AVR Assembler: Debugging IR Remote Control Transmitter
OP #7518466
Hello,
I'm trying to develop a simple infrared remote-control transmitter, using an ATmega88A, assembler and the NEC modulation (please see https://www.mikrocontroller.net/articles/IRMP_-_english#NEC_+_extended_NEC for details on that).
My program isn't working correctly yet – after testing with a receiver failed, I connected a red LED to the output which produced the result that can be seen in the attached video: the LED blinks, but the transmission stretches out for circa one second, which is far too long – an NEC transmission should take about 60 ms.
I initially suspected wrong timer settings, but couldn't find any error. After reading through my code again and again, I decided to post it here in the hope that someone might have a look at it and maybe find the problem.
Thank you in advance for any help.
Best regards
– Johannes
Moderator (Company: Titel)
A flashing LED is way too little to debug a serial interface. You should connect a oscilloscope instead. Because with that you can determine the real pulse times and check it against the mentioned https://www.mikrocontroller.net/articles/IRMP_-_english#NEC_+_extended_NEC and find out the factor your timing is wrong.
When its "fairly ecacxt" the factor 8 you shuld check the correct setting of the clkdiv8 fuse in your AVR.
OP
Yes, that's true of course, but unfortunately I don't have a DSO at the moment.
I already checked that; it's not programmed (i.e. value 1). I used the UART successfully with the same hardware directly before I flashed the current program, so the clock frequency has to be correct.
OP
S. L. wrote:
WGM12 resides in TCCR1B.
Oh yes, that was a mistake – thank you!
I corrected that and, in addition, another error (forgot to clear the COM0A0 bit of TCCR0A in the ir_carrierOff macro, which caused the LED not to be switched off at the end of every other transmission).
Now, it works perfectly.
Again, S. L., thanks for your help!
Have a nice evening, – Johannes
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
