Vhdl project: mini-router
Guest #7267870
I have a project about a mini router, I wrote the source code and the
testbech and it seems to work, but I'm not sure everything is correct
because I'm new in vhdl codes. Could someone please check it? I ll share
my codes and the test of the project.
Guest #7267878
For debug/verifying purposes, it woulde be fine to have an additional
output whichs tells the sourceport (Link1 or link2) of the routed data.
#7267890
1:So you think my work is ok, right? You are just suggesting me how to
improve it?
2: Should I add the 2 output ports to the entity of the mini router?
Guest #7267894
> improve it?
No, not to improve it, just to make it test-able.
See Design for test: https://en.wikipedia.org/wiki/Design_for_testing
Test coverage is also important, and have a look to UVVM:
https://emlogic.no/uvvm/
Guest #7267897
use IEEE.std_logic_unsigned.all;
use IEEE.numeric_std.all;
Never use both of them. Numeric is suffcient.
Besides that, I don't see any problems (assuming to simulation results
are correct). But get used to write source code comments in english, so
everybody can understand them :-)
(Company: word wipe) #7385989
For debug/verifying purposes, it woulde be fine to have an additional output whichs tells the sourceport (Link1 or link2) of the routed data.
1:So you think my work is ok, right? You are just suggesting me how to improve it?
No, not to improve it, just to make it test-able. See Design for test: https://en.wikipedia.org/wiki/Design_for_testing https://drivemad.io/home
Test coverage is also important, and have a look to UVVM: https://emlogic.no/uvvm/
I agree with you, it is best to choose one or the other and never combine them. The use of numbers is adequate.
#7634318
I recommend asking for feedback on forums dedicated to VHDL or digital design. There, experienced users can review your code and testbench to ensure everything is correct. If you need help accessing your Airtel router settings for any reason, you can refer to this guide at https://routerctrl.com/airtel-router-login/. It provides step-by-step instructions on how to log in and make changes to your router settings. Good luck with your project!
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
