STM32F103 math package
OP #7114844
• ▲ useful
▼ not useful
calculation time fixcomma for si5351
I have a project with Arduino UNO where the execution time for the line
below is 5,78 ms. The line is part of a Wobbler, which is running with
64 steps only. I awaited 1.28 ms with BluePill. After porting to
STM32F103 see yourself.
si5351.set_freq_manual((fnow) * 100ULL, pll_freq, SI5351_CLK0); //4,5 ms
//bin von BluePill enttäuscht
My expectation was, using BluePill, 5,78 / (72/16) MHz = 1,28 ms. Result
see above.
Only 22% quicker.
I'm using only fixcomma variables.
Any proposals?
Codes available if wanted.
Guest #7115600
• ▲ useful
▼ not useful
Rudi D. wrote:
> Any proposals?
It looks as if there is no proper setup for the clock. Therefore the
chip runs from only a slow internal RC-oscillator. Another idea is, that
the function "si5351.set_freq_manual" does it's calculations in a very
clumsy way. Or both, slow clock and clumsy algorithm.
W.S.
Guest #7124185
• ▲ useful
▼ not useful
Independent on I2C speed 100k or 400k nothing changes.
Still 4,4 ms for the si5351 Command.
Also the time needed for encoder interrupt is very short. If  I set the
interrupt to 5 ms -missing some encoder steps- does not change the 4,4
ms.
I'm familiar with fixcomma in assembler with tiny4313 and wobble
frequencies at max. 70 HZ. DDS Project in RMorg 2014-2015 with AD9850 up
to 30 MHz.
I think this would be a solution, but the si5351 is much more complex
comp. to AD9850. I want to use the si5351 up to  120 MHz. With some
phase mod. to have some sound.
Will see if I have enough drive to step into the si53551 deteils
registers and communication.
Guest #7124294
• ▲ useful
▼ not useful
> comp. to AD9850.
The SI5351 is a clock-generator based on PLL - it gives only a digital
output. The AD9850 is a DDS - it gives an analog output and needs a low
pass filter on the output.
While the AD9850 is very agile (it only needs to set the phase-offset to
switch it from one frequency to another) the SI5351 needs some time to
settle the VCO and its phase-loops.
Both chips are complex in their own way, but the use of the SI5351 ist
much more complicated compared to the AD9850, because the SI needs a
combination of 2 integer numbers, which give the best approximation to
the desired frequency - while the AD needs only the best value for the
phase increment.
W.S.
Guest #7124337
• ▲ useful
▼ not useful
is this from some public library? When it was designed for Arduino with
AVR, a common problem is the superfluous usage of type double. With 8
Bit AVR, the calculations were performed as float, but when used with
Cortex-M, expensive double math is used.
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
