Help - System not functioning as required
Guest #7187133
Hello everyone, I designed a uart successfully.
I initially configured it to enable sending information by a button from
the FPGA, the information was sent successfully.
After this I designed a timer that will send 24 packets of 8 bits and
after that it will stop.
Despite this, the system does not stop sending, even though the
simulation is functioning properly in reality, the UART continues to
send information.
If you notice - in the category of Synchronize the change to signals is
limited to 23 and then the system should stop changing the sending
signals :
  if(counteo <= 23 ) then
        Temp_clk2<=not(Temp_clk2);
        else
        Temp_clk2<='0';
        end if;
-- Create Date: 17.05.2022 12:19:31
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Uart is
    Port ( Send : in STD_LOGIC;
           clk : in STD_LOGIC;
           Data : in std_logic_vector(7 downto 0);
           Ready : out STD_LOGIC;
           Uart_Tx : out STD_LOGIC);
end Uart;
architecture Behavioral of Uart is
constant baud_timer : integer:= 10415;
constant bit_index_max : integer:=10;
type state_type is(Rdy, Load_bit, Send_bit);
signal state : state_type :=RDY;
signal timer : integer:=0;
signal txdata :std_logic_vector(9 downto 0);
signal bitIndex: integer range 0 to bit_index_max :=0;
signal txbit : std_logic:='1';
begin
process(clk)
begin
30
if rising_edge(clk) then
31
32
case state is
33
34
when Rdy =>
35
36
           if (Send='1') then
37
               txdata <= '1' & data & '0';
38
               state <= Load_bit;
39
           end if;
40
           timer<= 0;
41
           bitIndex <= 0;
42
           txbit <= '1';
43
44
when Load_bit =>
45
46
           state <= Send_bit;
47
           bitIndex<= bitIndex +1;
48
           txbit <= txdata(bitIndex);
49
50
when seND_BIT =>
51
52
           IF(timer = baud_timer) then
53
           timer <= 0;
54
           if ( bitIndex = bit_index_max) then
55
           state <= Rdy;
56
           else state <= Load_bit;
57
           end if;
58
           else timer <= timer + 1;
59
           end if;
60
end case;
61
end if;
62
end process;
63
Uart_Tx <= txbit;
64
Ready <= '1' when (state = Rdy) else '0';
65
end Behavioral;
-- Company:
-- Engineer:
-- Create Date: 01.09.2022 01:12:55
-- Design Name:
-- Module Name: jghjfk - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
30
-- any Xilinx leaf cells in this code.
31
--library UNISIM;
32
--use UNISIM.VComponents.all;
33
34
entity infoStorage is
35
    Port ( clk : in STD_LOGIC;
36
           eo : in STD_LOGIC;
37
           dataout : out STD_LOGIC_VECTOR (7 downto 0):="00000000");
38
end infoStorage;
39
40
architecture Behavioral of infoStorage is
41
42
type t_Row_Col is array (0 to 7, 0 to 2) of STD_LOGIC_VECTOR (7 downto 0);
43
44
signal r_Number : t_Row_Col:=
45
( ("01000001","01000010","01000011"),
46
  ("01000100","01000101","01000110"),
47
  ("01000111","01001000","01001001"),
48
  ("01001010","01001011","01001100"),
49
  ("01001101","01001110","01001111"),
50
  ("01010000","01010001","01010010"),
51
  ("01010011","01010100","01010101"),
52
  ("01010110","01010111","01011000")  );
53
signal i : integer range 0 to 7:=0;
54
signal j : integer range 0 to 2:=0;
55
begin
56
57
process(eo,clk)
58
begin
59
60
if(rising_edge (clk)) then
61
62
    if(eo='1') then
63
64
    dataout<=r_Number(i,j);
65
66
    if(j<=1) then
67
            j<=j+1;
68
            elsif(j=2 and i<=6) then
69
                j<=0;
70
                i<=i+1;
71
    end if;
72
73
    end if ;
74
75
76
end if;
77
78
79
end process;
80
81
end Behavioral;
library IEEE;
entity Synchronize is
           clkout : out STD_LOGIC;
           clk1 : out STD_LOGIC;
           clk2 : out STD_LOGIC;
           eo : out STD_LOGIC);
end Synchronize;
architecture Behavioral of Synchronize is
signal state1: std_logic:='0';
signal state2: std_logic:='0';
signal count1 : integer range -1001 to 105500001:=-1001;
signal count2 : integer range 0 to 103501:=0;
signal counteo : integer range 0 to 50:=0;
signal Temp_clk1 :  STD_LOGIC:='0';
signal Temp_clk2 :  STD_LOGIC:='0';
signal Temp_eo : STD_LOGIC:='1';
begin
process(clk,counteo) begin
30
31
32
if( rising_edge(clk) ) then
33
34
case state1 is
35
36
37
    when '0' =>
38
39
    if( count1 = 105499 ) then
40
        count1<=0;
41
42
43
        Temp_clk1<=not(Temp_clk1);
44
        else
45
        Temp_clk1<='0';
46
        end if;
47
48
        state1<='1';
49
50
51
52
53
    else count1<=count1+1;
54
    end if;
55
56
     when others =>
57
58
        if( count1 = 999 ) then
59
        count1<=0;
60
61
62
63
64
        else
65
        Temp_clk1<='0';
66
        end if;
67
68
69
70
71
72
73
        counteo<=counteo+1;
74
75
76
        state1<='0';
77
78
79
80
    end if;
81
82
83
84
end case;
85
86
case state2 is
87
88
89
    when '0' =>
90
91
    if( count2 = 103499 ) then
92
        count2<=0;
93
94
95
96
97
98
        else
99
        Temp_clk2<='0';
100
        end if;
101
102
103
104
105
        state2<='1';
106
107
108
109
110
    else count2<=count2+1;
111
    end if;
112
113
     when others =>
114
115
        if( count2 = 3999 ) then
116
        count2<=999;
117
118
119
120
        else
121
        Temp_clk2<='0';
122
        end if;
123
124
        state2<='0';
125
126
127
128
    end if;
129
130
131
132
end case;
133
134
135
136
end if;
137
138
-- else
139
-- Temp_clk2<='0';
140
-- Temp_clk1<='0';
141
---- Temp_eo<='0';
142
-- end if;
143
144
end process;
145
eo<=Temp_eo;
146
clkout<=clk;
147
clk1<=Temp_clk1;
148
clk2<=Temp_clk2;
149
150
end Behavioral;
Guest #7187417
Hello,
your urgent request has been noticed.
Please put on the Warnweste and the Dreieck on the street and hold the
line for additional questions.
Ersthelfers will arrive later this evening.
Guest #7187502
So ... it's a pity. you master this complicated language but fail at the
simplicity of VHDL.
Why do you not even try to format your code in a readable manner? Use
spaces, use linefeed carrage return and space. They all were invented in
the analog days centurys ago.
But the biggest problem here is:
You postet three components, but the toplevel or binding component is
missing. A testbench is missing, too.
So at the moment the possible error may reside in these missing
components.
Best regards,
-gb-
Guest #7187514
My guess: counteo overflows and so it is <23 again. Let the simulation
run a bit longer and also add the relevant signals (FSM states and all
the different counters, not only the ports) to the waveform.
Guest #7187929
-- Company:
-- Engineer:
-- Create Date: 03.09.2022 18:24:34
-- Design Name:
-- Module Name: Top_M_Uart - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
30
31
--library UNISIM;
32
33
34
entity Top_M_Uart is
35
36
           Uart_Tx : out STD_LOGIC;
37
38
           Ready : out STD_LOGIC);
39
end Top_M_Uart;
40
41
architecture Behavioral of Top_M_Uart is
42
43
component Uart is
44
45
           clk : in STD_LOGIC;
46
47
48
49
end component;
50
51
component infoStorage is
52
53
           eo : in STD_LOGIC;
54
55
end component;
56
57
component Synchronize is
58
59
60
61
62
63
64
end component;
65
66
67
signal s1,s2,s3,s4,s5 : STD_LOGIC;
68
69
signal i1 : STD_LOGIC_VECTOR (7 downto 0);
70
71
begin
72
U1 : Synchronize port map (clk=>s1,clkout=>s2,clk1=>s3,clk2=>s4,eo=>s5);
73
U2 : infoStorage port map (clk=>s4,eo=>s5,dataout=>i1);
74
U3 : Uart        port map (Data=>i1,Send=>s3,clk=>s2,Ready=>Ready,Uart_Tx=>Uart_Tx);
75
76
s1<=clk;
77
end Behavioral;
-- Company:
-- Engineer:
-- Create Date: 04.09.2022 00:43:51
-- Design Name:
-- Module Name: TB_TOPM - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
30
31
--library UNISIM;
32
33
34
entity TB_TOPM is
35
--  Port ( );
36
end TB_TOPM;
37
38
architecture Behavioral of TB_TOPM is
39
40
component  Top_M_Uart is
41
42
43
44
end component;
45
46
signal CLK : std_logic:='0';
47
signal Uart_Tx ,Ready : std_logic;
48
49
begin
50
U1 : Top_M_Uart port map(clk=>clk,Uart_Tx=>Uart_Tx,Ready=>Ready);
51
52
process begin
53
wait for 5ns;
54
clk<=not(clk);
55
end process;
56
57
end Behavioral;
Guest #7187955
@ Daniel
Attaching a few screenshots without further ado is … quite rude,
especially when expecting help
- 1
Guest #7188114
Sorry, that's not the intention, I built a system that blocks the
sending signal to the uart called Synchronize, which provides 2 signals
- the first is an exchange of the information being sent, and the second
is a sending enable signal - clk1 The uart receives the signal and sends
the information as can be seen in the simulations after 24 times the
signal remains low despite the computer Unlike the simulation, the
information continues to be sent endlessly
Guest #7188115
FPGA Rettungsdienst wrote:
> Help will arrive soon. The Tatütata is on its way to Unfallstelle
Heiner wrote:
> @ Daniel
> - 1
Guest #7188124
Well the pictures showing the vivado messages are useless because these
messages have nothing to do with your problem.
The simulation pictures are useless as well because they only show the
problem but not the related signals and states inside the problem
causing components.
Notfallhilfe will simulate for you when it arrives at Unfallstelle.
Guest #7188368
> these
> causing components.
I didn't quite understand what I should do in such a case...
The simulation shows 100% normality and in reality the received signals
continue to send the information.
Guest #7188384
Well,
counteo just counts up. It does not stop counting at 23 or 24. So what
will happen?
> simulation
The User was right!
Guest #7188387
> run a bit longer
Much longer. This overflow will not happen in feasible simulation time.
But in Hardware it will happen.
Guest #7188390
Well, counteo is defined as integer range 0 to 50, so the simulator
should  give an error in feasible simulation time. In real hardware, the
overflow will take much longer probably, depends what the synthesizer
did.
Guest #7188393
Look what counteo is doing. It does not stop at 24, but counts and
counts and counts. So at some point, it will overflow and start from 0
again.
Solution: Stop counting, when counteo reaches 24.
Guest #7188934
> again.
Thank you very much, I looked at it after that I realized what a
retarded mistake this is.
I'm pretty new and have never been exposed to it having continuity after
OV.
Guest #7189083
> OV.
Yes, that's a thing we all had to learn.
The more important lesson here is: That was NOT a thing where the
simulation did not match the synthesized outcome. It was just that you
observed some microseconds in simulation and observed some seconds on
real hardware, where the "erroneous" behavior occured after the time
slot you simulated.
So the conclusion "In sim it is working, on hardware not" was not
correct. You always have to interpolate what will happen, when the
design runs longer than the simulated time and keep in mind that
hardware runs much faster than simulation.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
