ch55xduino - CH552 serial print to txd port
OP #7617082
• ▲ useful
▼ not useful
Im working on a CH552 project using ch55xduino IDE with a Development Board: “CH552 Core Board by WeActStudio”
I trying to write a simple text “Hello,World" to an cpu port (31) TXD.
But can not get the code working, can any give me hand with the code
Has anybody used Serial0.println or Serial1.println
USBSerial_print(“Hello,World”); works perfect !
Code:
void setup() { Serial1.begin(9600); while (!Serial1); }
void loop() { Serial1.println("Hello,World"); delay(1000); }
OP #7617420
• ▲ useful
▼ not useful
Hello Thomas,
Thanks for your suggestions, unfortunately I'm still not getting any data out on ant of the ports.
I have tried to connect my serial capture program ( RealTerm ) to any port without result.
When I connect Rx to TX my serial capture program, the capture program echo what I type, so I'm sure the capture program works fine.
I also have no compile error, so looks like CHxxDuino accept:
  • Serial0_println("Hello World");
  • Serial1_println("Hello World");
USBSerial_println("Hello World"); works fine ! using Arduino Serial Monitor.
Any other suggestions ?
void setup() { }
void loop() { Serial0_println("Hello World"); // print to P1.7 Serial1_println("Hello World"); // print to P3.1 USBSerial_println("Hello World"); // print to USB ( Works fine ) delay(100); }
#7617676
• ▲ useful
▼ not useful
I dont use Arduino code on that board, so my knowledge is very limited.
But here is the thing: Output on TX0 or TX1 usually requires to TI =1 (U1TI = 1) in Non Interrupt mode to signal the transmiter is empty. I suppose this is done in Serial0_begin() and Serial1_begin().
void setup() { Serial0_begin(9600); Serial1_begin(9600); }
void loop() { Serial0_println("Hello World0"); // print to P1.7 Serial1_println("Hello World1"); // print to P3.1 USBSerial_println("Hello World"); // print to USB ( Works fine ) delay(100); }
A question of your own? This thread is over 2 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
