FPGA pin multiple usage
Guest #7017601
Hi all,
i use 10 fpga pins towards a connector on my board. They are set-up as 5
inputs and 5 outputs. on this connector i can have multiple little
boards and their function changes .
now for my question, is it good or bad practice to vhdl condition the
routing to these pins?
for example out pin10 is used as 1ms pulse for zeroing board1.
can i use out pin10 for uart TX for board2?
the little boards are not replaced 'live'. meaning that once the fpga
powers-up,
it will identify the board connected and set appropriate routing that
will not change (at least not until another power toggle).
thank you in advance
sparkyT
Moderator (Company: Titel) #7017711
I cannot see any problems. The only drawback: when you detect the wrong
type of board, then you will get strange behaviour.
Guest #7017744
Thanks for the confirmation.
Every advice in here has been spot on!
how can someone show their appreciation for all the help from this
forum?
anyway to buy you a beer, somehow?
SparkyT
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
