Clock frequency reducer
OP #7004717
I am trying to divide my input clock signal by 10 - effectively setting
my out HIGH 5 of ten clock pulses and LOW the other 5.
However, my counter idea does not work - the clk_ou2 signal doesn't
update at all, and I do not know why.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Taktteiler is
port (
    clk_in : in std_logic;
    clk_out : out std_logic;
    reset : in std_logic
end Taktteiler;
architecture rtl of Taktteiler is
signal counter : unsigned(3 downto 0);
signal clk_out2 : std_logic := '0';
begin
process(clk_in)
    begin
        if(rising_edge(clk_in)) then
            counter <= counter + 1;
            if std_logic_vector(counter) = "101" then --reset the counter at 101
                counter <= (others => '0');
                clk_out2 <= clk_out2 XOR '1'; --toggle the out2 signal
            end if;
        end if;
        if reset = '1' then --reset on HIGH reset input
30
31
            clk_out2 <= '0';
32
        end if;
33
end process;
34
clk_out <= clk_out2;
35
end architecture rtl;
Guest #7004767
counter is a 4 bit vector. It can never be equal to "101", because that
ist a 3 bit vector. So std_logic_vector(counter) = "101" will never be
true...
Try to replace line 24 by
    if counter="0101" then
If it works, then check, if you really divide by 10 or by some other
value..
Guest #7004941
I prefer a simple solution with just a single shift register:
library ieee;
entity clk_divider is
    port
end entity clk_divider;
architecture rtl of clk_divider is
    signal clk_reg : std_logic_vector( 9 downto 0) := "0000011111";
begin
    process
    begin
        wait until rising_edge( clk_in);
        clk_reg <= clk_reg( clk_reg'high-1 downto 0) & clk_reg( clk_reg'high);
    end process;
    clk_out <= clk_reg( clk_reg'high);
Duke
Moderator (Company: Titel) #7005063
To get rid of such kind of problems I would use an integer range 0 to 9
for counting.
Then the compare for 0 and 5 is easily human readable:
   process(clk_in)
   begin
         if counter<9 then counter <= counter + 1;
         else              counter <= 0;
         end if;
         if counter = 0 then clk_out <= '0'; end if;
         if counter = 5 then clk_out <= '1'; end if;
   end process;
I prefer the very same without any process ;-)
library ieee;
    port ( clk_in  : in  std_logic;
           clk_out : out std_logic);
    signal clk_reg : std_logic_vector(9 downto 0) := "0000011111";
begin
    clk_reg <= clk_reg(8 downto 0) & clk_reg(9) when rising_edge(clk_in);
    clk_out <= clk_reg(9);
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
