, *LM92_CurrentTemp1,sensor2, *LM92_CurrentTemp2,sensor3, *LM92_CurrentTemp3,sensor4, *LM92_CurrentTemp4,sql_time,sql_date);
51
52
53
54
55
    http_get_state=0;
56
57
    //usart_write("DataLog: [Sensor: %i] [Temperature: %i] [Time: %s] [Date: %s]\r\n",*sensor_id,*LM92_CurrentTemp,sql_time,sql_date);
58
    //usart_write("DataLog: [Temperature1: %i] [Temperature2: %i] [Temperature3: %i] [Temperature4: %i] [Time: %s] [Date: %s]\r\n",*LM92_CurrentTemp1,*LM92_CurrentTemp2,*LM92_CurrentTemp3,*LM92_CurrentTemp4,sql_time,sql_date);
59
    usart_write("DataLog: sensor: %s %s %s %s [Temperature1: %i] [Temperature2: %i] [Temperature3: %i] [Temperature4: %i] [Time: %s] [Date: %s]\r\n",sensor1, sensor2, sensor3, sensor4, *LM92_CurrentTemp1,*LM92_CurrentTemp2,*LM92_CurrentTemp3,*LM92_CurrentTemp4,sql_time,sql_date);
60
61
    usart_write("HTTP GET URL: %s\r\n",buffer_string);
62
63
64
    HTTPC_DEBUG("buffer: %s\r\n", buffer_string);
65
66
  } else {
67
    //usart_write("DataLog Fail: [Sensor: %i] [Temperature: %i] [Time: %s] [Date: %s]\r\n",*sensor_id,*LM92_CurrentTemp,sql_time,sql_date);
68
    usart_write("DataLog Fail: %s %s %s %s [Temperature1: %i] [Temperature2: %i] [Temperature3: %i] [Temperature4: %i] [Time: %s] [Date: %s]\r\n",sensor1, sensor2, sensor3, sensor4, *LM92_CurrentTemp1,*LM92_CurrentTemp2,*LM92_CurrentTemp3,*LM92_CurrentTemp4,sql_time,sql_date);
69
70
    usart_write("-------\r\n");
71
72
    //savetosd()
73
74
75
76
77
78
79
80
81
char buffer[10]={0};
82
83
84
85
86
87
    if (eth_buffer[a] == '$') //look for #$ string
88
89
      if (eth_buffer[a+1] == '#')
90
91
        if (eth_buffer[a+2] != '1')
92
93
          usart_write("SQL insert failed\r\n",eth_buffer[a+2]);
94
95
96
97
98
99
100
101
102
103
104
105
        http_get_state=-1;
106
107
    usart_write("HTTP Request - EOF\n\r");
108
109
    return;
110
111
    //else ////changed to else
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
                    return;
156
157
158
159
160
161
            http_get_state = 2;
162
163
        else
164
165
166
167
168
169
170
171
172
173
174
        //memcpy_P(&eth_buffer[TCP_DATA_START],WEATHER_GET_STRING,(sizeof(WEATHER_GET_STRING)-1));
175
    memcpy(&eth_buffer[TCP_DATA_START],buffer_string,(sizeof(buffer_string)-1));
176
177
        create_new_tcp_packet((sizeof(buffer_string)-1),index);
178
    http_get_state=21;
179
180
    usart_write("index: %i\r\n", index);
181
182
something like:??
    if (tcp_entry[index].app_status == 1)
      http_get_state=21;
#1882620
• ▲ useful
▼ not useful
... no - while waiting the stack must process incoming pakets
see attachment
to info:
* stackentry found if SYN-Packet has been sent (tcp_entry_search)
* app_status=1 if SYN/ACK has been received and ACK sent
in mainloop it would better that calling 'http_request' only once every
second. Then timeouts are better definable.
Sascha
OP #1882720
• ▲ useful
▼ not useful
ok i build the situation back to my locallan.
i debug tcp_entry[index].app_status == 1 and it never reaches >0
i debugged the stack
i added:
  while (TCP_PORT_TABLE[port_index].port && TCP_PORT_TABLE[port_index].port!=(htons(tcp->TCP_DestPort)))
--->>>>>>>>  usart_write("port index %i\r\n",port_index);
    port_index++;
my German failures, maybe you can translate? :)
ystem Ready
Compiliert am Oct  4 2010 um 19:16:38
Compiliert mit GCC Version 4.3.2
NIC init:My IP: 192.168.1.99
TCP Anwendung wird in Liste eingetragen: Eintrag 0
TCP Anwendung wird in Liste eingetragen: Eintrag 1
TCP Anwendung wird in Liste eingetragen: Eintrag 2
IP   192.168.1.99
MASK 255.255.255.0
GW   192.168.1.1
UDP Anwendung wird in Liste eingetragen: Eintrag 0
ROUTING!
ARP Eintrag nicht gefunden*
port index 0
port index 1
port index 2
TCP Keine Anwendung gefunden!
ARP REPLY EMPFANGEN!
**KEINEN ARP EINTRAG GEFUNDEN**
ARP EINTRAG GEFUNDEN!
ROUTING!
TIME: 18:29:26
30
http\port index 0
31
port index 1
32
port index 2
33
34
http
35
ERROR
36
37
DataLog: sensor: 1 2 3 4 [Temperature1: 0] [Temperature2: 221] [Temperature3: 0] [Temperature4: 231] [Time: 19:29:35] [Date: 2010-10-04]
38
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=221&S3=3&T3=0&S4=4&T4=231&Time=19:29:35&Date=2010-10-04 HTTP/1.1
39
40
Connection: close
41
42
43
buffer: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=221&S3=3&T3=0&S4=4&T4=231&Time=19:29:35&Date=2010-10-04 HTTP/1.1
44
45
Connection: close
46
47
48
HTTP Request
49
TCP Anwendung Port ändern: Eintrag 2
50
MY NETWORK!
51
52
Oeffen eines Ports mit Server
53
TCP Open neuer Eintrag 0
54
TCP SrcPort -23368
55
56
57
port index 0
58
port index 1
59
TCP Entry gefunden 0
60
TCP Port wurde vom Server geöffnet STACK:0
61
TCP SrcPort -23368
62
port index 0
63
port index 1
64
port index 2
65
66
DataLog Fail: 1 2 3 4 [Temperature1: 0] [Temperature2: 221] [Temperature3: 0] [Temperature4: 232] [Time: 19:29:45] [Date: 2010-10-04]
67
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=221&S3=3&T3=0&S4=4&T4=232&Time=19:29:45&Date=2010-10-04 HTTP/1.1
68
69
Connection: close
70
71
72
73
74
DataLog Fail: 1 2 3 4 [Temperature1: 0] [Temperature2: 221] [Temperature3: 0] [Temperature4: 231] [Time: 19:29:55] [Date: 2010-10-04]
75
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=221&S3=3&T3=0&S4=4&T4=231&Time=19:29:55&Date=2010-10-04 HTTP/1.1
76
77
Connection: close
78
79
80
81
82
DataLog Fail: 1 2 3 4 [Temperature1: 0] [Temperature2: 221] [Temperature3: 0] [Temperature4: 231] [Time: 19:30:05] [Date: 2010-10-04]
83
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=221&S3=3&T3=0&S4=4&T4=231&Time=19:30:05&Date=2010-10-04 HTTP/1.1
84
85
Connection: close
OP #1882860
• ▲ useful
▼ not useful
i was guessing about that because when passing
if ((http_get_state > 10 && http_get_state < 20) && (tcp_entry[index].app_status == 1))
    usart_write("tcp_entry[index].app_status2 %i\r\n",tcp_entry[index].app_status);
    http_get_state=21;
i created an extra delay but without luck
        #if GET_WEATHER
    if (!teller)
      http_request ();
      teller = 1000;
        #endif
        teller--;
tcp_entry[index].app_status == 1 and not 0
your code is better but when capturing with wireshark i get three transmissions.
[code]
      1 0.000000    192.168.1.99         192.168.2.2          TCP      46927 > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
      2 0.000068    192.168.2.2          192.168.1.99         TCP      http > 46927 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
      3 0.059202    192.168.1.99         192.168.2.2          TCP      46927 > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
      4 0.113420    192.168.1.99         192.168.2.2          HTTP     GET /temp/insert.php?S1=1&T1=0&S2=2&T2=227&S3=3&T3=0&S4=4&T4=230&Time=20:48:54&Date=2010-10-04 HTTP/1.1 Continuation or non-HTTP traffic
      5 0.113490    192.168.2.2          192.168.1.99         TCP      http > 46927 [ACK] Seq=1 Ack=230 Win=6432 Len=0
      6 0.117004    192.168.2.2          192.168.1.99         HTTP     HTTP/1.1 200 OK  (text/html)
      7 0.117233    192.168.2.2          192.168.1.99         TCP      http > 46927 [FIN, ACK] Seq=201 Ack=230 Win=6432 Len=0
      8 0.159392    192.168.1.99         192.168.2.2          HTTP     [TCP Retransmission] GET /temp/insert.php?S1=1&T1=0&S2=2&T2=227&S3=3&T3=0&S4=4&T4=230&Time=20:48:54&Date=2010-10-04 HTTP/1.1 Continuation or non-HTTP traffic
      9 0.159453    192.168.2.2          192.168.1.99         TCP      [TCP Dup ACK 7#1] http > 46927 [ACK] Seq=202 Ack=230 Win=6432 Len=0
     10 0.173377    192.168.1.99         192.168.2.2          TCP      [TCP Dup ACK 8#1] 46927 > http [ACK] Seq=230 Ack=1 Win=1100 Len=0
     11 0.250335    192.168.1.99         192.168.2.2          TCP      46927 > http [ACK] Seq=230 Ack=201 Win=1100 Len=0
     12 0.268817    192.168.1.99         192.168.2.2          TCP      46927 > http [FIN, ACK] Seq=230 Ack=202 Win=1100 Len=0
     13 0.268867    192.168.2.2          192.168.1.99         TCP      http > 46927 [ACK] Seq=202 Ack=231 Win=6432 Len=0
OP #1882969
• ▲ useful
▼ not useful
i tested without vpn and still the same
i changed:
"            if ((tcp_entry[index].app_status == 1) && (http_get_state < 20))
its working under windows.
when i'm using the vpn > linux i get an extra ack / duplicate ack
instead of windows
windows capture same lan:
    125 30.443885   192.168.1.99         192.168.1.22         TCP      13161 > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
    126 30.443971   192.168.1.22         192.168.1.99         TCP      http > 13161 [SYN, ACK] Seq=0 Ack=1 Win=64900 Len=0 MSS=1460
    127 30.490949   192.168.1.99         192.168.1.22         TCP      13161 > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
    128 30.518474   192.168.1.99         192.168.1.22         HTTP     GET /temp/insert.php?S1=1&T1=0&S2=2&T2=226&S3=3&T3=0&S4=4&T4=229&Time=21:34:18&Date=2010-10-04 HTTP/1.1 Continuation or non-HTTP traffic
    129 30.542955   192.168.1.22         192.168.1.99         HTTP     HTTP/1.1 200 OK  (text/html)
    130 30.543120   192.168.1.22         192.168.1.99         TCP      http > 13161 [FIN, ACK] Seq=305 Ack=230 Win=64671 Len=0
    131 30.654627   192.168.1.99         192.168.1.22         TCP      13161 > http [ACK] Seq=230 Ack=305 Win=1100 Len=0
    132 30.673119   192.168.1.99         192.168.1.22         TCP      13161 > http [FIN, ACK] Seq=230 Ack=306 Win=1100 Len=0
    133 30.673179   192.168.1.22         192.168.1.99         TCP      http > 13161 [ACK] Seq=306 Ack=231 Win=64671 Len=0
linux remote vpn capture:
      1 0.000000    192.168.1.99         192.168.2.2          TCP      50877 > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
      2 0.000104    192.168.2.2          192.168.1.99         TCP      http > 50877 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
      3 0.048717    192.168.1.99         192.168.2.2          TCP      50877 > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
      4 0.081688    192.168.1.99         192.168.2.2          HTTP     GET /temp/insert.php?S1=1&T1=0&S2=2&T2=226&S3=3&T3=0&S4=4&T4=230&Time=21:54:44&Date=2010-10-04 HTTP/1.1 Continuation or non-HTTP traffic
      5 0.081757    192.168.2.2          192.168.1.99         TCP      http > 50877 [ACK] Seq=1 Ack=230 Win=6432 Len=0
      6 0.085280    192.168.2.2          192.168.1.99         HTTP     HTTP/1.1 200 OK  (text/html)
      7 0.085511    192.168.2.2          192.168.1.99         TCP      http > 50877 [FIN, ACK] Seq=201 Ack=230 Win=6432 Len=0
      8 0.124417    192.168.1.99         192.168.2.2          TCP      [TCP Dup ACK 4#1] 50877 > http [ACK] Seq=230 Ack=1 Win=1100 Len=0
      9 0.201862    192.168.1.99         192.168.2.2          TCP      50877 > http [ACK] Seq=230 Ack=201 Win=1100 Len=0
     10 0.219848    192.168.1.99         192.168.2.2          TCP      50877 > http [FIN, ACK] Seq=230 Ack=202 Win=1100 Len=0
     11 0.219891    192.168.2.2          192.168.1.99         TCP      http > 50877 [ACK] Seq=202 Ack=231 Win=6432 Len=0
i tested with a linux machine in my other local lan (routed) and got the
same results as the vpn!!
this is what i see when i connect from a pc > vpn > linux webserver
      1 0.000000    192.168.1.22         192.168.2.2          TCP      tarantella > http [SYN] Seq=0 Win=64512 Len=0 MSS=1350
      2 0.000101    192.168.2.2          192.168.1.22         TCP      http > tarantella [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
      3 0.032238    192.168.1.22         192.168.2.2          TCP      tarantella > http [ACK] Seq=1 Ack=1 Win=64800 Len=0
      4 0.037490    192.168.1.22         192.168.2.2          HTTP     GET /temp/insert.php?S1=1&T1=0&S2=2&T2=225&S3=3&T3=0&S4=4&T4=239&Time=15:50:20&Date=2010-10-04 HTTP/1.1
      5 0.037586    192.168.2.2          192.168.1.22         TCP      http > tarantella [ACK] Seq=1 Ack=464 Win=6432 Len=0
      6 0.076260    192.168.2.2          192.168.1.22         HTTP     HTTP/1.1 200 OK  (text/html)
      7 0.076571    192.168.2.2          192.168.1.22         TCP      http > tarantella [FIN, ACK] Seq=201 Ack=464 Win=6432 Len=0
      8 0.111936    192.168.1.22         192.168.2.2          TCP      tarantella > http [ACK] Seq=464 Ack=202 Win=64600 Len=0
      9 0.123671    192.168.1.22         192.168.2.2          TCP      tarantella > http [FIN, ACK] Seq=464 Ack=202 Win=64600 Len=0
     10 0.123710    192.168.2.2          192.168.1.22         TCP      http > tarantella [ACK] Seq=202 Ack=465 Win=6432 Len=0
#1884056
• ▲ useful
▼ not useful
Hello,
the only different between Windows and Linux ist the extra ACK-Paket in
Frame 5 as answer of GET-Paket. I look at stack.c and tcp_application is
running every ACK-Paket is incoming - also an empty ACK-Paket. From APP
=>void test (unsigned char index) this pakets also replyed with ACK -
its an ACK to much.
Test with return if paket is empty ...
[c]
        http_get_state=-1;
    return;
    if (TCP_DATA_START_VAR == TCP_DATA_END_VAR)
       return;  //no reply for empty pakets
Sascha
OP #1884312
• ▲ useful
▼ not useful
thanks again! its working
but still got a amount of questions,
- why it's replying to an empty ack? why is linux sending this ack and
windows don't?
- why do i need to delay the http_request in main() when using vpn?
- seems to be that sometimes when my pc is busy, rs232 is delayed,
because rs232 delay, tcp packets of the atmega are to late because of
rs232 looping? if its to late then the tcp session broke, any idea how
to fix this?
#1885552
• ▲ useful
▼ not useful
> windows don't?
why? both variants are approved, the stack can send an "only"-ACK-packet
(Linux) or it can combine with reply of data (Win)
you don't need the delay, I said it's better for set timeoutvalues if
the time between two calls is a fixed value
For example you can use the 1 sec timebase from timer.c, add a flag that
check in main to call http_request(), or move the line ...
... from http_request() into timer.c ...
//Timer Interrupt
#if EXTCLOCK==1
  #if defined (__AVR_ATmega644__)
    ISR (TIMER2_COMPA_vect)
  #else
    ISR (TIMER2_COMP_vect)
  #endif
#else
  ISR (TIMER1_COMPA_vect)
#endif
  //tick 1 second
  time++;
    if((stack_watchdog++) > WTT)  //emergency reset of the stack
        RESET();
    eth.timer = 1;
//INSERT
  #if USE_NTP
  ntp_timer--;
  #endif //USE_NTP
  #if USE_DHCP
  if ( dhcp_lease > 0 ) dhcp_lease--;
    if ( gp_timer   > 0 ) gp_timer--;
    #endif //USE_DHCP
> to fix this?
if connection etablished in stack.c is an function 'tcp_timer_call' to
kill stackentry after 3 sec (TCP_MAX_ENTRY_TIME) of inactivity. Before
connection etablished the timeout is realized with counting of
'http_get_state'.
Sascha
OP #1889237
• ▲ useful
▼ not useful
i tested the code and it crashes after a while.
like about > 1 hour logging. with samples of 10 secs, the tcp stack is
crashing, i think.
last count was from sourceport 2345 till 2663 = 318
i debugged the code when testing.
everytime the last GET is going fine. but then it crashed and i dont
know where.
when its working the debug code looks like:
TCP SrcPort 2717
TCP TCP_DestPort 80
TCP-Stack Eintrag gelöscht! STACK:0
DataLog: sensor: 1 2 3 4 [Temperature1: 0] [Temperature2: 202] [Temperature3: 0] [Temperature4: 202] [Time: 20:32:36] [Date: 2010-10-07]
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=202&S3=3&T3=0&S4=4&T4=202&Time=20:32:36&Date=2010-10-07 HTTP/1.1
Connection: close
buffer: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=202&S3=3&T3=0&S4=4&T4=202&Time=20:32:36&Date=2010-10-07 HTTP/1.1
Connection: close
HTTP Request
ROUTING!
TCP SrcPort 2718
TCP TCP_DestPort 80
TCP SrcPort 2718
TCP TCP_DestPort 80
30
31
32
33
Daten Anfordern
34
TCP SrcPort 2718
35
TCP TCP_DestPort 80
36
index: 0
37
38
39
HTTP/1.1 200 OK
40
Date: Fri, 08 Oct 2010 18:22:03 GMT
41
Server: Apache/2.2.3 (CentOS)
42
X-Powered-By: PHP/5.2.10
43
Content-Length: 9
44
Connection: close
45
Content-Type: text/html; charset=UTF-8
46
47
48
49
$#1
50
TCP SrcPort 2718
51
TCP TCP_DestPort 80
52
53
HTTP Request - EOF
54
55
TCP SrcPort 2718
56
TCP TCP_DestPort 80
57
58
59
DataLog: sensor: 1 2 3 4 [Temperature1: 0] [Temperature2: 202] [Temperature3: 0] [Temperature4: 202] [Time: 20:32:46] [Date: 2010-10-07]
60
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=202&S3=3&T3=0&S4=4&T4=202&Time=20:32:46&Date=2010-10-07 HTTP/1.1
61
62
Connection: close
63
64
65
buffer: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=202&S3=3&T3=0&S4=4&T4=202&Time=20:32:46&Date=2010-10-07 HTTP/1.1
66
67
Connection: close
68
69
70
HTTP Request
71
72
ROUTING!
73
74
75
76
TCP SrcPort 2719
77
TCP TCP_DestPort 80
78
79
80
DataLog Fail: 1 2 3 4 [Temperature1: 0] [Temperature2: 202] [Temperature3: 0] [Temperature4: 201] [Time: 20:32:56] [Date: 2010-10-07]
81
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=202&S3=3&T3=0&S4=4&T4=201&Time=20:32:56&Date=2010-10-07 HTTP/1.1
82
83
Connection: close
not even tcp stack debug code so thats why i think it crashes, the tcp
entry list is empty too..
[code]
tcp
ERROR
tcp
00  IP:000.000.000.000  PORT:0000  Time:0000
01  IP:000.000.000.000  PORT:0000  Time:0000
02  IP:000.000.000.000  PORT:0000  Time:0000
03  IP:000.000.000.000  PORT:0000  Time:0000
04  IP:000.000.000.000  PORT:0000  Time:0000
Ready
arp
00  MAC:00.00.00.00.00.00  IP:000.000.000.000  Time:0000
01  MAC:00.10.db.9f.f0.02  IP:192.168.010.001  Time:0099
02  MAC:00.00.00.00.00.00  IP:000.000.000.000  Time:0000
03  MAC:00.00.00.00.00.00  IP:000.000.000.000  Time:0000
04  MAC:00.00.00.00.00.00  IP:000.000.000.000  Time:0000
Ready
[code]
any idea how to futher debug this and if there is a timer that crashes?
after a reboot everything works fine.
#1889455
• ▲ useful
▼ not useful
what crashes?
AVRServer ist complete busy?
No connections at net are acceptet, no serial commands are execute?
Before are moving count of 'http_get_state' it works continuously?
How much you start the transmission - 10s? -> its too often!
TCP-Connection-Timeout is 30s!
If connection is break, after this time the stackentry is killed.
Therefore the requestrate should greater than Timeout!
Sascha
OP #1889583
• ▲ useful
▼ not useful
hi,
i tought it was  crashing but i still can ping the device, telnet to the
device and the webserver http page is working.
[quote]
[/quote]
no
[quote]
[/quote]
temp samples are 10 secs yes. what do you mean by timeout 30 secs? i
start a new tcp session with a different tcp source port.
and if it's to often, why its working for aproxx > 1 hour?
#1890081
• ▲ useful
▼ not useful
Sj Sj wrote:
> hi,
then server not crashed! The error message is "HTTP Request BUSY" ?
you read temps every 10 secs? You send temps also ervery 10 secs?
if tcp-connection is hang stackentry is kill after timeout (30secs), if
you start a new connection - a new stackentry is needed but only place
for 5 entrys at stack.
If you get "HTTP Request BUSY" it says that previous transmission is not
end.
If counting 'http_get_state' each second, a timeout not until 21 secs.
please send your actual timer.c, and http_get.c
Sascha
OP #1890715
• ▲ useful
▼ not useful
yes, error message is ERROR - HTTP Request BUSY
every 10 secs is a temperature sample and GET to the remote server. this
delay was small, just for testing.
today i tried to sample/GET every 40 secs. it runs for 4.5 hours then it
quits
with 10 secs it approx 1,10 hour, 40 secs 4,5,  looks proportional.
see attachments
i commented
  //NEW
    //if (http_get_state == 20) //20 or more (if waittime to short) but you must change some values more
      //DEBUG "Error - no answer from server
     // http_get_state = -1;
because this will only bypass the actual problem
#1891976
• ▲ useful
▼ not useful
I changed something ...
new http_get_state's
-1     nothing to do
0      start request; try to open connection
2      tcp-entry at stack successful, SYN-packet sent
       if error at tcp-entry go to state -1
2..6   wait to SYN-ACK receiving [4 secs max]
       if reached 6 go to state -1
10     connection etablished; data sent
10..16 wait for incomming data from server (at each packet reset state
to 11)
       timeout after 5 secs and go to state -1
test it with minimum of 20 secs between requests, and look for last
message before crash (i hope not).
Sascha
OP #1892400
• ▲ useful
▼ not useful
i changed
to:
    if ((tcp_entry[index].app_status == 1)  && (http_get_state < 10))
the mega sends a syn, get syn,ack back but does not response again with
ack
HTTP Request
debug 1
debug 2
debug 3
debug 4
TCP-SYN-Timerout!
HTTP Request
debug 1
debug 2
debug 3
debug 4
LM92_ReadTemperature
DataLog Fail: 1 2 3 4 [Temperature1: 0] [Temperature2: 210] [Temperature3: 0] [Temperature4: 211] [Time: 22:25:52] [Date: 2010-10-11]
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=210&S3=3&T3=0&S4=4&T4=211&Time=22:25:52&Date=2010-10-11 HTTP/1.1
Connection: close
TCP-SYN-Timerout!
HTTP Request
debug 1
debug 2
debug 3
debug 4
30
tcp_entry[index].app_status4 1
31
Connection etablished!
32
33
34
35
Daten Anfordern
36
index: 0
37
tcp
38
00  IP:192.168.002.002  PORT:0080  Time:0028
39
01  IP:192.168.002.002  PORT:0080  Time:0021
40
02  IP:192.168.002.002  PORT:0080  Time:0027
41
42
43
Ready
44
45
TCP-Connection-Timeout!
46
47
the strange thing is, it starts automatic
i comment the http_get_state=0; line and still HTTP Request is running!
    http_get_state=0;
HTTP Request
debug 1
debug 2
debug 3
debug 4
TCP-SYN-Timerout!
HTTP Request
debug 1
debug 2
debug 3
debug 4
OP #1893555
• ▲ useful
▼ not useful
ok found the problem.
at startup
is set in http_get.c but timer.c start http_get_state at 0
timer.c is including the http_get_state from http_get.h because if i
dont include this file i get an error.
System Ready
Compiliert am Oct 12 2010 um 18:48:24
IP   192.168.1.99
MASK 255.255.255.0
GW   192.168.1.1
http_get_state timer = -1
TIME: 17:52:18
HTTP Request
http_get_state timer = 0
debug 1
debug 2
debug 3
debug 4
http_get_state timer = 2
http_get_state timer = 3
http_get_state timer = 4
http_get_state timer = 5
TCP-SYN-Timerout!
HTTP Request
debug 1
debug 2
debug 3
30
debug 4
31
32
33
34
35
36
37
TCP-SYN-Timerout!
38
39
HTTP Request
40
http_get_state is always counting and its the counter from timer.c
    if (http_get_state > 1)
    http_get_state++;
so i think if >1 is not working, or is -1 greater then 1 ? =)
OP #1895091
• ▲ useful
▼ not useful
until now it seems to be working, but i only tested for a few hours.
i split the lm92 (temperature sensor) samples and the http_requests with
different timers.
lm92 polls every 10 secs and http_request 40 secs.
i copied the same code from ntp_timer in main.c
    if (!lm92_timer)
      lm92_timer = LM92_TIMER;
      LM92_ReadTemperature();
      usart_write("LM92_CurrentTemp %i %i %i %i \r\n",LM92_CurrentTemp[0],LM92_CurrentTemp[1],LM92_CurrentTemp[2],LM92_CurrentTemp[3]);
    if (!http_request_timer)
      //usart_write("http_request_timer\r\n");
      http_request_timer = HTTP_GET_TIMER;
      insert_into_db();
the var's are countdown in timer.c the strange thing is, sometimes
lm92_timer is -1 if POST and lm92 samples runs at the same time.
using ! does not seem reliable, i think it would be better to define the
countdown var as
volatile char lm92_timer; (not unsigned)
and then using:
    if (lm92_timer <=0)
what do you think of this solution?
OP #1907868
• ▲ useful
▼ not useful
hi,
I tested for a few days now. i get notice by mail when http_get_state=-1
                    mail_enable = 1;
          sprintf(mail_error,"%s","no TCP");
          return;
        else
      mail_enable = 1;
      sprintf(mail_error,"%s","no arp");
    if (http_get_state==6)
      usart_write("TCP-SYN-Timerout!\r\n");  //no syn-ack within 4 secs (State from 2 to 6)
      mail_enable = 1;
      sprintf(mail_error,"%s","No Syn");
    if (http_get_state==16)
      usart_write("TCP-Connection-Timeout!\r\n");  //no incomming packets within 5 secs (State from 11 to 16)
      mail_enable = 1;
      sprintf(mail_error,"%s","TCP Time");
i still get mails with TCP Time and No Syn messages. i dont know how to
fix, is this normal? can tcp packets dropped that much? sometimes it
goes ok for a while but then it stucks for 30 mins, it fixes itself but
i miss data...
#1907901
• ▲ useful
▼ not useful
i don't know
> i miss data...
packet loss is not an error, but regular single packet loss only.
with which transmission path you tested?
how much send packets?
an delay for 30 mins sees for me as an packet block up at your server to
prevent DOS-Attack?!
Sascha
OP #1908134
• ▲ useful
▼ not useful
ok this is strange,
i bugged better and see that the data is inserted but after a while
every insert(http_get_state) ends with 16. i captured with wireshark and
the packets are ok! looks like when data arrives, http_get_state == 11
till 16 is to short?
      mail_enable = 1;
any suggestions? else i try to change 16 to 20?
        http_get_state=-1;
    return;
after inserting the sql data i see at console HTTP Request - EOF then it
tooks 5 secs before i get the message
so it looks like that the timer.c overwrite's the value -1
#1908667
• ▲ useful
▼ not useful
yes this can be a problem!
solution:
at timer.c only set a flag like 'eth.timer', move the http_get_state
handling from timer.c to http_get.c and process if flag is set and reset
flag following.
timer.c
http_get_timer=1
http_get.c
    if (http_get_timer=1) {
       http_get_timer=0
       //code moved from timer.c
//other code from http_request
Sascha
OP #1909615
• ▲ useful
▼ not useful
here's the debug:
HTTP Request
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=175&S3=3&T3=0&S4=4&T4=180&Time=12:25:28&Date=2010-10-24 HTTP/1.1
Connection: close
http_get_state timer sec 0
http_get_state timer sec 2
SQL inserted
HTTP Request - EOF
http_get_state -1
http_get_state timer sec 11
http_get_state timer sec 12
http_get_state timer sec 13
http_get_state timer sec 14
LM92_CurrentTemp 0 175 0 180
http_get_state timer sec 15
http_get_state -1
mail_enable
http_get_state timer sec -1
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
LM92_CurrentTemp 0 175 0 181
54
55
56
57
58
HTTP Request
59
HTTP GET URL: GET /temp/insert.php?S1=1&T1=0&S2=2&T2=175&S3=3&T3=0&S4=4&T4=181&Time=12:26:08&Date=2010-10-24 HTTP/1.1
60
61
Connection: close
62
63
64
65
66
67
68
69
SQL inserted
70
HTTP Request - EOF
71
72
http_get_state -1
73
74
75
76
77
78
79
80
http_get_state -1
81
mail_enable
82
83
84
i dont understand your solution, the variable is already used for other
states so i cant use it for 0/1 (flag)?
OP #1912944
• ▲ useful
▼ not useful
ah,
so every tick in timer.c, the flag is set en http_get_status is counting
up ?
new code:
//usart_write("time: %i\r\n",time);
    //unsigned int my_httpget_cp_new = my_http_cp + time;
    //if (my_httpget_cp_new < 2345) my_httpget_cp_new +=1000;
    if (my_httpget_cp_new == 5000) my_httpget_cp_new =LOCAL_HTTP_PORT;
30
31
32
33
34
35
36
37
38
39
40
                    mail_enable = 1;
41
42
          usart_write("http_get_state %i\n\r",http_get_state);
43
44
          return;
45
46
47
48
49
50
            http_get_state = 2;
51
52
      //usart_write("tcp_entry[index].app_status %i\r\n",tcp_entry[index].app_status);
53
54
        else
55
56
57
      mail_enable = 1;
58
59
60
61
62
63
64
65
66
67
68
69
        HTTPC_DEBUG("tcp_entry[index].app_status4 %i\r\n",tcp_entry[index].app_status);
70
        HTTPC_DEBUG("Connection etablished!\r\n");
71
        //http_get_state = 10;
72
73
74
75
76
        http_get_state=10;
77
        HTTPC_DEBUG("index: %i\r\n", index);
78
79
80
81
    if (http_get_timer==1) {
82
    http_get_timer=0;
83
84
    http_get_state++;
85
86
87
88
89
90
      mail_enable = 1;
91
92
93
94
95
96
97
98
99
100
      mail_enable = 1;
101
102
103
104
105
106
107
with the old code i did get a few problems when i get a tcp syn error,
with new i dont know but i guess its the same.
02  IP:192.168.002.002  PORT:0080  Time:0255
03  IP:192.168.002.002  PORT:0080  Time:0255
even after 10 min's the entry's are still there, any suggestion?
OP #1913008
• ▲ useful
▼ not useful
ok still the same with new code
HTTP Request
HTTP GET URL: GET /temp/insert.php?S1=8b31&T1=0&S2=157b&T2=151&S3=052a&T3=0&S4=b65e&T4=171&Time=21:47:04&Date=2010-10-26 HTTP/1.1
Connection: close
http_get_state timer sec 3
SQL inserted
HTTP Request - EOF
http_get_state -1
LM92_CurrentTemp 0 152 0 172
http_get_state -1
looks like data is still received after syn flag?
#1914101
• ▲ useful
▼ not useful
i look at your debuglog and i belief the problem is at "void test
(unsigned char index)". It's the only position to set state to 11. The
function is running after transmission FIN+ACK and set state to -1
another once if ACK-packet from server received and set state to 11 and
set TCP-Time to 255 (TCP_TIME_OFF) also.
add the follow line ...
//NEW
  if (http_get_state < 10) return;
//ENDNEW
        http_get_state=11;  //reset timeout
30
        http_get_state=-1;
31
32
33
34
    return;
35
36
37
38
    return;
39
40
41
42
43
44
45
46
47
48
...  to break receive before connection opend or after connection
closed.
Sascha
OP #1914121
• ▲ useful
▼ not useful
when adding this line it failures at start
lm92_timer 2, http_request_timer 2
lm92_timer 1, http_request_timer 1
lm92_timer 0, http_request_timer 0
LM92_CurrentTemp 0 161 0 175
HTTP Request
HTTP GET URL: GET /temp/insert.php?S1=8b31&T1=0&S2=157b&T2=161&S3=052a&T3=0&S4=b65e&T4=175&Time=18:48:33&Date=2010-10-27 HTTP/1.1
Connection: close
lm92_timer 9, http_request_timer 39
lm92_timer 8, http_request_timer 38
lm92_timer 7, http_request_timer 37
http_get_state timer sec 4
lm92_timer 6, http_request_timer 36
http_get_state timer sec 5
lm92_timer 5, http_request_timer 35
TCP-SYN-Timerout!
http_get_state -1
mail_enable
Send E-Mail (Sie haben Post ;-)
think because it dont reaches the fin flag anymore
OP #1914157
• ▲ useful
▼ not useful
i captured with wireshark maybe it helps.
it runs fine for x minutes and then it crashes. looks like the mega
can't handle the duplicated syn from the webserver?
    462 1839.979898 192.168.1.99         192.168.2.2          TCP      rprt > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
    463 1839.979970 192.168.2.2          192.168.1.99         TCP      http > rprt [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    464 1843.578899 192.168.2.2          192.168.1.99         TCP      http > rprt [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    465 1844.957153 192.168.1.99         192.168.2.2          TCP      rprt > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
    466 1849.578467 192.168.2.2          192.168.1.99         TCP      http > rprt [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    467 1849.696817 192.168.1.99         192.168.2.2          TCP      [TCP Dup ACK 465#1] rprt > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
    468 1861.576604 192.168.2.2          192.168.1.99         TCP      http > rprt [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    469 1861.679115 192.168.1.99         192.168.2.2          TCP      [TCP Dup ACK 465#2] rprt > http [ACK] Seq=1 Ack=1 Win=1100 Len=0
    470 1879.979129 192.168.1.99         192.168.2.2          TCP      slinterbase > http [SYN] Seq=0 Win=1100 Len=0 MSS=1100
    471 1879.979197 192.168.2.2          192.168.1.99         TCP      http > slinterbase [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    472 1879.998121 192.168.1.99         192.168.2.2          HTTP     GET /temp/insert.php?S1=8b31&T1=0&S2=157b&T2=153&S3=052a&T3=0&S4=b65e&T4=172&Time=22:34:13&Date=2010-10-26 HTTP/1.1 Continuation or non-HTTP traffic
    473 1879.998215 192.168.2.2          192.168.1.99         TCP      http > rprt [ACK] Seq=1 Ack=230 Win=6432 Len=0
    474 1880.006826 192.168.2.2          192.168.1.99         HTTP     HTTP/1.1 200 OK  (text/html)
    475 1880.007024 192.168.2.2          192.168.1.99         TCP      http > rprt [FIN, ACK] Seq=201 Ack=230 Win=6432 Len=0
    476 1883.007089 192.168.2.2          192.168.1.99         HTTP     [TCP Retransmission] HTTP/1.1 200 OK  (text/html)
    477 1883.173055 192.168.2.2          192.168.1.99         TCP      http > slinterbase [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    478 1889.005637 192.168.2.2          192.168.1.99         HTTP     [TCP Retransmission] HTTP/1.1 200 OK  (text/html)
    479 1889.171620 192.168.2.2          192.168.1.99         TCP      http > slinterbase [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    480 1901.003775 192.168.2.2          192.168.1.99         HTTP     [TCP Retransmission] HTTP/1.1 200 OK  (text/html)
    481 1901.169763 192.168.2.2          192.168.1.99         TCP      http > slinterbase [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
    482 1901.170162 192.168.1.99         192.168.2.2          TCP      slinterbase > http [RST] Seq=1 Win=0 Len=0
OP #1914387
• ▲ useful
▼ not useful
it looks like when it failures sequence numbers are zero, the next try
(tcp session) the sequence number is again zero, this cant be?
or can a sequence number be zero again when using a different source
port?
i'm not sure, aint be that good to research...
#1916867
• ▲ useful
▼ not useful
> TCP-SYN-Timerout!
> http_get_state -1
i dont understand - AVR don't get SYN-ACK from server, but the
connection establishment is handled by stack, and the function "test" is
not runnig there.
this capture is recorded without or with added line?
for SYN/ACK at frame 463 avr sends no reply with ACK !? Is it too busy?
Between frame 471 and 472 ACK-packet, which created by stack.c, are
missing!
Yes it's ok - the zero is always the "relativ seq-number" the absolute
number starts always with the value at >stack.c/tcp_port_open<
Sascha
