Verilog circuit
#7304640
Well ... how are a, b and c connected at the bottom of the MUX? The left input is b, then a and right is c. So 000 ... 111 is a combination of b, a, c.
In VHDL it would be:
signal sel := std_logic_vector(2 downto 0);
begin
sel <= b & a & c;
with sel select y <= a and b when "000", c when "001", a and b when "010", '1' when "011", a and b when "100", '0' when "101", a and b when "110", a xor b when "111";
And now ask ChatGPT to translate this in Verilog:
Question:
Translate
begin
sel <= b & a & c;
to Verilog.
Answer:
reg [2:0] sel;
always @* begin case (sel) 3'b000, 3'b010, 3'b100, 3'b110: y = a & b; 3'b001: y = c; 3'b011: y = 1'b1; 3'b101: y = 1'b0; 3'b111: y = a ^ b; endcase end
assign sel = b & a & c;
#7380531
module mux(input b,a,c, output reg y ); always@(b,a,c) begin if(!b) assign y=c; else if(b) begin assign y=a; if(a==1 && c==1) assign y=1'b0; end end
endmodule
this code was successfully executed on xilinx vivado
testbench
module tb; reg b,a,c; wire y; mux uut(b,a,c,y); initial begin b=1'b0; a=1'b0; c=1'b0; #10 b=1'b0; a=1'b0; c=1'b1; #10 b=1'b0; a=1'b1; c=1'b0; #10 b=1'b0; a=1'b1; c=1'b1; #10 b=1'b1; a=1'b0; c=1'b0; #10 b=1'b1; a=1'b0; c=1'b1; #10 b=1'b1; a=1'b1; c=1'b0; #10 b=1'b1; a=1'b1; c=1'b1;
#20 $finish; end endmodule
sorry if am too early😅
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
