AVR Questions for Uni
Guest
Guess you attended the relevant course at university or school.
So better check your scripts, use your brain - and good luck
By the way - where are you from? The way u ask reminds me of some
politicians.
Guest
Whoever has written these questions had a stroke and needs to get into
the hospital at once!
Oder hast du den Kram durch 3 schlechte Onlineübersetzer gewürfelt damit
dein Prof nicht merkt das du betrügst?
Guest
Ich bin mal nicht so!.
Sorge dafür, dass es Erklärungsnot bei Nachfragen gibt.
Also: Punkt 4 in Anlehnung an......
#include <Streaming.h> // die Lib findest du selber ;-)
Print &cout = Serial; // cout Emulation für "Arme"
// #include <functional>
constexpr size_t N {6};
byte test[N] {1,2,3,4,5,6};
template<typename T>
void reverse(T *begin, T *end)
  end--;
  while(begin<end)
    T temp=*end;
    *end=*begin;
    *begin=temp;
    begin++,end--;
void setup()
  Serial.begin(9600);
  cout << F("Start: ") << F(__FILE__) << endl;
30
31
  for(auto v:test) cout << v << endl;
32
  reverse(test,test+N);
33
  // std::reverse(test,test+N);
34
35
36
37
void loop()
38
39
40
Guest
Wer für die Beantwortung von Frage Nummer Eins ernsthaft Hilfe benötigt,
der sollte sich auf Mehlstaub-Allergie untersuchen lassen.
In der Bäckerbranche wird händeringend gesucht…
Guest
Dogukan D. wrote:
> I urgently need solutions to these questions
Simply writing the answers for you does not make sense.
I imagine that you finish your time at the university this way and later
program a piece of code in my next car that drives us directly to death.
No. If you cannot solve this simple work yourself within an hour, you
should fail and either start over learning or leave the university.
Start a new thread
