at89c51cc03 problems
OP (Company: individual) #7568431
• ▲ useful
▼ not useful
Hi, I need to read the flash contents in a"at89c51cc03" . So i installed the components (adaptor rs232 ,cristal etc.). Opening the flip I can read and write the microchip. However if i try to read one microchip that I have in other application allwais give "timeout". It´s possible the user bootloader is programed to jump the can bootloader? and how can I access the flash in this mode? Thanks Rodrigues
#7568475
• ▲ useful
▼ not useful
What version of chip do you have?
  • at89c51cc03u - uart bootloader type
  • at89c51cc03c - can bootloader type
What do you mean with:
Are you able to read the chip or not? Beside the flash, are you able to read the signature of the chip?
#7569627
• ▲ useful
▼ not useful
Strange...
Just to be sure:
  • The chip (you can't read) contains a program and does work in target?
  • You try to read that chip outside the target hardware?
  • When running the customer program in target hardware, is UART used in that application? Otherwise, may be that chips UART is faulty.
Next:
  • I would try to reduce UART baud rate, e.g. 9600
  • use a logic analyzer an monitor ..CC03 pins Rx, Tx, EA, Reset, PSEN
  • Try to find and use a parallel programmer.
Best success! Regards.
OP (Company: individual) #7569966
• ▲ useful
▼ not useful
Hi, First of all thank you for your help. Yes,the chip (I can't read) contains a program and it work in target.The problem is that was a short-circuit and damaged the input P0.0 (pin24).For that reason the target don´t make only one function. Yes I read the chip outside (and inside) the target hardware, and the result is the same,(Timeout error). The customer program in target hardware, not use UART (pin 6 and 7 not used) but uses can network,P4.0 and P4.1 (pin 14,15). I don´t bilieve the UART is faulty, maybe the user bootloader have some instruction to jump for network can bootloader,if is that possible,I don´t realy know. I will try with a logic analyzer to see all signals, and then(if I have no results),I wil try parallel programmer. Do you know someone? Thaks Rodrigues
#7570111
• ▲ useful
▼ not useful
In that case, you are already executing code in user flash FM0 and "network can bootloader" is part of user application. Applying Hardware Condition (see above) should prevent to reach that place.
No, I've never used a parallel programmer for it and was not engaged with it.
OP (Company: individual) #7574310
• ▲ useful
▼ not useful
HI,again. I'm back to say that I still can't communicate with the chip,(programmed). So in summary if I put a new (empty)chip in circuit,I can communicate with it and make everything(read,writh,etc.) then I just change the chip (put the programmed),and it gives (timeout error)even after reset ,(theoretically it should communicate since the conditions are the same). I analyzed the signals (with logic analyzer)and the diference is: in a new chip we have first a tx signal(rx in chip),and after we have the answer in rx(tx in chip), in other chip (the programmed),we have the same signal but the chip does not respond. I think we have two reasons for it: or the bootloader(FM1) is programed to jump immediately fo FM0,(i don´t know if it is possible),or they burned the inputs (rx and tx)on purpose since it was not used in application. If that's the case,does not make sense,they could put block bit´s to level 2, don´t you think? Thanks Rodrigues
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
