help with uart
OP #7582519
Hello,
I am trying to send some data via UART. I have a shift register which stores a value for 24 clk cycles. Meanwhile I want this value to be sent via UART because after that the register will have another value saved into it. Is this even possible? In a picture that I have added it's my simulation. You can see that the value "15" is stored in SR for 24 cycles. How do I send it via UART? Thanks for any help in advance!
`timescale 1ns / 1ps
module flipflop(
    input wire D_1, //vhod prvi ff
    input wire f_clk, //clock
    input wire rst, //reset
    input wire en, //enable
    output reg O //izhod AND vrat
parameter N = 24;
reg [N-1:0] SR = 0, SR_next = 0; //shift register
reg [1:0] SR_2 = 2'b11; //drugi shift register
reg SR_set = 1, SR_en;
reg [N-1:0] Q_4; //shift register izhod
reg Q_1;
reg Q_2;
reg Q_3;
reg Q_3_neg; //negirana vrednost izhoda detektorja
reg [15:0] counter = 0;
reg [15:0] counter_reg = 0;
reg [4:0] shift_counter = 0;
reg [16:0] counter8ciklov = 0;
    always @(posedge f_clk or posedge rst) begin
        if (rst) begin
            Q_1 <= 0;
        end
30
        else if (en) begin
31
            Q_1 <= D_1;
32
        end
33
    end
34
35
36
37
38
39
        if (rst) begin
40
            Q_2 <= 0;
41
            counter <=0;
42
            counter_reg <=0;
43
        end
44
        else if (en) begin
45
            Q_2 <= Q_1;
46
        end
47
    end
48
49
50
51
   always @(posedge f_clk) begin
52
          Q_3 <= Q_2 ;
53
          Q_3_neg <=~Q_3;
54
          O <= Q_2 & ~Q_3;
55
    end
56
57
58
59
60
61
62
    if (O) begin
63
        counter_reg <= counter;
64
        counter <= 0;
65
    end else begin
66
        counter <= counter + 1;
67
    end
68
end
69
70
71
//shift register 1
72
73
74
if ( SR_set )
75
begin
76
SR <= counter_reg;
77
SR_set <= 0;
78
end else begin
79
SR <= SR;
80
end
81
end
82
83
//shift register 2
84
85
86
always @(posedge f_clk)begin
87
if(shift_counter == 4'b0001)begin //DODAJ ŠE && tx_busy !!!!!!!!!!!!
88
SR_en = 1;
89
end
90
if(counter8ciklov == 7)begin
91
SR_en = 0;
92
end
93
end
94
95
always @(SR)begin
96
if(shift_counter == 4'b0000)begin
97
shift_counter <= shift_counter + 4'b0001;
98
end
99
end
100
101
102
if(shift_counter >= 4'b0001 && shift_counter <= 4'b1110)begin
103
shift_counter <= shift_counter+ 4'b0001;
104
end else begin
105
if(shift_counter == 4'b1111)begin
106
shift_counter <= 4'b0000;
107
end
108
end
109
110
end
111
112
113
if(SR_2 != 2'b01) begin
114
counter8ciklov <= 0;
115
end
116
if(shift_counter == 4'b1000 || shift_counter == 4'b1111) begin
117
SR_2 <= SR_2 +1;
118
end
119
if(counter8ciklov < 3'b111 && SR_2 == 2'b01)begin
120
counter8ciklov <= counter8ciklov +1;
121
end else begin
122
if(counter8ciklov ==3'b111 && SR_2 == 2'b01)begin
123
SR_2 <= SR_2 +2;
124
125
end
126
end
127
end
128
129
always @(posedge O && SR_2 == 2'b11)begin
130
SR_set <= 1;
131
end
132
133
endmodule
#7582575
The Shiftregister 15 bits wide. Sending via uart requires two data bytes with 1 start and 1 stop bit each (8N1). So you will need to transmit 20 bits, and you have 24 clock cycles time. So if the UART transmits with a bit rate ~equal to the clock rate, yes then its possible. If the UART is slower, no.
#7582607
PEter wrote:
Hello,
maybe you should look into uart.v in the zip file you attached to your post?
There seems to be WORKING UART implementation, so you only need to use it, and you are done.
OP #7582615
First I would like to thank you both for answering.
  1. Can I set the speed of UART or is this a fixed max value that I have to read in the datahseet of artix7 ? Or did you just mean the baud rate by this ?
  2. I knew it will need 2 transfers of 8 bits for data and all the stop and start bits together shouldn't exceed the 24 clock cycles (if the UART speed is fast enoguh). So I understand that.
  3. I do have a working uart but I don't know how to implement it into my project. At UNI we did that UART example but I don't know how to use it in my project. I would be grateful if you could have helped me out.
Thank you again for your replys
#7582621
you should have started so:
I have homework at the UNI where I need to use UART and I do not know how.
Please help me with my homework.
OP #7582628
I am sorry but this is not a homework. I am trying to build a detector which will detect to which way the current is flowing. The only part from the UNI is the UART part.
#7582634
Well then USE the UART.v code, the uart is there just use it. If you do not know how to use a verilog module then use google.
#7582653
PEter wrote:
As said I do not know how to implement it into my project therefore I am trying to find help here.
And I did tell you to use google. OK I do it for you:
google: how to instatiate verilog modules I did this for you, and did take FIRST LINK
https://www.chipverify.com/verilog/verilog-module-instantiations
it explains how to use verilog modules. Just instatiate the uart_tx module and use it then as needed in your top-level design.
OP #7582739
I tried many things. Now even that from the forum you have sent me. I can't figure it out.
// Instantiate tx_uart module
tx_uart #(.DATA_WIDTH(8), .FREQ(10000000), .BAUD(115200)) uart_tx_inst (
    .i_clk(f_clk),
    .i_rst(rst),
    .i_data(Q_4),  // Data I want to send to UART
    .i_valid(SR_en),
    .o_tx(),  // Connect to  output (an external pin)
    .o_busy(tx_busy)  // Connect to tx_busy
wire tx_output_signal;
assign tx_output_signal = uart_tx_inst.o_tx;
endmodule
This is the code I added, since I only need to use TX. The problem is that I dont really understand what is going on here. Im trying to do a simulation but tx_output_signal is low at all times. Also tx_busy is set to busy all the time.
#7582757
>     .i_clk(f_clk),
>     .i_rst(rst),
>     .i_valid(SR_en),
here you should connect tx_output_signal and not use assign!!!!
> endmodule
this is some weird way todo things. You should have see above, used the output signal in instantion.
how long is your VALID pulse? How long did you simulate? The UART will send 0 for START as long as one bit time at the beginning. But BEFORE valid going low output should be high for sure, and busy should be low after reset before valid
#7582772
PEter wrote:
I tried many things. Now even that from the forum you have sent me. I can't figure it out. [code]// Instantiate tx_uart module tx_uart #(.DATA_WIDTH(8), .FREQ(10000000), .BAUD(115200)) uart_tx_inst ( .i_clk(f_clk), .i_rst(rst), .i_data(Q_4), // Data I want to send to UART .i_valid(SR_en), .o_tx(), // Connect to output (an external pin) .o_busy(tx_busy) // Connect to tx_busy );
it seems your uart_tx has major issue in the code, namely the START bit can be random length depending when you assert valid. But that is not yet your problem, you have some more issues to solve out. also it seems busy is never cleared.. but it should be low after reset until valid comes, then when it asserts it is asserted forever.
maybe get some better UART IP core, that works
OP #7582783
here you should connect tx_output_signal and not use assign!!!! I dont know what you mean. I know that o.tx() is the serial data that will be transmitted. I just made tx_output_signal to try to simulate it but it didnt work.
I am running simulation for 1000ns. Data_valid should be positive when SR_en = 1 right ? .i_valid(SR_en)
In that case, SR_en is on for 40ns so the i_valid should be the same
I just want the variables from my module that I crated to be used in the module UART
I have SR (its counting clk cycles from ADC) which I need to be sent via UART. This data can be sent while SR_en = 1 and meanwhile i need tx_busy to be 1. I dont know how to do that.
A question of your own? This thread is over 2 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
