Encoder Timer switches between 0 and highest value.
OP #7669325
Hello guys,
i want to work with an optical encoder. I only want to use one channel, which i already connected to a timer and configured for the encoder. Now i have a weird problem. When i spin the encoder it only switches between 0 and the highest value. Do any of you have an idea where the problem could be. You probably need more information, im happy to give them to you.
I work with a STM32H745XIHx.
Thank you
#7669332
This is a german-speaking forum. Please post your questions in german, or use embdev.net (the english sister of this forum).
Deiner Anfrage fehlt das naheliegendste:
Dein Quelltext. Ohne den kann niemand Deine Frage beantworten.
#7669338
So you configured the STM Timer for Encoder-Mode, but only one channel is connected. Thats wrong. If you use only one channel eg. for speed measure you have to configure the Timer in capture mode.
Moderator (Company: Titel) #7669348
Harald K. schrieb:
or use embdev.net
I switched the thread over there.
In which way did you do this configuration? What you need is a simple counter that counts events at the pin, but no encoder.
Indeed: show your schematic (as simple it may be) and your code.
OP #7669360
Thank you.
First of all, im doing a project for university, thats why i only have a microcontroller in a "starter kit". So i cant change the connections. For the schematics: The Encoder Cannel A is connected to STmod 3 (PD6) and CN6 4 (PA6). Encoder COM2 is connected to STMod 8 (PI3) and CN7 2 (PF8). The only pin which can function as timer for the encoder is PA6 on TIM3_CH1. Therefore i only can use the one channel encoder. So i put the Timer 3 in combined channels encoder mode and the encode mode in TI1.
And here is my code:
void startEncoder(uint8_t u8iEncoder) {
  if(u8iEncoder == 1) {
    HAL_TIM_Encoder_Start(&htim3,TIM_CHANNEL_1);
uint32_t getEncoder(uint8_t u8iEncoder) {
  uint32_t ui32Counter = 0;
    ui32Counter = __HAL_TIM_GET_COUNTER(&htim3);
  return ui32Counter;
/* USER CODE END 0 */
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim3;
TIM_HandleTypeDef htim5;
TIM_HandleTypeDef htim6;
TIM_HandleTypeDef htim7;
/* TIM2 init function */
void MX_TIM2_Init(void)
  /* USER CODE BEGIN TIM2_Init 0 */
  /* USER CODE END TIM2_Init 0 */
30
31
  TIM_MasterConfigTypeDef sMasterConfig = {0};
32
  TIM_OC_InitTypeDef sConfigOC = {0};
33
34
  /* USER CODE BEGIN TIM2_Init 1 */
35
36
  /* USER CODE END TIM2_Init 1 */
37
  htim2.Instance = TIM2;
38
  htim2.Init.Prescaler = 200;
39
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
40
  htim2.Init.Period = 999;
41
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
42
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
43
  if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
44
45
    Error_Handler();
46
47
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
48
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
49
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
50
51
    Error_Handler();
52
53
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
54
  sConfigOC.Pulse = 0;
55
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
56
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
57
  if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
58
59
    Error_Handler();
60
61
  if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
62
63
    Error_Handler();
64
65
  /* USER CODE BEGIN TIM2_Init 2 */
66
67
  /* USER CODE END TIM2_Init 2 */
68
  HAL_TIM_MspPostInit(&htim2);
69
70
71
/* TIM3 init function */
72
void MX_TIM3_Init(void)
73
74
75
  /* USER CODE BEGIN TIM3_Init 0 */
76
77
  /* USER CODE END TIM3_Init 0 */
78
79
  TIM_Encoder_InitTypeDef sConfig = {0};
80
81
82
  /* USER CODE BEGIN TIM3_Init 1 */
83
84
  /* USER CODE END TIM3_Init 1 */
85
  htim3.Instance = TIM3;
86
  htim3.Init.Prescaler = 0;
87
  htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
88
  htim3.Init.Period = 65535;
89
  htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
90
  htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
91
  sConfig.EncoderMode = TIM_ENCODERMODE_TI1;
92
  sConfig.IC1Polarity = TIM_ICPOLARITY_RISING;
93
  sConfig.IC1Selection = TIM_ICSELECTION_DIRECTTI;
94
  sConfig.IC1Prescaler = TIM_ICPSC_DIV1;
95
  sConfig.IC1Filter = 0;
96
  sConfig.IC2Polarity = TIM_ICPOLARITY_RISING;
97
  sConfig.IC2Selection = TIM_ICSELECTION_DIRECTTI;
98
  sConfig.IC2Prescaler = TIM_ICPSC_DIV1;
99
  sConfig.IC2Filter = 0;
100
  if (HAL_TIM_Encoder_Init(&htim3, &sConfig) != HAL_OK)
101
102
    Error_Handler();
103
104
105
106
  if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
107
108
    Error_Handler();
109
110
  /* USER CODE BEGIN TIM3_Init 2 */
111
112
  /* USER CODE END TIM3_Init 2 */
113
114
115
/* TIM5 init function */
116
void MX_TIM5_Init(void)
117
118
119
  /* USER CODE BEGIN TIM5_Init 0 */
120
121
  /* USER CODE END TIM5_Init 0 */
122
123
124
125
126
  /* USER CODE BEGIN TIM5_Init 1 */
127
128
  /* USER CODE END TIM5_Init 1 */
129
  htim5.Instance = TIM5;
130
  htim5.Init.Prescaler = 200;
131
  htim5.Init.CounterMode = TIM_COUNTERMODE_UP;
132
  htim5.Init.Period = 999;
133
  htim5.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
134
  htim5.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
135
  if (HAL_TIM_PWM_Init(&htim5) != HAL_OK)
136
137
    Error_Handler();
138
139
140
141
  if (HAL_TIMEx_MasterConfigSynchronization(&htim5, &sMasterConfig) != HAL_OK)
142
143
    Error_Handler();
144
145
146
147
148
149
  if (HAL_TIM_PWM_ConfigChannel(&htim5, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
150
151
    Error_Handler();
152
153
  if (HAL_TIM_PWM_ConfigChannel(&htim5, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
154
155
    Error_Handler();
156
157
  /* USER CODE BEGIN TIM5_Init 2 */
158
159
  /* USER CODE END TIM5_Init 2 */
160
  HAL_TIM_MspPostInit(&htim5);
161
162
163
/* TIM6 init function */
164
void MX_TIM6_Init(void)
165
166
167
  /* USER CODE BEGIN TIM6_Init 0 */
168
169
  /* USER CODE END TIM6_Init 0 */
170
171
172
173
  /* USER CODE BEGIN TIM6_Init 1 */
174
175
  /* USER CODE END TIM6_Init 1 */
176
  htim6.Instance = TIM6;
177
  htim6.Init.Prescaler = 200;
178
  htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
179
  htim6.Init.Period = 999;
180
  htim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
181
  if (HAL_TIM_Base_Init(&htim6) != HAL_OK)
182
183
    Error_Handler();
184
185
186
187
  if (HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig) != HAL_OK)
188
189
    Error_Handler();
190
191
  /* USER CODE BEGIN TIM6_Init 2 */
192
193
  /* USER CODE END TIM6_Init 2 */
194
195
196
/* TIM7 init function */
197
void MX_TIM7_Init(void)
198
199
200
  /* USER CODE BEGIN TIM7_Init 0 */
201
202
  /* USER CODE END TIM7_Init 0 */
203
204
205
206
  /* USER CODE BEGIN TIM7_Init 1 */
207
208
  /* USER CODE END TIM7_Init 1 */
209
  htim7.Instance = TIM7;
210
  htim7.Init.Prescaler = 200;
211
  htim7.Init.CounterMode = TIM_COUNTERMODE_UP;
212
  htim7.Init.Period = 999;
213
  htim7.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
214
  if (HAL_TIM_Base_Init(&htim7) != HAL_OK)
215
216
    Error_Handler();
217
218
219
220
  if (HAL_TIMEx_MasterConfigSynchronization(&htim7, &sMasterConfig) != HAL_OK)
221
222
    Error_Handler();
223
224
  /* USER CODE BEGIN TIM7_Init 2 */
225
226
  /* USER CODE END TIM7_Init 2 */
227
228
229
230
void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef* tim_pwmHandle)
231
232
233
  if(tim_pwmHandle->Instance==TIM2)
234
235
  /* USER CODE BEGIN TIM2_MspInit 0 */
236
237
  /* USER CODE END TIM2_MspInit 0 */
238
    /* TIM2 clock enable */
239
    __HAL_RCC_TIM2_CLK_ENABLE();
240
  /* USER CODE BEGIN TIM2_MspInit 1 */
241
242
  /* USER CODE END TIM2_MspInit 1 */
243
244
  else if(tim_pwmHandle->Instance==TIM5)
245
246
  /* USER CODE BEGIN TIM5_MspInit 0 */
247
248
  /* USER CODE END TIM5_MspInit 0 */
249
    /* TIM5 clock enable */
250
    __HAL_RCC_TIM5_CLK_ENABLE();
251
  /* USER CODE BEGIN TIM5_MspInit 1 */
252
253
  /* USER CODE END TIM5_MspInit 1 */
254
255
256
257
void HAL_TIM_Encoder_MspInit(TIM_HandleTypeDef* tim_encoderHandle)
258
259
260
  GPIO_InitTypeDef GPIO_InitStruct = {0};
261
  if(tim_encoderHandle->Instance==TIM3)
262
263
  /* USER CODE BEGIN TIM3_MspInit 0 */
264
265
  /* USER CODE END TIM3_MspInit 0 */
266
    /* TIM3 clock enable */
267
    __HAL_RCC_TIM3_CLK_ENABLE();
268
269
    __HAL_RCC_GPIOB_CLK_ENABLE();
270
    __HAL_RCC_GPIOA_CLK_ENABLE();
271
    /**TIM3 GPIO Configuration
272
    PB5     ------> TIM3_CH2
273
    PA6     ------> TIM3_CH1
274
275
    GPIO_InitStruct.Pin = GPIO_PIN_5;
276
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
277
    GPIO_InitStruct.Pull = GPIO_NOPULL;
278
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
279
    GPIO_InitStruct.Alternate = GPIO_AF2_TIM3;
280
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
281
282
    GPIO_InitStruct.Pin = GPIO_PIN_6;
283
284
285
286
287
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
288
289
  /* USER CODE BEGIN TIM3_MspInit 1 */
290
291
  /* USER CODE END TIM3_MspInit 1 */
292
293
294
295
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* tim_baseHandle)
296
297
298
  if(tim_baseHandle->Instance==TIM6)
299
300
  /* USER CODE BEGIN TIM6_MspInit 0 */
301
302
  /* USER CODE END TIM6_MspInit 0 */
303
    /* TIM6 clock enable */
304
    __HAL_RCC_TIM6_CLK_ENABLE();
305
  /* USER CODE BEGIN TIM6_MspInit 1 */
306
307
  /* USER CODE END TIM6_MspInit 1 */
308
309
  else if(tim_baseHandle->Instance==TIM7)
310
311
  /* USER CODE BEGIN TIM7_MspInit 0 */
312
313
  /* USER CODE END TIM7_MspInit 0 */
314
    /* TIM7 clock enable */
315
    __HAL_RCC_TIM7_CLK_ENABLE();
316
317
    /* TIM7 interrupt Init */
318
    HAL_NVIC_SetPriority(TIM7_IRQn, 14, 0);
319
    HAL_NVIC_EnableIRQ(TIM7_IRQn);
320
  /* USER CODE BEGIN TIM7_MspInit 1 */
321
322
  /* USER CODE END TIM7_MspInit 1 */
323
324
325
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* timHandle)
326
327
328
329
  if(timHandle->Instance==TIM2)
330
331
  /* USER CODE BEGIN TIM2_MspPostInit 0 */
332
333
  /* USER CODE END TIM2_MspPostInit 0 */
334
335
    /**TIM2 GPIO Configuration
336
    PA15 (JTDI)     ------> TIM2_CH1
337
    PA3     ------> TIM2_CH4
338
339
    GPIO_InitStruct.Pin = GPIO_PIN_15|GPIO_PIN_3;
340
341
342
343
    GPIO_InitStruct.Alternate = GPIO_AF1_TIM2;
344
345
346
  /* USER CODE BEGIN TIM2_MspPostInit 1 */
347
348
  /* USER CODE END TIM2_MspPostInit 1 */
349
350
  else if(timHandle->Instance==TIM5)
351
352
  /* USER CODE BEGIN TIM5_MspPostInit 0 */
353
354
  /* USER CODE END TIM5_MspPostInit 0 */
355
356
    __HAL_RCC_GPIOH_CLK_ENABLE();
357
    /**TIM5 GPIO Configuration
358
    PH10     ------> TIM5_CH1
359
    PH12     ------> TIM5_CH3
360
361
    GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_12;
362
363
364
365
    GPIO_InitStruct.Alternate = GPIO_AF2_TIM5;
366
    HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
367
368
  /* USER CODE BEGIN TIM5_MspPostInit 1 */
369
370
  /* USER CODE END TIM5_MspPostInit 1 */
371
372
373
374
375
void HAL_TIM_PWM_MspDeInit(TIM_HandleTypeDef* tim_pwmHandle)
376
377
378
379
380
  /* USER CODE BEGIN TIM2_MspDeInit 0 */
381
382
  /* USER CODE END TIM2_MspDeInit 0 */
383
    /* Peripheral clock disable */
384
    __HAL_RCC_TIM2_CLK_DISABLE();
385
  /* USER CODE BEGIN TIM2_MspDeInit 1 */
386
387
  /* USER CODE END TIM2_MspDeInit 1 */
388
389
390
391
  /* USER CODE BEGIN TIM5_MspDeInit 0 */
392
393
  /* USER CODE END TIM5_MspDeInit 0 */
394
395
    __HAL_RCC_TIM5_CLK_DISABLE();
396
  /* USER CODE BEGIN TIM5_MspDeInit 1 */
397
398
  /* USER CODE END TIM5_MspDeInit 1 */
399
400
401
402
void HAL_TIM_Encoder_MspDeInit(TIM_HandleTypeDef* tim_encoderHandle)
403
404
405
406
407
  /* USER CODE BEGIN TIM3_MspDeInit 0 */
408
409
  /* USER CODE END TIM3_MspDeInit 0 */
410
411
    __HAL_RCC_TIM3_CLK_DISABLE();
412
413
414
415
416
417
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_5);
418
419
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_6);
420
421
  /* USER CODE BEGIN TIM3_MspDeInit 1 */
422
423
  /* USER CODE END TIM3_MspDeInit 1 */
424
425
426
427
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* tim_baseHandle)
428
429
430
431
432
  /* USER CODE BEGIN TIM6_MspDeInit 0 */
433
434
  /* USER CODE END TIM6_MspDeInit 0 */
435
436
    __HAL_RCC_TIM6_CLK_DISABLE();
437
  /* USER CODE BEGIN TIM6_MspDeInit 1 */
438
439
  /* USER CODE END TIM6_MspDeInit 1 */
440
441
442
443
  /* USER CODE BEGIN TIM7_MspDeInit 0 */
444
445
  /* USER CODE END TIM7_MspDeInit 0 */
446
447
    __HAL_RCC_TIM7_CLK_DISABLE();
448
449
    /* TIM7 interrupt Deinit */
450
    HAL_NVIC_DisableIRQ(TIM7_IRQn);
451
  /* USER CODE BEGIN TIM7_MspDeInit 1 */
452
453
  /* USER CODE END TIM7_MspDeInit 1 */
454
455
456
457
/* USER CODE BEGIN 1 */
458
459
/* USER CODE END 1 */
Moderator (Company: Titel) #7669467
Which one? Is there already an encoder on it? If so: which one? If you connected an addidional encoder: wchich one and how?
What is Channel A and what is COM2 of what encoder?
I don't know a thing like a "one channel encoder". What does it mean?
For the schematics
No GND involved in this "schematic" anyhow?
A useful schematic is some kind of graphics with some symbols, names, values and wires on it. With such a schematic one can easily see what parts are intercconnected in what way. This kind of schematic can be understood in almost any langauge and it tells more than thousand words may do...
Pls read and obey the rules above every edit-box:
Post long source code as attachment, not in the text
(Company: IBM) #7682622
Hello, our optical encoder is only toggling between 0 and the highest value when spun. Quick fixes:
Check connections for interference. Verify encoder and timer settings. Ensure stable power supply. Calibrate encoder settings. Inspect for mechanical issues. Apply software filtering. Review documentation for guidance. I hope this will help you. Thank you
A question of your own? This thread is over 2 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
