FPGA development resources
OP Admin #1184200
*CPLD or FPGA?*
The main difference is that CPLDs are smaller than FPGAs, i.e. you can
fit a lot more logic inside a FPGA than inside a CPLD.
* CPLDs: address decoders, bus interfaces, simple memory controllers,
(video) signal generators
* FPGAs: complex CPUs, high speed I/O, signal processing, encryption
*VHDL or Verilog?*
The difference is mainly in syntax, you can get the same synthesis
result with both languages. VHDL is more verbose than Verilog (which can
be an advantage or disadvantage, depending on how you look at it). In
Europe VHDL is much more widely used than Verilog, in the US Verilog
seems to be slightly more popular.
Basic rules for VHDL development
See "http://embdev.net/articles/VHDL":http://embdev.net/articles/VHDL.
Chip vendors
* "Xilinx":http://www.xilinx.com
* "Altera":http://www.altera.com
* "Lattice":http://www.latticesemi.com
* "Actel":http://www.actel.com
Boards
* also see the FPGA vendors' websites
* "Digilent":http://www.digilentinc.com
Tutorials
* TODO
IP Cores
* "Opencores":http://opencores.org - CPUs, USB, Ethernet, encryption,
If you want to suggest any additions to this post, please reply below.
Guest #5286339
i programmed fbga with xp2 lattice chip to switch lvds from ipu and gpu.
The screen resolution of 1440x900 and 1600x900 is good. but 1920x1200
results are bad. I think the data and clk channel n and p output from
the chip is not good. You let me ask how I write code to ensure that clk
and data out are good
(Company: Nazarbayev University) #6216410
I am creating a Youtube playlist for those who are interested to
start/learn/try hardware-software codesign with Xilinx Zynq APSoC
platform. There are already 40 Videos and hoping to add about 100 Videos
from basic to advanced level. Basic background in Verilog and C
programming are assumed. All source code are made available through git
repo.
https://lnkd.in/gnw7Au8
(Company: Home) #6302653
CPLD or FPGA?
>i.e. you can fit a lot more logic inside a FPGA than inside a CPLD.
 Main different CPLD from FPGA that :
CPLD work immidiatly after power up
FPGA after power up need time for load from external or internal flash
memory.
 It's present some application wich need work immidiatly after power up
and can be released only by CPLD.
P.S.
 FPGA can lose it design and stop work after short time power down or
power spike and need it reload.
 CPLD does not have this problem.
 Regards Alex.
Guest #6303792
@Alexander S. you really have no clue of these things!
First, do your homework before stating things.
Cheers :)
(Company: Home) #6303966
 Perhaps Wikipedia have clue of these things :
 The most noticeable difference between a large CPLD and a small FPGA is
the presence of on-chip non-volatile memory in the CPLD, which allows
CPLDs to be used for "boot loader" functions, before handing over
control to other devices not having their own permanent program storage.
A good example is where a CPLD is used to load configuration data for an
FPGA from non-volatile memory.
 https://en.wikipedia.org/wiki/Complex_programmable_logic_device
FPGA loads it from external memory (typically on every power-on)
https://en.wikipedia.org/wiki/Field-programmable_gate_array
(Company: Home) #6303977
> repo.
 Usually I put real ModelSim project which you can start and check
simulation of design and see that design really work.
You don't need to build ModelSim  project and design TestBench file .
ModelSim simulation tools you can download from Altera's site.
 Regards Alex.
A question of your own? This thread is over 17 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
Formatting
  • [c]C-Code[/c]
  • [vhdl]VHDL-Code[/vhdl]
More about formatting
Already registered? Log in
