TLV272 Rail to Rail problem DIODES
Guest #7231323
Hello,
I need a expert tip for my problem by using a Operational Amplifiers
TLV272IS-13 from DIODES. Rail to Rail, 3,3VCC to GND as power supply. In
my circuit I use the TLV272IS-13 as a “Voltage Follower” to measure the
net supply of 230V/50Hz over a rectifier bridge and a voltage divider.
By reaching the max limit of net supply (300VAC) the Voltage Follower is
by 3,3V. But unfortunately, the output signal of TLV272IS-13 is cut by a
voltage of 2,92V.
I testes bigger capacities by power supply (22uF) between 3,3V and GND,
but without positive result. I unsoldered all capacities in the circuit,
unsoldered the pulldown, tested an pull up of 12k to 3,3V also I copied
the circuit to an external board, but nothing helps the signal is cut by
2,29V.
By using a simple 3,3V over an adjustable voltage divider I can go up to
3,3V (3,25V) without problems, but if there is a frequency in the
signal, the Rail to Rail does not work.
I changed to an operational amplifier type TLV272CDR from Texas
instruments and it works perfectly. The 300VAC will be displayed as 3,3V
after TLV272CDR.
Does I overlook something in the datasheet ?
Is TLV272IS-13 from Diodes not able do drive RtR ?
Mikel
Guest #7231343
The datasheet says "Rail to Rail output". But it does not claim a rail
to rail input. If you use this OpAmp as a voltage follower, the input
common mode range limits the usable voltage range.
The recommended Common Mode Input Voltage according to datasheet ends at
VDD-1.35V
You may divide the input voltage by a factor of 2 and configure the
OpAmp as x2-amplifier - then the output should look better.
Start a new thread
