Signal clock generator
OP #7320909
Hello everyone, I am new to VHDL so basically I need help with vhdl code that I have to do till friday for college. I'm working in Xilinx ISE (dev sys is E2LP)
"Design a clock signal generator circuit. Using switches on the development system, the frequency of the clock signal should be able to be selected as: 3 Hz, 6 Hz, 12 Hz, 24 Hz, 100 Hz, 1000 Hz and 2000 Hz."
So I have been working on solution but I'm not sure if it is going to work on E2LP. Any help is going to be appreciated
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clock_generator is
    Port ( clk_sel : in STD_LOGIC_VECTOR(3 downto 0);
           clk : out STD_LOGIC);
end clock_generator;
architecture Behavioral of clock_generator is
    signal clk_int : std_logic := '0';
    signal clk_freq : integer := 3;
begin
    clk_gen: process(clk_sel)
    begin
        case clk_sel is
            when "0000" => clk_freq := 3;
            when "0001" => clk_freq := 6;
            when "0010" => clk_freq := 12;
            when "0011" => clk_freq := 24;
            when "0100" => clk_freq := 100;
            when "0101" => clk_freq := 1000;
            when "0110" => clk_freq := 2000;
            when others => null;
        end case;
    end process;
    clk <= not clk_int;
    clk_int_gen: process(clk)
    begin
30
        clk_int <= not clk_int after (1000000/clk_freq) ns;
31
    end process;
32
end Behavioral;
Moderator (Company: Titel) #7321982
Give it a try. Start the synthesizer and look what happens.
But to go into future: it won't work. Simply because inside the FPGA isn't anything like a "variable drlay" like that you want to get with "after (1000000/clk_freq) ns;"
In your FPGA you will have to use flip-flops and logic (in the LUTs) to create a counter that counts some clock-cycles and toggles a flag after reaching a desired prescaler value.
With other words: why reenventing the wheel? Simply look how others did the job and try to understand what they did.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
