Help not working properly
Guest #7006549
Hello everyone, my English is not the best I would love patience.
I wrote a counter code designed to schedule the transfer of information
from an array to a single output signal.
The problem is that it bounces the value of control j from zero to a
maximum of one time.
I would love to know what the problem is, the goal is to split a vector
of 24 into 3 vectors of 8 when count_2 = 1.
If I do not use the tra tra increase, and if I do it does not respond.
process(clk,res_in)
variable Q1 : integer range 0 to 2000:=0;
variable Q2 : integer range 0 to 8:=0;
variable Q3,Q4 : integer range 0 to 8:=0;
begin
if(res_in = '1' or Q4=1) then
    Q1:=0;
    Q2:=0;
    Q3:=0;
    Q4:=0;
            elsif(rising_edge(clk) and enb='1') then
            Q1:=Q1+1;
                if(Q1=2000) then
                Q1:=0;
                tra<=not(tra);
                Q2:=Q2+1;
                    if(Q2=8) then
                    Q2:=0;
                    Q3:=Q3+1;
                        if(Q3=8) then
                        Q3:=0;
                        Q4:=Q4+1;
                            if(Q4=8) then
30
                            Q4:=0;
31
                            end if;
32
33
                        end if;
34
35
                    end if;
36
               end if;
37
         end if;
38
39
40
         if(count_2=1 and rising_edge(tra)) then
41
         if(j<7) then
42
            Dataout(0)<=Data(j)(7 downto 0);
43
            Dataout(1)<=Data(j)(15 downto 8);
44
            Dataout(2)<=Data(j)(23 downto 16);
45
            j<=j+1;
46
          end if;
47
         end if;
48
49
count_1<=Q1;count_2<=Q2;count_3<=Q3;count_4<=Q4;
50
end process;
Moderator (Company: Titel) #7006597
Ouch...
You will get strange effects with this here because Q4 is a variabel,
and you can't put variables in the sensitivity list. But for
recalculating the process a signal in the sensitivity list *must
change*.
But at a closer look the whole sensitiviy list looks inconsistet and
therfore the simulation must be wrong.
One of the actual problems is: you do some weird things with clocks.
To keep things short: "tra" for sure is not a clock!!!
A beginners design has only 1 clock: the one that is coming from the
quartz oscillator outside the FPGA. Only on this clock a 'event or a
risong_edge() or a falling_edge() has to be used.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
