Help with Terms in .V file
Guest #7130487
Please post the verilog file.
bteddy wrote:
> cmps = ???? needs clarification
These are names of variables. The author of the code did invent these
names on his own. So there is only one way to get full name: ask the
author of the code.
Guest #7130558
Being a Verilog .v file it defines circuits in a FPGA. Correct?
So, ena would equal a Enable signal line.
rst would equal Reset signal line.
I just need a little help defining:
cmps = ???? needs clarification (is it a comparator OR a
chip-multiprocessor OR a complex...)
fmod = ???? needs clarification
hfc = ???? needs clarification (is it a high frequency clock OR...)
mod = ???? needs clarification (modulator OR a modual OR a modulus...)
Thank You
Moderator (Company: Titel) #7130679
Simply look at what those signals are used for in the unknown and
strictly secret 5phase.V file.
Help us helping you!
Simply attach it here. Or give a link to it when you found it on the
www.
Guest #7131718
//TOP LEVEL MODULE
module epm240(rst, ena,dir, pul, mod, cmps, outs, hfc);   //module
stepmot                                   is the top level module.
     input rst, ena;                        //rst when asserted brings
the shaft to reference position.
        input mod;                           //mod specifies step
operation or continuous operation.
        input dir;                               //dir is for clockwise
or anti clockwise motion.
        input pul;
    input [4:0] cmps;
    output hfc;
    output [9:0] outs;
    wire w_pwm;
  /* Instantiation  of controller module.*/
  stepper s1(
    .rst (rst),
    .ena (ena),
    .pul (pul),
    .dir (dir),
    .mod (mod),
    .pwm (w_pwm),
    .outs (outs),
    .cmps (cmps));
  /* Instantiation  of clock generate module.      */
  clk_generate cg1(
    .ena (ena),
    .pul (pul),
    .rst (rst),
    .pwm (w_pwm),
    .hfc (hfc));
endmodule
/* Module stepper is the motor controller module */
module stepper (rst, ena, pul, dir, mod, pwm, outs, cmps);
  parameter A1 = 0, A2 = 10, B1 = 5, B2 = 15, C1 = 7, C2 = 19, D1 = 12,
D2 = 2, E1 = 17, E2 = 6;
    input ena, pul, rst, dir, mod, pwm;
  input [4:0] cmps;
    output reg [9:0] outs;
    reg [19:0] position;
  reg fmod;
  always @(posedge pul or negedge rst) begin
    if(rst == 0) begin                                      // array
resets to 11111111100000000000 at rst=0
      position = 20'b11111111100000000000;
      fmod = 1'b0;
    end else if(ena == 1) begin
        //mod=0/1 for half/full step
        //dir=0/1 for anticlockwise/clockwise motion
        if(fmod == 1 && mod == 1) begin
          position = {position[18:0], position[19]};
          fmod = 1'b0;
        end
        if(mod == 0) begin
          if (dir == 0)
          else
            position = {position[0], position[19:1]};
          fmod = fmod + 1'b1;
        end else begin
          if (dir==0)
            position = {position[17:0], position[19:18]};
          else
            position = {position[1:0], position[19:2]};
        end
    end
  end
  always @(posedge pwm or negedge cmps[0] or negedge rst or negedge ena)
begin
    if(rst == 0 || cmps[0] == 0 || ena == 0)
      outs[1:0] = 2'b00;
    else
      outs[1:0] = {position[A2], position[A1]};
  end
  always @(posedge pwm or negedge cmps[1] or negedge rst or negedge ena)
begin
    if(rst == 0 || cmps[1] == 0 || ena == 0)
      outs[3:2] = 2'b00;
    else
      outs[3:2] = {position[B2], position[B1]};
  end
  always @(posedge pwm or negedge cmps[2] or negedge rst or negedge ena)
begin
    if(rst == 0 || cmps[2] == 0 || ena == 0)
      outs[5:4] = 2'b00;
    else
      outs[5:4] = {position[C2], position[C1]};
  end
  always @(posedge pwm or negedge cmps[3] or negedge rst or negedge ena)
begin
    if(rst == 0 || cmps[3] == 0 || ena == 0)
      outs[7:6] = 2'b00;
    else
      outs[7:6] = {position[D2], position[D1]};
  end
  always @(posedge pwm or negedge cmps[4] or negedge rst or negedge ena)
begin
    if(rst == 0 || cmps[4] == 0 || ena == 0)
      outs[9:8] = 2'b00;
    else
      outs[9:8] = {position[E2], position[E1]};
  end
endmodule
* clock generate
* clock = 3.3MHz  pwm = clock / 256 = 13KHz  half_current = pwm /
`timescale 1 ps / 1 ps
module  clk_altufm_osc_1p3( osc) /* synthesis synthesis_clearbox=1 */;
  output   osc;
  wire  wire_maxii_ufm_block1_osc;
  maxii_ufm   maxii_ufm_block1(
    .arclk(1'b0),
    .ardin(1'b0),
    .arshft(1'b0),
    .bgpbusy(),
    .busy(),
    .drclk(1'b0),
    .drdout(),
    .drshft(1'b0),
    .osc(wire_maxii_ufm_block1_osc),
    .oscena(1'b1)
    `ifdef FORMAL_VERIFICATION
    `else
    `endif
    .drdin(1'b0),
    .erase(1'b0),
    .program(1'b0)
    `else
    `endif
    .ctrl_bgpbusy(),
    .devclrn(),
    .devpor(),
    .sbdin(),
    .sbdout()
  defparam
    maxii_ufm_block1.address_width = 9,
    maxii_ufm_block1.osc_sim_setting = 300000,
    maxii_ufm_block1.lpm_type = "maxii_ufm";
  assign
    osc = wire_maxii_ufm_block1_osc;
endmodule
module clk_generate(ena, pul, rst, pwm, hfc);
  input ena, pul, rst;
  output reg pwm, hfc;
  wire  osc;
  reg [14:0] count_hfc;
  reg [9:0] count_pwm;
  clk_altufm_osc_1p3  clk_altufm_osc_1p3_component (
    .osc (osc));
  always @(posedge osc or negedge rst or negedge ena) begin
    if (rst == 0 || ena == 0) begin               // counter resets to 0
at rst=0 or pul=1
      count_pwm[9:0] = 10'b0;
      pwm = 1'b0;
    end else begin
      count_pwm = count_pwm + 1'b1;
      pwm = count_pwm[8];
    end
  end
  always @(posedge pwm or posedge pul or negedge rst or negedge ena)
begin
    if(pul == 1 || rst == 0 || ena == 0) begin                        //
counter resets to 0 at rst=0 or pul=1
      count_hfc[14:0] = 15'b0;
      hfc = 1'b1;
    end else begin
      if (count_hfc[14] == 1)
        hfc = 1'b0;
      else
        count_hfc = count_hfc + 1'b1;
    end
  end
endmodule
/***********************************END OF
PROGRAM.**********************************************/
Moderator (Company: Titel) #7131794
Why don't you simply look in the code?
I can clearly see:
And pul is acting like an additional reset in some cases.
All in all this code ist kind of dirty. Such things will break you
bones:
  always @(posedge pul or negedge rst) begin // sensitive to pul and rst
    if(rst == 0) begin                       // async reset...
      fmod = 1'b0;
      ...             // but pul not used throughout the whole module
As far as I see (as a VHDL guy) this code will not do whats expected and
even so not what the simulation will show.
And this here is a reason for firing the programmer:
  always @(posedge pwm or posedge pul or negedge rst or negedge ena) begin
This is an async combinatorial reset. Call me a seer cause I guarantee:
this design will crash now and then without any reason.
Guest #7134169
In Verilog, this code is correct. Unlike in VHDL, the clock edge will
not be evaluated explicitely inside the always block.
But this
is code from the bottom of hell and will never work in silicon.
Obviously it has been written without any hardware structure in mind.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
