How to check the value of a specific bit in vhdl
Guest
NINA wrote:
> i need to check the first bit of a
> signle after that the second bit
First of all, make yourself more familar with the ideas behind VHDL.
Checking a bit of a vector is absolutely basic.
if (signle[0]=='1')...
if (signle[1]=='1')...
Guest
Depending on what should be done, this could be a use case for a for
loop:
for i in 0 to signle'high loop/generate
    if signle(i) = '1' then
    end if;
end loop/generate
I hope there is no syntax error, but the idea should be clear.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
