Manipulation of json
Guest #7240917
• ▲ useful
▼ not useful
Test schrieb:
> I want to read it in an array and add one pair [7,8].
You can write a simple JSON parser that does just that. Or you use a
general JSON parsing library and construct your data structure with it.
I guess adding the additional pair does not require any JSON business.
KR, Sebastian
Guest #7241012
• ▲ useful
▼ not useful
Hello i tried it
#include <iostream>
#include "ArduinoJson.h"
int main() {
  StaticJsonDocument<300> doc;
  char json[] =
      "[[48.756080,2.302038],[48.756080,2.302038]]";
  DeserializationError error = deserializeJson(doc, json);
  if (error) {
    std::cerr << "deserializeJson() failed: " << error.c_str() << std::endl;
    return 1;
  double longitude = doc[0];
  // Print values.
    std::cout << longitude << std::endl;
But the output is 0. WHat is wrong??
