AVR Arithmatic
OP #7380454
• ▲ useful
▼ not useful
Found AVR code for 32 bit square root under AVR Arithmatic, topic 7.1
The code is look like assembly language but, some instruction is unknown like "role r24"
and some jump lable not found any where in the code (like brcs 2f, brcs 3f etc)
can anybody make necessary correction ?
The code file is attached.
#7380526
• ▲ useful
▼ not useful
the code in your attachment sqrt32_Fb.txt looks different compared to the one at https://www.mikrocontroller.net/articles/AVR_Arithmetik#Wurzel
;  Fast and short 32 bits AVR sqrt routine, avr-gcc ABI compliant
;  R25:R24 = SQRT (R25:R24:R23:R22)
;  rounded down to integer
;     Destroys R26,R27,R22,R23,R18,R19
;  Cycles incl call & ret = 260-300
;  Stack incl call = 2-3
.text
.global sqrt32_floor
.type sqrt32_floor, @function
sqrt32_floor:
    ldi   R19, 0xc0
    clr   R18               ; rotation mask in R19:R18
    ldi   R27, 0x40
    sub   R26, R26          ; developing sqrt in R27:R26, C=0
1:  brcs  2f                ; C --> Bit is always 1
    cp    R24, R26
    cpc   R25, R27          ; Does test value fit?
    brcs  3f                ; C --> nope, bit is 0
2:  sub   R24, R26
    sbc   R25, R27          ; Adjust argument for next bit
    or    R26, R18
    or    R27, R19          ; Set bit to 1
3:  lsr   R19
    ror   R18               ; Shift right mask, C --> end loop
    eor   R27, R19
    eor   R26, R18          ; Shift right only test bit in result
    rol   R22               ; Bit 0 only set if end of loop
30
    rol   R23
31
    rol   R24
32
    rol   R25               ; Shift left remaining argument (C used at 1:)
33
    sbrs  R22, 0            ; Skip if 15 bits developed
34
    rjmp  1b                ; Develop 15 bits of the sqrt
35
36
    brcs  4f                ; C--> Last bits always 1
37
    lsl   R23               ; Need bit 7 in C for cpc
38
    cpc   R26, R24
39
    cpc   R27, R25          ; After this C is last bit
40
41
4:  adc   R26, R19          ; Round up if C (R19=0)
42
    mov   R25, R27          ; return in R25:R24 as for avr-gcc ABI
43
    mov   R24, R26
44
    ret
45
46
.size sqrt32_floor, .-sqrt32_floor
#7382022
• ▲ useful
▼ not useful
Kishor S. wrote:
Ok, thanks
but where is jump locations ?
see line 16, brcs 2f see line 20, brcs 3f
assembler shows an error on this instructions
These notations are from C inline assembly language, which is very different from an directly usable assembly language.
The understanding of this crude notation is simple: the number describes the relative branch distance (in instruction words), the trailing character denotes, if it is a forward branch or a backward branch. Of course the 'f' stands for 'forward'.
So your task is: count instruction words up from the branch instruction and insert a label at found point in source code. Finally replace the branch target parameter by the name of this label.
#7382045
• ▲ useful
▼ not useful
That's so wrong, even the opposite wouldn't be any better!
1f or 1b (or any other number) simply points to a numbered label in forward or backward direction.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
