help - multi-driven \\ clocked by two different clocks
Guest #7222584
First I would like to thank everyone who always helping (=, even if I am
not always clear.
I had a lot of trouble creating a system, I'm trying to make it start
working once until she finish working. The system needs to wait for
external signal ' ' in order to work one more tw
When I write two different independent if conditions, then an error
message comes out (p1 code) : [Synth 8-6859] multi-driven net on pin
U4/chek with 1st driver pin 'U4/chek_reg__0/Q'
["C:/Users/danie/Desktop/FinalProject/FinalProject/FinalProject.srcs/sou
rces_1/new/eieo.vhd":66]
(p1 code)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity eieo is
    Port (
           Tenb : in STD_LOGIC;
              clk : in std_logic;
             UPDOWN : in STD_LOGIC;
             startcountenb : in std_logic;
           eo : out STD_LOGIC;
           ei : out STD_LOGIC);
end eieo;
architecture Behavioral of eieo is
signal chek : std_logic:='0';
signal counter : integer range 0 to 100000000:=0;
type state_type is(s1, s2, s3, s4);
signal state : state_type :=s1;
constant n1 : integer :=4001;
constant n2: integer :=3001;
30
constant n3 : integer :=4001;
31
constant n4 : integer  :=2557011;
32
signal tempoe : std_logic:='0';
33
signal tempie : std_logic:='0';
34
35
36
begin
37
38
39
40
41
process(clk,chek,Tenb,UPDOWN,state) begin
42
43
if( UPDOWN='1') then
44
    if(falling_edge(Tenb)) then
45
        chek<='1'; end if;
46
47
--else
48
end if;
49
50
51
if(rising_edge(clk) ) then
52
53
if(chek='1') then
54
55
counter<=counter+1;
56
57
case state is
58
59
    when s1 => if( counter=n1) then tempie<=not(tempie);
60
                                      tempoe<='0';
61
                                      counter<=0;
62
                                      state<=s2;
63
64
                                      end if;
65
66
    when s2 => if( counter=n2) then tempie<=not(tempie);
67
                                      tempoe<='0';
68
                                      counter<=0;
69
                                      state<=s3;
70
                                      end if;
71
72
    when s3 => if( counter=n3) then tempoe<=not(tempoe);
73
                                      tempie<='0';
74
                                      counter<=0;
75
                                      state<=s4;
76
                                      end if;
77
78
    when s4 => if( counter=n4) then tempoe<=not(tempoe);
79
                                     tempie<='0';
80
                                     counter<=0;
81
82
83
                                       chek<='0';
84
85
86
                                     state<=s1;
87
                                      end if;
88
end case;
89
else
90
tempie<='0';
91
tempoe<='0';
92
end if;
93
end if;
94
95
--end if;
96
97
end process;
98
ei<=tempie;
99
eo<=tempoe;
100
end Behavioral;
 When I write the " if's" under the same condition,  I get another error
message (p2 code) : [Synth 8-5787] Register chek_reg in module eieo is
clocked by two different clocks in the same process. This may cause
simulation mismatches and synthesis errors. Consider using different
process statements
(p2 code)
library IEEE;
entity eieo is
    Port (
              clk : in std_logic;
           eo : out STD_LOGIC;
end eieo;
begin
30
31
32
33
34
35
36
37
38
        chek<='1'; end if;
39
40
else
41
--end if;
42
43
44
45
46
if(chek='1') then
47
48
counter<=counter+1;
49
50
case state is
51
52
53
                                      tempoe<='0';
54
                                      counter<=0;
55
                                      state<=s2;
56
57
                                      end if;
58
59
60
                                      tempoe<='0';
61
                                      counter<=0;
62
                                      state<=s3;
63
                                      end if;
64
65
66
                                      tempie<='0';
67
                                      counter<=0;
68
                                      state<=s4;
69
                                      end if;
70
71
72
                                     tempie<='0';
73
                                     counter<=0;
74
75
                                       chek<='0';
76
77
                                     state<=s1;
78
                                      end if;
79
end case;
80
else
81
tempie<='0';
82
tempoe<='0';
83
end if;
84
end if;
85
86
end if;
87
88
end process;
89
ei<=tempie;
90
eo<=tempoe;
91
end Behavioral;
What do you do in such cases, I didn't find any mention of it anywhere.
Guest #7222601
You correctly used the vhdl formatting tags, but could you attach the
code as vhdl file (correctly formatted)? The vhdl formatting is broken
here, thus the code is difficult to read.
I suspect the problem might be the triggering on falling and rising
edge. UPDOWN is a signal, so it might change during runtime and I don't
know how and if this could be synthesised.
Moderator (Company: Titel) #7222604
Write a clocked process as it is printed in any book. Or simply have a
close look at the synthesizers user manual how a  synchronous has to be
written.
To keep things simple: use only one clock and only one edge of it. In
the whole design.
And one additional hint: check your sensitivity lists. When the
sensitivity list is wrong, then the simulation will not match the real
hardware.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
