running a simulation with microblaze
Guest #7259997
• ▲ useful
▼ not useful
I am trying to simulate a micro blaze microprocessor demo design with
ram and ports in Modelsim. For XSIM in Xilinx Vivado environment it
allows to synthesize and implement. My problem is to start the
simulation:
I have exported the scripts from Vivado and got a folder exportsim /
modelsim, where I expected a do file to be used with ModelSims TCL
window.
In fact there is a script with extension *.sh wich I do not know how to
start
The readme says: "run ./demo.sh" but this does not work.
Leaving away the . or changing \ also has to result.
Anyone has an idea how to start this script?
It looks like this:
# Script info
echo -e "demo.sh - Script generated by export_simulation (Vivado v2021.1 -id)\n"
# Main steps
run()
  setup
  compile
  simulate
# RUN_STEP: <compile>
compile()
  source compile.do ..
So there are some known commands, but i never had used an sh before.
From a search I found that this might by a bash script and can be
executed by "exec bash" but i did not get it running.
So far I know this is unix shell. Is that correct, that Vivado exports
only for unix style?
Ideas welcomed.
Guest #7260138
• ▲ useful
▼ not useful
Forgot to mention: I am using Windows only and Vivado and ModelSim both
installed on the Win PC / Win10.
From another webpage I picked this:
Modelsim runs TCL. Bash would need to be handed over to the OS. tcl has
an "exec" command that passes instructions to the OS.
So how would be the correct phrase to run the simulation from the
>ModelSIM prompt?
Duke Scarring wrote:
> Looks like TCL-script for me...
How can i execute it?
ModelSim does not accept the code
./demo
# invalid command name "./demo"
do demo
# Cannot open macro file: board
do demo.sh
# -e demo.sh - Script generated by export_simulation
# ** Error: invalid command name "run()"
# Error in macro ./demo.sh line 36
# invalid command name "run()"
#     while executing
# "run()"
  • [vhdl]VHDL-Code[/vhdl]
